Old Thu, Jun-21-2012, 01:14:08 AM   #1
ventura_328Ci
Reputation: 0 ventura_328Ci is on a distinguished road
Default Running a 275/35/19 Tire on a 19x11 Rear Wheel?
Since the general consensus is that a 295/30/19 Yokohama AD08 will not fit on my 19x11 ET25 rear wheels without rubbing, and since the AD08 is not produced in a 285/30/19 (I would prefer to avoid the stretch of a 275/30/19), my question is:
Would it make more sense to run a 275/35/19 tire instead of a 275/30/19 tire if I would like to achieve as little stretch as possible, but still not rub?
Would running a 35 series sidewall screw up the overall diameter of 26"? I do not think so, based on this logic: a 275/35/19 is probably close to how a 285/30/19 tire would fit, thus the taller sidewall is irrelevant due to the slight stretch on a wider rim. Is this true, and should I be able to run a 275/35/19 to achieve less stretch and closer overall diameter of 26"?
WTB: VarrsToen 1.1.2 LM Reps 19x9.5 +34 and 19x10.5 +22 in HYPER BLACK
2003.5 LSB/black M3 - 6MT - No Sunroof
Engine: Carbonio carbon fiber intake, Evosport power pulleys
Exhaust: SMURFM headers w/ Jet Hot ceramic coating, SuperSprint S-Pipes, SuperSprint X-Pipe (non-resonated), custom muffler delete w/ Magnaflow resonator
Suspension: Bilstein PSS9 coilovers
Brakes: GSG Motorsports cross drilled/slotted black rotors, StopTech Street Performance brake pads
Wheels: VarrsToen 1.1.2 (19x9.5 ET20, 19x11 ET25) - Yokohama Advan AD08 (245/35/19 F, 275/30/19 R)
Exterior: Seibon CSL trunk (unpainted carbon fiber), matte black kidney grilles & side gills, custom smoked OEM LED taillights, smoked corner lights & sidemarkers
Interior: ZHP shift knob
Factory Options: Navi, full power heated leather seats w/ lumbar support
Jump to top ventura_328Ci is offline   Reply With Quote
Old Thu, Jun-21-2012, 01:22:45 AM   #2
M3ANMACHINE
HellaFunctional
M3ANMACHINE's Avatar
Reputation: 0 M3ANMACHINE is on a distinguished road
Run 275/30, or choose a different tire.
E90 ///M3 - AW - 6MT - Volk - Akrapovic - Dinan
Originally Posted by F1 Game 2013 View Post
iHatePosers says, "I was having a sh!t the past few weeks..." -Kimi
Jump to top M3ANMACHINE is offline   Reply With Quote
Old Thu, Jun-21-2012, 01:28:41 AM   #3
Dan4hockey99
oem csl or die
Dan4hockey99's Avatar
Reputation: 0 Dan4hockey99 is on a distinguished road
Ukraine
Default Re: Running a 275/35/19 Tire on a 19x11 Rear Wheel?
May I ask why you are running a 11in wheel?
2004 Mystic 6MT
///M3AN One Headers | Agency Power V2 | Evolve-R | Blitz Technospeed Z1 | BC Racing Coilovers | Macht Schnell | CSL
Jump to top Dan4hockey99 is online now   Reply With Quote
Old Thu, Jun-21-2012, 03:01:48 AM   #4
OneFastSicilian
OneFastSicilian's Avatar
Reputation: 0 OneFastSicilian is on a distinguished road
Italy
it fits perfect, slight stretch but looks great, saw it done the other day at a wheel shop.
01 AW/IR <3 - SOLD
03.5IR/BLack - Current
www.nextgenerationny.com
Jump to top OneFastSicilian is offline   Reply With Quote
Old Thu, Jun-21-2012, 08:46:28 PM   #5
ventura_328Ci
Care to explain why?
Wanted 10.5", but the wheel is now discontinued, so I was forced to go with the 19x11. Plenty of E46 M3's run 11" rears; some 12".
Which one fits perfect - the 275/30 or 275/35?
Old Thu, Jun-21-2012, 08:51:33 PM   #6
cosmos///m3
MMMmmmmmm....
cosmos///m3's Avatar
Reputation: 0 cosmos///m3 is on a distinguished road
Go with 275/30. That's what I'm running on my Meisters, slight stretch not awful... Depending on ride height and camber and if fenders are rolled you may still have a slight rub. I do on larger bumps, but my ride height is low...
2005 ZCP Schwarz II/Imolarot 6spd ///M3
Originally Posted by hum3a
man i need a fu<kin wife to run errands for me......fu<k grocery shopping
Jump to top cosmos///m3 is offline   Reply With Quote
Old Thu, Jun-21-2012, 08:52:02 PM   #7
mrgicm
mrgicm's Avatar
Reputation: 0 mrgicm is on a distinguished road
Croatia
I have original csl wheels and run 275/35/19 michelin sport cup and with 10mm spacer I had rubing so go with 30 if possible
Jump to top mrgicm is offline   Reply With Quote
Old Tue, Jul-03-2012, 12:05:24 AM   #8
ventura_328Ci
Seems like no one has ever really put any thought into this topic. Any other input?
Those wheels are only 19x9.5 though. Image a wheel with an extra 1.5" width; the taller sidewall would be stretched to fit how a 275/30/19 would fit on your smaller rim. At least that would make sense to me.
Old Tue, Jul-03-2012, 01:02:52 AM   #9
DealsWheels
Banned
Reputation: 0 DealsWheels is on a distinguished road
Not a fair comparison with DOT R compound tires. A 275/35/19 pilot cup is quite a bit wider than a comparably-sized street tire not to mention pilot cups have very square sidewalls.
You guys keep forgetting, not all 275s are 275s, not all 305s are 305s since that number is merely the tread with, not total width.
Jump to top DealsWheels is offline   Reply With Quote
Discussing Running a 275/35/19 Tire on a 19x11 Rear Wheel? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
