Old Tue, Jan-03-2017, 10:08:44 AM   #21
kyrix1st
kyrix1st's Avatar
Japan
Default Re: FX racing stage 2/stage 3 clutch kit
OMG your clutch pedal! Fix that
LOL sorry I forgot to put grease on pedal bushing and now it squeaks like you know what. Will silicon spray suffice?
By the way, is this the same rattle you got when you installed yours? I would love to compare with E46 M3's SMF setting.
WTB: Carbon airbox
'98 M3 evo (S50B32)
Rear: Stock-Endless CC-RG //
Recaro SPG, SR-2//
Sparco 35cm steering//
Hella headlights//
Old Tue, Jan-03-2017, 03:41:10 PM   #22
Yes, same rattle. It will get worse.
No, you need to buy a new pedal and bushings. They are wear items. If you did that, pull the pedal back down and use a lithium grease on the shaft/bushings and the pins for the slave and spring. I've never heard an E36 pedal that bad...
Old Fri, Jan-06-2017, 02:57:50 PM   #23
kyrix1st
kyrix1st's Avatar
Japan
No more squeaking noise from the pedal after I applied abundance of amber lithium grease. Will upload video just for you tom.
WTB: Carbon airbox
'98 M3 evo (S50B32)
Recaro SPG, SR-2//
Hella headlights//
Old Fri, Jan-06-2017, 08:25:18 PM   #24
tsmith25
Reputation: 0 tsmith25 is on a distinguished road
Braymond, mine is way worse. It's more of a high pitch honk than a squeek. You consider the actual pedal to be a wear item, not just the bushings?
Jump to top tsmith25 is offline   Reply With Quote
Old Fri, Jan-06-2017, 10:03:24 PM   #25
It IS a wear item, not an opinion. The holes oval out over time so bushings will not fix it.
New pedal + Rogue Engineering bushings is ideal. Replace the clutch master and slave along with clutch kit, guide tube, fork, and pivot pin. Refreshed systems done thoroughly make the E36 very enjoyable again!
Old Wed, Feb-15-2017, 05:27:45 PM   #26
kyrix1st
kyrix1st's Avatar
Japan
Quick update on 2,000km:
1. Clutch actually has less rattling now, and it engages very smoothly.
2. Now that the clutch plate is completely engaged with the flywheel, I can really enjoy the power at the top of the rpm.
3. Can rev match like a motorcycle lol.
WTB: Carbon airbox
'98 M3 evo (S50B32)
Recaro SPG, SR-2//
Hella headlights//
clutch, e36 m3, flywheel kit, fx racing
Discussing FX racing stage 2/stage 3 clutch kit in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
