Go Back   BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X) > BMW M3 Discussions > E30 M3 (1986-1991)
E30 M3 (1986-1991) {Euro 86-892.3L: 200hp @ 6750} {1990 2.3L Evo2/Cecotto/Ravaglia: 220/215/215hp @ 6750}
{1991 2.5L Sport Evo: 238 @ 7000} {US -- 88-91 2.3L: 196hp @ 6750, 170tq @ 4750}
Total produced: 5,280 US, ~13,300 Europe/world
Old Sat, Feb-03-2018, 08:33:24 AM   #1
stalker-vishnu
Reputation: 0 stalker-vishnu is on a distinguished road
Ukraine
Default E30 swap S65B40
Hi Guys!
may i ask to discuss at this forum replacement of the S65B40 engine to e30 body?
Generally i've already done it, but faced with a number of problems
First: it rpm limit 4500
second is missing DSC
if anyone knows
that concretely still needs a motor for full functioning?
p.s. sorry for my bad english, i am from ukraine.
Jump to top stalker-vishnu is offline   Reply With Quote
Old Sat, Jun-30-2018, 05:23:27 PM   #2
stalker-vishnu
Ukraine
Default Re: E30 swap S65B40
If someone met this problem pls let me know what is that??
connect battery, before first start:
I am using BMWlogger to fast check errors:
https://pasteboard.co/Hsjxzb0.png
DSC error
on the instrument panel icon half-engine (reduce power) mode
after starting engine! another picture hmm
https://pasteboard.co/Hsjwunn.png
rpm limit 4500 (red zone)
try to push pedal to 100%
but rpm limited about 3500-4000 rpm
turn off engine clear errors clear adapts by BMW logger
ok check again :
got DSC only........ start engine
https://pasteboard.co/Hsjzyr2.png
idle rpm ok
try to rise rpm with the pedal (rpm limit on board 5500)
but in fact a can't reach 4000 rpm , something does not allow me to do it
ok check errors:
https://pasteboard.co/HsjC6Ck.png
wtf !!?
272C
272D lambda heater ?
2786 it's about pressure sensor
http://wiki.rcollins.org/core/index....r:_2786,_P0193
but pressure sensor installed and did not make mistakes before
ok , stops engine....
start again:
https://pasteboard.co/HsjHw1e.png
then stops
https://pasteboard.co/HsjI3K1.png
of all these actions, I understand that some errors occur during engine run and also disappear when it stops
Ie some errors I could not diagnose in INPA because did not detect while tap throttle pedal
and if you carefully look at the screenshots you will see that
of the throttle do not open with the gas pedal pressed
DKPB1 and DKBP2 always zero while pedal angle changin according to the pedal pressed
dsc, e30, fuel pump, s65b40
Discussing E30 swap S65B40 in the E30 M3 (1986-1991) Forum - {Euro 86-892.3L: 200hp @ 6750} {1990 2.3L Evo2/Cecotto/Ravaglia: 220/215/215hp @ 6750}
Total produced: 5,280 US, ~13,300 Europe/world at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
