Old Wed, Oct-09-2019, 06:47:47 AM   #21
Default Re: Best OEM+ Cooling Refresh Kit
I would avoid silicone hoses just because they are ugly AF. Also, OEM hoses are not a huge failure point and silicone can be difficult to secure (they slide off).
Always use factory clamps or similar style. Typical parts store clamps chew up the hoses.
Old Wed, Oct-09-2019, 07:59:42 AM   #22
M3AN
321 fun...
M3AN's Avatar
Reputation: 0 M3AN is on a distinguished road
New Zealand
I'm not so sure...
You can get silicon hoses in OEM-look mat black... they're expensive but lifetime so I think it's a personal decision verses a do/don't one. https://roosemotorsport.co.uk/silicone-hose-kits
The OEM Oetinger clamps are an unnecessarily royal PITA. Since you're putting them on manually and you're not in a rush you don't need their pre-set clamp pressure "feature" so you're inconveniencing yourself for no benefit. And you need a special tool. Use stainless steel worm drive clamps which can be reused, will last a lifetime and cost less.
/// E36 M3 Evo Coupe / Estoril Blue / Lotus White Individual
/// S50B32 / 6MT / Slick Top / Alu Doors / Z3 Rack / Simota / Remus / Bilstein / Eibach / BBS / Goodyear / Rally Road / 3.62 CWP (TBI)
Jump to top M3AN is offline   Reply With Quote
Old Wed, Oct-09-2019, 08:38:29 AM   #23
Originally Posted by M3AN View Post
I'm not so sure...
Oetiker clamps are great. I use them all of the time. However, only two Oetiker clamps are used on the US M3 cooling system, and none of what we are discussing mentions replacing them with the same crimp style.
Non-perforated worm gear clamps are great. Perforated are ****ing trash and will ruin your hoses.
Silicone hose kits rarely come in an OE look here. Everything is colored or glossy
Good clamps
Garbage clamps
Old Wed, Oct-09-2019, 08:46:39 AM   #24
M3AN
321 fun...
M3AN's Avatar
New Zealand
When you say "Always use factory clamps or similar style" the clear implication is that you mean the same type of clamp, that's exactly what you were discussing.
This is certainly true although I didn't even think to make it explicit that you need to use soft hose clamps on soft hoses.
Check the link I posted (edit: they ship to the US).
Discussing Best OEM+ Cooling Refresh Kit in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
