Old Wed, Aug-17-2016, 06:51:53 PM   #111
EricSMG
40 something
Default Re: Best Daily Driver Suspension?
In your case I'd seriously consider the Eibach coils. Probably double your investment but I think it's safe one, everyone seems to love these coils.
And let's be honest - who does want the ability to fine-tune their ride height?
Old Wed, Aug-17-2016, 06:53:03 PM   #112
Originally Posted by SunD3v1L View Post
So obviously with your previous post you have some damn experience with them - what, if any - have you compared them with on the e46? You mentioned you haven't tried Billys... And you're on Ohlins coils...
(In terms of ride quality / handling - obviously that's quite the testament for durability / warranty / etc)
Erms, a fair variety.... PSS9s, PSS10s, KWs of all Vs, Ohlins, Motons, JRZs, ASTs, a couple of the chinese crap setups, stock, Teins, TCKs, stock bilsteins, GCs. I used to install suspensions pretty frequently on the weekends, so I've driven a fair variety.
I meant I hadn't tried the FCM bilsteins, which I find very intriguing.
Old Wed, Aug-17-2016, 06:54:41 PM   #113
SunD3v1L
hi
SunD3v1L's Avatar
Reputation: 0 SunD3v1L is on a distinguished road
Italy
Default Best Daily Driver Suspension?
God dammit. Back to square one.
I'm quite happy with the height of my Eibach springs... and height alone won't get me into 'em. I'd be more convinced if the ride quality & handling is better.
What a crap shoot. Maybe I'll drive out to Corona (to their facility) and see if I they have an e46 around I can sit in.....
Jump to top SunD3v1L is offline   Reply With Quote
Old Wed, Aug-17-2016, 06:56:40 PM   #114
SunD3v1L
hi
SunD3v1L's Avatar
Italy
DAMN. And Koni Yellows come out on top as your go to for a DD set up?
Old Wed, Aug-17-2016, 07:14:38 PM   #115
Well, I'd immediately rule out Ohlin/Moton/JRZ, since they require rebuilds too frequently for a daily setup.
ASTs seem to like to fail and develop noises.
TCKs are awesome for a daily setup (with reasonable spring rates), but require camber plates that increase NHV and increase cost. Probably the best DD/track setup for the car, imo.
GCs are equal or worse than the TCKs, so just makes sense to go TCK if you're going that route
Stock bilsteins don't work well with lowering springs unless combined with bump travel increasing camber plates, but they are a solid setup if you're down for that. They don't ride as well as the Konis can, but they handle better. They certainly aren't happy with any sort of significant lowering.
PSS9s and PSS10s are a great setup if you run them near stock ride height. But, nobody does and they're not great once lowered.
Teins are crap.
KW's (V1, V2, V3) don't handle very well, clubsports are too uncomfortable to DD
Chinese crap setups don't ride or handle well, and will break early and often with DD mileage.
Haven't had any seat time yet with the Eibach coilovers, so can't comment on them... but I've only heard universally positive things, so my expectations are high.
I really want to try the FCM Bilsteins, with Dinan springs. Eric really has me thinking they're the best DD setup for the car.
Old Wed, Aug-17-2016, 07:30:14 PM   #116
ctres
ctres's Avatar
Reputation: 0 ctres is on a distinguished road
So are you planning on switching to the Eibach Pro Street on your E46? What's the reason for the switch from the ohlins? Rebuild interval?
Jump to top ctres is online now   Reply With Quote
Old Wed, Aug-17-2016, 07:30:22 PM   #117
SunD3v1L
hi
SunD3v1L's Avatar
Italy
Thanks Ian.
I'll check out FCM Bilsteins & wait for more info on Eibach coils... But heavily swayed towards the Koni yellows.
Old Wed, Aug-17-2016, 08:00:18 PM   #118
icecream
Registered Apples
icecream's Avatar
No love for the B4's huh?
Old Wed, Aug-17-2016, 08:59:25 PM   #119
WytLytnyn
WytLytnyn's Avatar
Reputation: 0 WytLytnyn is on a distinguished road
I've had the Dinan/Koni setup for a few years and does a great job of soaking up the potholes and metal plates here in Atlanta (let's face it sometimes you just have no choice and have to hit them....OUCH!). Performs very well in the mountain twisties here in GA as well. Couldn't be happier.
My suggestion is to find other local E46 M3 owners in your local forum and ask them to ride/drive their cars to form your own opinion of what will work for you. You may find that some of the suggestions you've heard here may not be what you're looking for. I rode/drove about 6 different setups before buying the suspension I have.
Good luck.
Current: 2005 Titaniumsilber M3 Coupe
Dinan CAI/Exhaust/Stage 3 suspension, spherical bearings in rear trailing arms
UUC EVO 3 + DSSR
Look Ma! No sunroof! "Wood" trim! Unpowered Cloth Seats! NAV!
Michelin Pilot Super Sports on OEM 19's
"If everything is under control, you are just not driving fast enough!" - Sir Stirling Moss
Jump to top WytLytnyn is offline   Reply With Quote
Old Wed, Aug-17-2016, 09:14:25 PM   #120
EricSMG
40 something
Yes, Koni/Dinan is quite smooth^^.
FWIW, I'm running the FCMs with OE springs currently. Further, I'd only recommend them to the true connoisseur of suspension.
Discussing Best Daily Driver Suspension? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
