Old Thu, Jul-13-2017, 10:11:11 PM   #1
MFNATIK
Reputation: 0 MFNATIK is on a distinguished road
Default Just had inspection service, no valves needed to be re-shimmed, is this normal or OK?
I just bought the car at 93k miles from a woman owner who got the car in the divorce, it was her husband's and he took care of all the services. She said it had an oil service at 90k, but wasn't sure if they did the full inspection. So just being on the safe side I ordered all the parts and had the full service done. Most everything looked very recent except for the spark plugs which looked like they had 30k miles on them.
My buddy who did the service (he's a BMW Tech) said all the shims were within spec and he felt them all having about the right amount of resistance with his feeler tool. He felt that they'd last until the next 30k mile inspection service so none were change. I trust him so not a big deal, but would this be a sign that previous owner just didn't drive the car very hard so that the shims didn't wear down much?
2005 Imola M3 Convertible
2017 LSB F80
2017 Protonic Blue i3REx
2002 525iT M Sport
Jump to top MFNATIK is offline   Reply With Quote
Old Thu, Jul-13-2017, 10:46:06 PM   #2
Msidd
Reputation: 0 Msidd is on a distinguished road
Default Re: Just had inspection service, no valves needed to be re-shimmed, is this normal or
Believe it or not.. after 80k after the last adjustment i had .. only 2-3 were needed for mine. Seems like it's common to find after 60k not many get loose.
Sent from my SM-G930T using Tapatalk
Jump to top Msidd is offline   Reply With Quote
Old Thu, Jul-13-2017, 10:49:47 PM   #3
It's very common to not have many valves need adjustment, but rare for none to need it unless it was done recently I guess. I can't see putting 30k+ on and no valve needing a reshim. For example, I just did mine after 32k and I reshimmed 5. Maybe it was done recently on yours.
-NA S54-
·RE Trans Mounts · AKG poly SUB/DIFF 95a · SDW RTAB · Weighted ///M knob + UUC DSSR + delrin carrier bush · OE CSL trunk · APEX 75mm Studs · ZHP 13.7:1 P/S Rack
·Sportline 8S 18"x8.5/9.5" · MPSS 245/275 · Brembo 996 36/40 345mm CSL Textar D917 FF & 28/30 328mm CSL ATE D738 FF · CM brackets & ss/teflon lines
Old Thu, Jul-13-2017, 11:06:15 PM   #4
MFNATIK
Ok good to know guys! He said there were some that were borderline but he said didn't warrant replacing as it still had enough resistance. He said some may have been 1/1000th off which I think is just a hair and he said wasn't worth it to replace at this time. I should have taken a pic with the valve cover off since he also said things looked clean (no tarnishing or gunking).
2017 LSB F80
2002 525iT M Sport
Old Thu, Jul-13-2017, 11:20:42 PM   #5
Slowmobile
Na Na Na Na Na Na Na Na
Reputation: 0 Slowmobile is on a distinguished road
Well seeing as the shim range is 0.007 - 0.009 and 0.011 - 0.013, 0.001 out is not nothing. Did you get a printout / did he keep track of the measurements?
As another datapoint, I reshimmed I believe 5-6 at 30k.
Legen... Wait For It... ///M
Jump to top Slowmobile is offline   Reply With Quote
Old Fri, Jul-14-2017, 04:11:24 AM   #6
Dave B
M3 collector
Dave B's Avatar
Italy
I've had two cars need 0 and a few need 1-2. So it's common enough to not feel a massive urge to redo the job to be sure.
Old Fri, Jul-14-2017, 05:09:31 AM   #7
bluptgm3
By the way the shim does not wear. The valve/valve seat wears making the valve clearance too tight. Too tight and valves burn.
Old Fri, Jul-14-2017, 06:37:52 AM   #8
Too loose you mean? Any part (lobe, rocker, shim, valve stem) wearing would result in the valve protruding less far into the cylinder.
-NA S54-
Old Fri, Jul-14-2017, 06:41:49 AM   #9
Just remember you can tune the engines performance with a valve adjustment. Within the given clearance spec; Tight = torque, loose = horsepower. I prefer mine on the loose side.
Old Fri, Jul-14-2017, 02:07:21 PM   #10
EricSMG
40 something
Possible to need none but unlikely in my experience, unless, as noted, they were recently adjusted. My black car needed 18 out of 24 at 104k, indicating that it'd not been done for a while.
I'm with Brett - I always run mine as loose as I can get them whilst in spec. Given the shim sizing it's not always possible to get them the "all" loose or tight, though.
Discussing Just had inspection service, no valves needed to be re-shimmed, is this normal or OK? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
