Go Back   BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X) > M3Forum Marketplace > M3Forum Sponsor Announcements and Specials
M3Forum Sponsor Announcements and Specials Browse this forum to locate any specials our board sponsors may be holding.
Old Thu, Apr-20-2017, 06:15:40 AM   #11
AndresC
AndresC's Avatar
Reputation: 0 AndresC is on a distinguished road
Default Re: ► APEX | Redesigned & Re-engineered BMW Wheel Spacers
Links for "Shop » 3mm | 5mm | 12mm | 15mm | 18mm " are old/misdirected.
20mm link works though
I'll be ordering some 12mm soon.
2003.5 E46M 6MT
Jump to top AndresC is offline   Reply With Quote
Old Fri, May-05-2017, 04:15:11 PM   #12
Good
@GOOD_M3
Good's Avatar
Reputation: 0 Good is on a distinguished road
Any chance we'll see a set of steel spacers any time soon?
EXTERIORJCSL 1X1 DIFFUSER | VÖRSTEINER CSL BUMPER
PREVENTATIVE ▌VANOS BEISAN LOCKDOWN: UPPER GUIDE CHAIN | SOLENOID COIL PACK | OIL PUMP DISK | SMG PUMP/MOTOR RELOCATED
EXHAUSTSUPERSPRINT EXHAUST ~ OVERSIZED STEPPED V1 HEADERS | RACE CATTED SEC 1 | RESONATED X-PIPE SEC 2 | SPORT (GEN 2) SEC 3
BRAKES ▌STOCK CSL/ZCP ROTORS | PORSCHE 996 BREMBO CALIPERS | SS LINES
WHEELS ▌STOCK ZCP BBS 19" | 75MM ECS/TMS F&R WHEEL STUD CONVERSION
SUSPENSIONTURNER MOTORSPORT 30MM FRONT SWAY BAR | KW V2 COILOVERS | GROUND CONTROL CAMBER PLATES | SDW RTABS
ENGINE ▌TUNED BY PAUL-CLAUDE | KARBONIUS CSL AIRBOX (ALPHA N), OEM SNORKEL (FLAP DELETE), OIL CATCH CAN
TRANSMISSION ▌'255' CSL SMG DME TUNE | INERTIA SMG DME UPDATE | WARM-UP LIGHT RECALIBRATION
Instagram: https://www.instagram.com/good_m3/?hl=en
Youtube: https://www.youtube.com/channel/UCOW...3N7QDfZ5NSzriA
Journal: http://www.m3forum.net/m3forum/showthread.php?t=599036
Jump to top Good is online now   Reply With Quote
Old Thu, Jul-27-2017, 10:54:30 PM   #13
David@ApexRaceParts
David@ApexRaceParts's Avatar
Reputation: 0 David@ApexRaceParts is on a distinguished road
We'll likely be sticking to aluminum, but we'll make an announcement if we decide to switch materials.
Jump to top David@ApexRaceParts is offline   Reply With Quote
Old Thu, Aug-03-2017, 05:55:49 PM   #14
David@ApexRaceParts
This 900 HP daily driven E46 has been running our 5mm spacers in front and 12mm spacers in the rear for many years. They really are built to endure.
Old Thu, Aug-10-2017, 11:41:30 PM   #15
David@ApexRaceParts
This F80 M3 runs our 5mm spacers behind 18x11" ET44 EC7 wheels in the rear for a perfectly dialed fitment.
Old Thu, Aug-24-2017, 09:47:04 PM   #16
David@ApexRaceParts
Check out the difference 15mm can make.
Order Here
Old Thu, Aug-31-2017, 11:25:15 PM   #17
David@ApexRaceParts
Whether it is for extra inner clearance for suspension or brakes, or just to get that flush fitment we all desire, APEX Spacers have you covered!
Contact us today if you would like to learn more about spacer kits and the supporting hardware.
Old Wed, May-09-2018, 05:15:38 PM   #18
ApexRaceParts
Reputation: 0 ApexRaceParts is on a distinguished road
Certain spacer kits are now on sale:
Silver 5mm spacers are currently on sale for $39.99/pair instead of $54.99.
Silver 18mm spacers are currently on sale for $69.99/pair instead of $94.99.
Jump to top ApexRaceParts is offline   Reply With Quote
Old Tue, May-15-2018, 06:39:36 PM   #19
Laguna01///M3
PapaSmurf
Laguna01///M3's Avatar
Reputation: 0 Laguna01///M3 is on a distinguished road
Hmm, I need a set of 18mm with bolts.
EURO.techniks
@WBUCCO
Jump to top Laguna01///M3 is online now   Reply With Quote
Old Wed, May-16-2018, 04:50:58 PM   #20
ApexRaceParts
Thanks for the post!
The 18mm spacers can be found here: https://www.apexraceparts.com/access...pacer-kit.html
And you'll use 43mm extended bolts, which can be found here: https://www.apexraceparts.com/access...lug-bolts.html
Let us know if you have any questions!
Discussing ► APEX | Redesigned & Re-engineered BMW Wheel Spacers in the M3Forum Sponsor Announcements and Specials Forum - Browse this forum to locate any specials our board sponsors may be holding. at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
