Old Thu, May-08-2014, 03:47:14 AM   #31
kokgo20
kokgo20's Avatar
Default Re: SMG Clutch
160K miles and when I took it out it was in perfect condition
Build thread
Old Thu, May-08-2014, 03:53:43 AM   #32
RedM3/4
If you're going to replace it anyway, please do us a favor and drive in S5 for a few days and do several hard starts. Not necessarily SMG launches, but very hard take-offs, then let us know if behavior changes any. This is just a hunch, but worth trying.
ADS
Originally Posted by Zabalzae View Post
Mine has 124k reset via inpa and still shudder. Replaced along with flywheel and compression springs.
Old Thu, May-08-2014, 04:49:53 AM   #33
mddicted
Reputation: 0 mddicted is on a distinguished road
I just replaced my clutch while the tranny was out for replacement of the retention springs and the gear position sensor. After 10 track days in the past year the clutch disc looked decent but the throw out bearing was near failure. Since the car is progressing towards a dedicated track car I went with the VAC Kevlar Clutch Kit. It required a 600 mile break in but the positive engagement of this clutch rivals the SMG III. (3rd gear chirps on brand new Mich Pilot Sports) Non of the springs were broken but the gear position sensor cured all of the missed shifts I was experiencing.
2005 Silver Grey Metallic / Imola
Competition Pkg
Sunroof Delete
Manual Seats
V1
Borla X Pipe
Dinan Section 3
Dinan 3.91
Dinan Stage 3 Suspension
Fluidyne Aluminum Radiator
K&N Filter Insert
Stainless Steel Brake Lines
PFC Direct Drive 2 piece rotors
PFC Z-rated/PFC 08's
Michelin Pilot SS 19" staggered/Nitto NT01's 18" Sq
Jump to top mddicted is offline   Reply With Quote
clutch, smg
Discussing SMG Clutch in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
