Old Fri, Dec-18-2009, 05:56:20 PM   #1
24601
what goes around comes around...pay it forward
24601's Avatar
Reputation: 0 24601 is on a distinguished road
Default smg f/i folks who have done clutch (and flywheel) upgrade, questions and impressions
hey, folks,
for those who have smg and f/i and did a clutch (and flywheel) upgrade, i have some questions:
1. obviously, first question is which clutch and flywheel? i realize that some upgraded clutch and got the oem flywheel.
2. at how many miles (approximate) did you do the upgrade?
3. what is your mileage (approximate) currently?
4. if there is significant weight savings when compared to stock clutch and flywheel assembly, what is the amount?
5. does your car stutter or have a slight shudder during a slow start in 1st gear from a complete stop or with a slow rolling start in 2nd gear?
6. if you have chatter, can you do your best and quantify it?
7. if your setup is not a direct swap for the stock clutch and flywheel assembly, what else was needed?
8. if you are not happy with your setup, what do you wish you had gone with now that hindsight is 20/20?
9. (assuming you have had f/i for a reasonable period of time before upgrading) when on stock clutch, did you experience anything a little off when going WOT in s5 or s6 and upshifting?
for example, when at WOT or even close in s5 or s6 and you shift up, the rpms will naturally drop during the shift. but does it seem once rpm's hit their lowest point that there is a momentary pause once upper gear is engaged and then the normal rpm rise with WOT is delayed?
or same scenario with WOT or close, s5 or s6 mode, you are shifting up and experience something like this (all this with constant throttle at or near WOT):
rpms fall, rpm is held for a split second, drops a little then quickly
rises up toward redline. so if point A is where you upshift and B is
where rpms fall,C is the lowest point of falling after "pausing" at B
and D is redline. the needle goes from A to B to C to D. where the
order in increasing rpms is C---B---------A-D.
if you did experience something strange when upshifting at WOT with stock clutch, do you continue to experience it with your new clutch and flywheel?
10. final question: what f/i setup do you have? for convenience, also add whp/wtq.
i know that is a lot. thanks in advance.
'06 M3 | '07 A3 2.0T S-Line | '17 GLC43 (hers)
Jump to top 24601 is offline   Reply With Quote
Old Fri, Dec-18-2009, 06:36:56 PM   #2
GJGM3
Porsche 997
GJGM3's Avatar
Reputation: 0 GJGM3 is on a distinguished road
Subscribed.
I have a 6MT but interested in what people have.
Porsche Carrera S - GJGM3 Replacement
Miss the M3 ASA Boost
But truly, "Porsche, There is No Substitute"
Jump to top GJGM3 is offline   Reply With Quote
Old Fri, Dec-18-2009, 10:56:11 PM   #3
MSpired
Reputation: 0 MSpired is on a distinguished road
HPF clutch and OEM flywheel, watch, you'll see, it's your best option.
Jump to top MSpired is offline   Reply With Quote
Old Fri, Dec-18-2009, 11:47:26 PM   #4
NY Z Pilot
NY Z Pilot's Avatar
Reputation: 0 NY Z Pilot is on a distinguished road
I have that same problem, BUT I just had the SMG pump replaced. It wasnt doing that before.
Jump to top NY Z Pilot is offline   Reply With Quote
Old Sat, Dec-19-2009, 12:18:37 AM   #5
24601
24601's Avatar
Originally Posted by GJGM3 View Post
Subscribed.
#5 is what is experienced by a couple of folks i know how have hpf clutch and oem flywheel.
which hpf clutch do you have?
hmmmmm, that is weird. and which problem (a couple listed by me)?
thanks.
Old Sat, Dec-19-2009, 12:39:08 AM   #6
NY Z Pilot
NY Z Pilot's Avatar
It feels like the clutch is slipping.
Old Sun, Dec-20-2009, 12:30:36 AM   #7
ISPEEDM3
Got Boost?
ISPEEDM3's Avatar
Reputation: 0 ISPEEDM3 is on a distinguished road
1. obviously, first question is which clutch and flywheel? HPF CLUTCH, OEM FLY
2. at how many miles (approximate) did you do the upgrade? 59K
3. what is your mileage (approximate) currently? 66K
4. if there is significant weight savings when compared to stock clutch and flywheel assembly, what is the amount? NOT SURE
5. does your car stutter or have a slight shudder during a slow start in 1st gear from a complete stop or with a slow rolling start in 2nd gear? SURE DOES
6. if you have chatter, can you do your best and quantify it? IT FEELS LIKE WHEN 1ST LEARNING HOW TO DRIVE A STICK, AND YOU LAY OFF THE CLUTCH TO FAST AND THERE IS A JUDDER, UP UNTIL YOU PRESS CLUTCH BACK IN
7. if your setup is not a direct swap for the stock clutch and flywheel assembly, what else was needed? NOTHING OTHER THAN NEW CLUTCH
8. if you are not happy with your setup, what do you wish you had gone with now that hindsight is 20/20? VERY HAPPY
9. (assuming you have had f/i for a reasonable period of time before upgrading) when on stock clutch, did you experience anything a little off when going WOT in s5 or s6 and upshifting? IT WOULDVE BEEN DUMB OF ME NOT TO GET AN UPGRADED CLUTCH WITH NEW FOUND POWER
sorry for caps, i was just trying to differ the question and answer
[CENTER]
Jump to top ISPEEDM3 is offline   Reply With Quote
Old Thu, Jun-17-2010, 08:56:56 PM   #8
24601
24601's Avatar
ISPEEDM3, thanks for the detailed info. sig pic rocks
bump for anyone else to give more feedback.
just curious to see if anyone has installed re's "f/i specific" clutch kit.
thanks!
Old Thu, Jun-17-2010, 09:12:01 PM   #9
battam3
Reputation: 0 battam3 is on a distinguished road
Hpf stg 2 clutch. Slight chatter in low speed in 1st. I can take for ride so you can seefor yourself.
Jump to top battam3 is offline   Reply With Quote
Old Thu, Jun-17-2010, 09:43:36 PM   #10
24601
24601's Avatar
cool. when i get a chance, that would be good. thanks.
clutch, f or i, flywheel, folks, impressions, questions, smg, upgrade
Discussing smg f/i folks who have done clutch (and flywheel) upgrade, questions and impressions in the Forced Induction (F/I) Forum - Discuss the ever growing F/I options here! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
