Old Wed, Jul-23-2008, 05:21:00 AM   #1
markjm3
markjm3's Avatar
Reputation: 0 markjm3 is on a distinguished road
Default Fan Clutch DIY
Here is how I changed the fan clutch on my e46. I had searched but did not find anything for e46 M's so here is how I did it. It is actually pretty easy and will take less than 45 mins. Let the car cool down before you start working on it.
Tools Req:
1. 32mm wrench (I spent more time driving around looking for this than it took to change the clutch.) Go to Sears and save yourself some time. Better yet, check your local automotive retailer and see if you can loan one. I couldn't find one as all the retailers in my area only carried the 36mm for Fords.
2. Torx size 25
3. Something to hold fan clutch pulley- I went to Autozone to borrow one (the one for Ford's can be used.)
4. Something to jack up your car- Rhino ramps, lift, tire jack, etc.
5. 8 & 9 mm sockets.
1. Raise the front end of the car. I pulled the fan clutch/fan blade assembly out form underneath the car. It took about 10 mins of looking from the top down to realize there is more room below the car to get the assembly out. You also don't need to remove any cooling system components this way, too. Take the 32mm wrench, pulley holder and loosen the nut. Loosen the nut until it is almost off the water pump shaft. Now go underneath the car.
2. Remove skid plate panel. If you have done an oil change or CDV removal, its the same one.
3. Remove 2 torx screws that hold the oil cooler to the radiator. These are located on either side of the plastic housing that holds the oil cooler in place. With the screws removed, the oil cooler will not be completely detached, it will hang from the driver's side. It has a tab on the oil cooler shroud that helps to hold it in place. Take the left side of the oil cooler and slide it towards the rear of the car and it will come off. There is no need to disconnect the tubes- just move it to the side.
4. Remove 2 more torx screws that hold the plastic shroud to the radiator. These are located at the left and right bottom corners of the shroud. The shroud will not fall on you as there are two more screws at the top of the car- do not remove these. Also remove the catch that is located in the middle bottom of the radiator- just rotate it 90 degrees and pull it out.
5. Loosen the clutch/blade assembly completely. Push the bottom of the shroud towards the rear of the car and squeeze the assembly between the shroud and radiator. Be careful not to bend the cooling fins on the radiator with the fan blades.
6. Replace old fan clutch with the new one and assemble in reverse.
six sppeeeeeeddd
Jump to top markjm3 is offline   Reply With Quote
Old Wed, Jul-23-2008, 05:22:36 AM   #2
markjm3
markjm3's Avatar
More pics...
six sppeeeeeeddd
Old Thu, Jul-24-2008, 01:19:12 PM   #3
Rat Fink
Seven years of college, down the drain . . . .
Rat Fink's Avatar
Reputation: 0 Rat Fink is on a distinguished road
Originally Posted by markjm3 View Post
Tools Req:
You can also check out a well supplied bicycle shop. Those that carry tools should have a 32mm headset spanner/wrench. I used my Campagnolo headset wrench when I did my UDP's - worked great
Jump to top Rat Fink is offline   Reply With Quote
Old Tue, Jul-29-2008, 09:00:03 PM   #4
bmw_mthr33
bmw_mthr33's Avatar
Reputation: 0 bmw_mthr33 is on a distinguished road
this was great info! thanks again...
Jump to top bmw_mthr33 is offline   Reply With Quote
Old Tue, Jul-07-2009, 09:09:46 AM   #5
indoctrin8ed
Reputation: 0 indoctrin8ed is on a distinguished road
I'm so glad I found this forum. I just did mine tonight, and thankfully inspired by these posts.
I had to make a pulley holder. No screwdriver would do. I bought a $3 piece of 3/16th thick strip (about 1" wide x 18" long) of steel from Home Depot and drilled one 1/2" hole near the corner, which could set over a pully screw. This did the trick. There was at least 30 lbs of torque on that nut.
My fan exploded for no known reason. It was causing a vibration that was horrible and I was panicing thinking it was something bad like a main bearing or a vanos issue or some god-knows-what expensive problem. 82k miles. I was so happy to discover that the fan had blown up. 5 of the 11 blades were all but gone and no damage to the inside, 4 were still found in the slash guard below.
I hope was nothing more than an old brittle fan, but the cause will reveal itself it it's something more - like a bad water pump bearing or a clutch that locks up and puts the full 8500 RPM of force on the fan. Knock on wood.
Thanks for the posts...
Jump to top indoctrin8ed is offline   Reply With Quote
Old Tue, Jul-07-2009, 09:40:06 PM   #6
Tonester
Reputation: 0 Tonester is an unknown quantity at this point
Viet Nam
I would check the amount of play you have in the water pump, sounds like it might be going out.
Jump to top Tonester is offline   Reply With Quote
Old Thu, Jul-09-2009, 02:16:33 PM   #7
alfredocamacho
Reputation: 0 alfredocamacho is on a distinguished road
Puerto Rico
Do you remove the nut to the passenger side or driver side?
Jump to top alfredocamacho is offline   Reply With Quote
Old Wed, Sep-23-2009, 03:20:54 AM   #8
bzsbimmer
Reputation: 0 bzsbimmer is on a distinguished road
South Korea
It's a reverse thread so lefty tighty, righty loosey
If under the car, to loosen it's CCW or pull toward the driver
Helping the economy one mod at a time
Alpine E90 M3
Jump to top bzsbimmer is offline   Reply With Quote
Old Thu, Sep-24-2009, 04:57:24 PM   #9
bzsbimmer
South Korea
Just did mine last night and although I busted up my elbow skin (car wanted blood) it went without a huge hitch.
Once under the car it was easy to spot the bolts that needed to be removed and it went really easy.
The fan isn't as fragile as everyone makes it out to be. I used a new fan clutch and fan from AutohausAZ.com and saved quite a bit.
This DIY was a godsend!!!
Alpine E90 M3
Old Wed, Aug-10-2011, 01:21:37 AM   #10
Don Draper
Flappy Paddle Flapper
Don Draper's Avatar
Reputation: 0 Don Draper is on a distinguished road
Jamaica
Default Re: Fan Clutch DIY
Old thread is old...but I wanted to say thanks for the DIY. Just used it, and going in from under probably saved me some trouble. Thanks!
AKA LordDRIFT (BF.c)
I used to Love to Flap My Paddle
Jump to top Don Draper is offline   Reply With Quote
clutch, diy, fan
Stuck clutch fan? Clutch fan brushing up against radiator shroud? Overheat? YiKes! NYM3Jack E36 M3 (1992-1999) 6 Sat, Jun-28-2008 05:28:37 AM
Bad fan clutch and/or aux fan switch ? bartolome1 E36 M3 (1992-1999) 3 Fri, Jul-20-2007 11:34:30 PM
Need DIY on How to Replace Fan Clutch RealPolItiK E46 M3 (2001-2006) 6 Mon, Jun-18-2007 04:31:00 AM
Fan delete DIY JasonSTL739 E46 M3 (2001-2006) 4 Sun, Apr-23-2006 07:26:19 AM
Is it possible to take off the fan clutch and not install an electric fan? UA///M3 E46 M3 (2001-2006) 9 Thu, Nov-03-2005 01:21:38 PM
Discussing Fan Clutch DIY in the Faults, Fixes and DIY Forum - Please share your experience and knowledge with other members by contributing your own DIY, or by helping another member find the elusive fix! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
