Old Mon, Mar-25-2019, 06:44:49 PM   #221
Texaz3
Default Re: 1999 Dakar M3 Coupe Build/Restoration Journal (Long and Picture Heavy)
Originally Posted by CatchMyM3 View Post
I've contemplated which color alcantara to go with on my E46. Your first few photos look very black but the in-car photos look just right (more graphite). I think gray alcantara may be TOO gray.
Beautiful car!
Thanks.
Garage photos were really dark, black alcantara in real life is not pitch black, its more graphite, you are correct.
I have gray alcantara wheel in E46 (ZCP) and its very light. But you also need to remember that alcantara changes its shade depending on how its fibers are laying, like any suede-type material. It could be darker and lighter at the same time.
Old Fri, Apr-12-2019, 08:02:56 PM   #222
Texaz3
A little sneak peak - I've always liked how DS2 wheels look on e36 coupe, so I finally assembled a cheap set from various sources that I will completely strip, make sure its straight, and re-finish in the nearest future.
So, a question to experts - what was the original finish on these wheels? Was it more of a silver clearcoated finish, or was it more like hyper silver, finer and slightly darker than typical silver? Trying to get it re-done close to the original shade/look.
If you have a good picture of a wheel that has original finish, I'd appreciate it.
Old Fri, Apr-12-2019, 08:11:09 PM   #223
Steve M3
I like the steering wheel and can't wait to see the wheels once refinished
Old Fri, Apr-12-2019, 09:24:58 PM   #224
Gregarious7
Reputation: 0 Gregarious7 is on a distinguished road
I know Brett knows how to color match the original BMW silver exactly
Jump to top Gregarious7 is offline   Reply With Quote
Old Sat, Apr-13-2019, 04:05:08 PM   #225
Texaz3
Thanks Steve!
I'm sure he does - Brett, wanna chime in?
To be honest, I will just get close to what I think it should be, and that's fine - not looking for 100% color match. I think the fronts were not re-done, and I could see what color they should be - just wanted to confirm. Its easier with silver than for example, with shadow chrome on my M5 or M Coupe.
Old Sat, Apr-13-2019, 04:45:40 PM   #226
Gregarious7
Check his post history he's written about it a few times.
Old Sat, Apr-13-2019, 08:28:51 PM   #227
Texaz3
Thanks I'll take a look.
Old Tue, Apr-16-2019, 07:20:54 PM   #228
Contracheatcode
Reputation: 0 Contracheatcode is on a distinguished road
Doubt I do the shift boot, I like it in leather.
Yellow stripe - it was an attempt to make the interior a bit more lively, and dakar stripe was one way to do it. If I were to do this again, I'd probably skip the stripe, though I'm ok with it for now.
The strip and wheel look great IMO.
Jump to top Contracheatcode is offline   Reply With Quote
Old Wed, Apr-17-2019, 03:08:29 PM   #229
Texaz3
I like it better now that I had some time behind the wheel and gotten used to it. Its great. Alcantara for some reason makes the car feel different. I know its only a perception, but I'm good with that.
Old Fri, Jun-07-2019, 08:45:34 PM   #230
Texaz3
Last week I took the car on a little 150-mile journey to stretch its legs, and on my way back home, I got a check engine light, of course!
Checked it out with my OBD scanner, and it was upstream oxygen sensor on bank 2.
Decided it was time to replace both anyway (129K) I ordered couple from Amazon, and they showed up two days later:
The offender was covered in some oil fluid – probably oil – not sure if this was the culprit of the malfunction:
Bank one sensor looked just fine:
Getting the old ones out was relatively easy, though I did spray some PB blaster and used crows foot socket to get them off. Lots of residue on them:
New ones came nicely packaged:
With anti-seize already applied to the threads – very thoughtful:
Both went in without a problem, torqued to spec:
Cable management:
Hopefully the new ones will last just as long as the original ones (though, I don’t know if these are truly original).
Discussing 1999 Dakar M3 Coupe Build/Restoration Journal (Long and Picture Heavy) in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
