Old Mon, Dec-12-2016, 04:39:50 PM   #1
kyrix1st
kyrix1st's Avatar
Japan
Default FX racing stage 2/stage 3 clutch kit
Trying to buy clutch+flywheel kit from gripforce. What do you guys recommend? Both are sprung discs so I suppose the rattle isn't as bad as the non sprung + single mass flywheel setup.
I also would like to know the difference between Chromoly flywheel and aluminum flywheel besides the weight.
WTB: Carbon airbox
'98 M3 evo (S50B32)
Rear: Stock-Endless CC-RG //
Recaro SPG, SR-2//
Sparco 35cm steering//
Hella headlights//
Old Mon, Dec-12-2016, 05:50:50 PM   #2
Default Re: FX racing stage 2/stage 3 clutch kit
You will not like the lightweight flywheel in the Getrag 420G gearbox. The gear chatter is bad. I do not care what you read, who says otherwise or what unicorn piss mix of oil you use, it will rattle with this setup and it will be loud. You can also expect more driveline clunking on poorly timed shifts. It is possible higher quality LTW flywheel setups may do better, but I doubt it (having had them in the past).
I have the Stage 3 sprung hub with the steel flywheel and 13psi of boost. After 1k miles it is being replaced with an OEM dual mass flywheel and clutch kit. I can't imagine how terrible it would be with the lighter aluminum flywheel!
Old Mon, Dec-12-2016, 06:19:40 PM   #3
kyrix1st
kyrix1st's Avatar
Japan
I already have some gear rattle due to the clutch kit (probably OS giken) in my car. I was thinking aluminum/chromoly flywheel+ E34 M5 or gripforce clutch kit for the best all round performance. Your response makes it all so intriguing that I can't wait to try it out!
WTB: Carbon airbox
'98 M3 evo (S50B32)
Recaro SPG, SR-2//
Hella headlights//
Old Tue, Dec-13-2016, 01:19:13 AM   #4
NolliM3
NolliM3's Avatar
Braymond141, this is the one I am thinking of getting as I am planning force induction...what's your feedback?
Old Wed, Dec-14-2016, 09:51:12 AM   #5
kyrix1st
kyrix1st's Avatar
Japan
Just ordered ECS performance flywheel kit. Will go in detail regarding the fitment on euro 'e 6-speed.
WTB: Carbon airbox
'98 M3 evo (S50B32)
Recaro SPG, SR-2//
Hella headlights//
Old Wed, Dec-14-2016, 04:58:29 PM   #6
Originally Posted by NolliM3 View Post
Braymond141, this is the one I am thinking of getting as I am planning force induction...what's your feedback? FX STAGE 2 CLUTCH KIT 1987-88 BMW M6 3.5L E24 S38 87-93 M5 E28 E34 3.5L 3.6L | eBay
Since that is a full face clutch kit that I assume is getting mounted to your stock dual mass... you should like it. I've only ever ran their Stage 3 + 16lb flywheel in my 5spd and then purchased the same Stage 3 in 6speed fitment. The kits are very good for the money!
Old Wed, Dec-14-2016, 09:47:41 PM   #7
NolliM3
NolliM3's Avatar
Awesome...yes, mounting to stock dual mass.
Old Fri, Dec-23-2016, 03:34:11 PM   #8
kyrix1st
kyrix1st's Avatar
Japan
Update: I want to inform that Ecs kit (E34 M5+ LTW flywheel) does fit euro M3 without an issue. I will write a comprehensive DIY when I have time.
WTB: Carbon airbox
'98 M3 evo (S50B32)
Recaro SPG, SR-2//
Hella headlights//
Old Tue, Dec-27-2016, 05:42:27 PM   #9
kyrix1st
kyrix1st's Avatar
Japan
You are right. It does make quite a bit of noise when clutch is warm. Especially when accelersting from stop. I can't imagine how I would live with unsprung hub (mines E34 setup)
WTB: Carbon airbox
'98 M3 evo (S50B32)
Recaro SPG, SR-2//
Hella headlights//
Old Tue, Dec-27-2016, 06:17:34 PM   #10
It will probably get worse!
Oh well, enjoy it best you can
clutch, e36 m3, flywheel kit, fx racing
Discussing FX racing stage 2/stage 3 clutch kit in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
