Go Back   BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X) > M3Forum Garage > Forced Induction (F/I)
Forced Induction (F/I) Discuss the ever growing F/I options here!
Old Tue, Jul-24-2018, 11:48:37 PM   #1
Nicholas1996
Reputation: 0 Nicholas1996 is on a distinguished road
Greece
Default How much boost are stock motor guys running?
Setup is 6266 with a stock motor (rod bearings replaced) on e85. Big intercooler. AEM Infinity for management. I want to know where is too much. Max psi kits runs 18psi on e85. I am running a similar setup. Would 15 psi doable as far as stock motor holding up? Thanks
Topaz Blau
PTE 6266 on E85
AEM Infinity
Tuned by Ian @Bend Calibration
Jump to top Nicholas1996 is offline   Reply With Quote
Old Wed, Jul-25-2018, 04:40:37 PM   #2
B18c1turboedek
Reputation: 0 B18c1turboedek is on a distinguished road
Default Re: How much boost are stock motor guys running?
Yes a stock block will take 15psi. You should make 650ish on a stock block easy. I love the infinity system
Jump to top B18c1turboedek is offline   Reply With Quote
Old Wed, Jul-25-2018, 11:38:49 PM   #3
Tchleung
Reputation: 0 Tchleung is on a distinguished road
Mileage? Never split motor for head studs/head gasket?
Follow me on Instagram @tommtomm84
09 X54.4 - Parts Hauler/Daily
02 Carbon Black M3 6MT - Fun Car
462whp/311wtq @ 9.5psi(SuperFlow)
Now at 11 PSI...
4.10 / Headers / ESS VT2-550+
Jump to top Tchleung is offline   Reply With Quote
Old Thu, Jul-26-2018, 12:00:08 AM   #4
Nicholas1996
Greece
Topaz Blau
PTE 6266 on E85
AEM Infinity
Old Thu, Jul-26-2018, 12:00:45 AM   #5
Nicholas1996
Greece
108k. no headgasket work done.
Topaz Blau
PTE 6266 on E85
AEM Infinity
Old Sat, Aug-04-2018, 10:10:33 PM   #6
S54 TBO
Reputation: 0 S54 TBO is on a distinguished road
United Kingdom
WOW!! my car should be ready for mapping in the next couple of weeks and im worried about running 8psi!! pump fuel. Wish E85 was available here in the U.K
Jump to top S54 TBO is offline   Reply With Quote
Old Mon, Aug-06-2018, 03:12:40 AM   #7
Nicholas1996
Greece
What setup are you running?
Topaz Blau
PTE 6266 on E85
AEM Infinity
Old Thu, Aug-09-2018, 09:04:29 PM   #8
S54 TBO
United Kingdom
Stock compression
Aem infinity
Garret t04z ball bearing turbo
Custom equal length tubular manifold
HPF inlet manifold
Injector dynamics 1000cc injectors
Custom exhaust no cats
Car made 380whp at 7000rpm very conservative
My tuner has put a rev limit to 7k rpm, i told him to take it to 8k so should make over 400whp which I donít think is to bad on pump fuel and high milage standard engine.
Having issues at the moment with crank senor and a few other bits to sort before we can put it back on the dyno
Old Fri, Aug-10-2018, 02:11:16 AM   #9
Nicholas1996
Greece
Stock compression
Aem infinity
HPF inlet manifold
Sounds like a fun setup!
Topaz Blau
PTE 6266 on E85
AEM Infinity
Old Thu, Sep-13-2018, 12:51:45 PM   #10
e46Dan
Reputation: 0 e46Dan is on a distinguished road
Currently at 19-20 psi. 6266 on e85
Jump to top e46Dan is offline   Reply With Quote
Discussing How much boost are stock motor guys running? in the Forced Induction (F/I) Forum - Discuss the ever growing F/I options here! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
