Old Fri, Sep-21-2018, 05:51:35 AM   #11
HassanEido
HassanEido's Avatar
Lebanon
Default Re: power steering noise after hose upgrade
Originally Posted by kokgo20 View Post
I still have noise from the steel lines, but once i put the OEM hose on noise is gone. not necessarily that the noise = bad pump.
U lucked out ! If u ran them longer, you would definitely have had a damaged pump. I ran them for a month, never recovered(not the same lines). It might've been a coincidence that it went out when i put the lines, but generally, noise from pump means pump went bad, or going bad, fast.
Mods:
-Custom CF airbox
-Cat Cams 280 272.
-Custom dyno tune
385.7 whp 288 wtq
Old Fri, Sep-21-2018, 01:55:28 PM   #12
kokgo20
kokgo20's Avatar
Ran the steel lines for 2 years with a noise while Turing, one the lines rubbed against another and poked a hole and started leaking so I temporarily swapped it with my old factory lines noise was gone until I fixed the steel line and back on the car now
Build thread---------- INSTAGRAM ------------ROTREX REBUILD-------------Now offering custom digital gauges
2004 SMG PY/BLK - 600 TCKline - CPI Headers & resonated Sec1- Stoptech BBK 6 pod front & 4 pod rear with steel lines - 75mm Studs conversion - SDW monoball RTABs - AKG subframe bushings - Multi color AEs - FR-X 3.0 Projectors - Smoked Side markers - Euro bumper - V1 with hard wire & Stealth one - M Track Mod - ZCP steering rack - Dual LI - CSL Style diffuser - SCZA Exhaust - E9x Door handle LED retrofit - SCZA CSL bootlid - VEI systems custom air vent A/F & boost gauge - VEI custom air vent Water temp & oil pressure guage- Active Prima plus + TTFS tune - Mishimoto Radiator & Oil cooler - H&R front Sway - UUC camber arms - keyless & push to start system - clear bra - interiors red stitching contrast - Apex PS7s - 16" Spal fan
Jump to top kokgo20 is online now   Reply With Quote
Old Fri, Sep-21-2018, 04:48:02 PM   #13
HassanEido
HassanEido's Avatar
Lebanon
Again. Pump noise=laboring pump or low oil pressure=less pump life. Ure free to run whatever u want. That's my
Mods:
-Custom CF airbox
-Cat Cams 280 272.
-Custom dyno tune
385.7 whp 288 wtq
Discussing power steering noise after hose upgrade in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
