Old Tue, Nov-18-2008, 05:23:11 PM   #21
Pantera
Pantera's Avatar
Reputation: 0 Pantera is on a distinguished road
Default Same problem resolved with replacement bumpers
Boy this is an old thread...
I had the exact same problem. I didn't understand how it could make a difference either. I changed the bump stops very easily and it closes and stays closed without issue. It was really cheap to do too. They unscrew from the edge and the new ones screw right back in. You may have to adjust the depth of the little bump stops a little, but you could note how tall your old ones are before you put the new ones in and you should be set.
Official Dragon Slayer ( 07/04/07 )
http://www.tailofthedragon.com/dragon.html
Jump to top Pantera is offline   Reply With Quote
Old Tue, Nov-18-2008, 05:32:20 PM   #22
deilenberger
deilenberger's Avatar
That's what the problem is - and this is what fixes it.
JUST DO IT.. you'll be happy with the results.
  • 2011 Lexus RX-350. SWMBO's toy.
Old Tue, Nov-18-2008, 05:38:12 PM   #23
rbenjami
Grumpy Old Man
rbenjami's Avatar
Reputation: 0 rbenjami is on a distinguished road
2 x part number 51-24-8-137-994 on order from circlebmw.com
By the way, I can't say enough nice things about those guys. Very reasonable prices and shipping. Much easier than waiting in line at my local dealer and being tempted into buying a new car!
And thanks again to everyone on this board - what a great community!
Jump to top rbenjami is offline   Reply With Quote
Old Tue, Nov-18-2008, 05:58:28 PM   #24
c.my.m3
c.my.m3's Avatar
Reputation: 0 c.my.m3 is on a distinguished road
Super thread - have this problem too - know I can fix it
Jump to top c.my.m3 is offline   Reply With Quote
Old Fri, Nov-21-2008, 05:40:34 PM   #25
rbenjami
Grumpy Old Man
rbenjami's Avatar
How on earth do I get out the old ones? They just turn in place and don't seem to unscrew!
2004 M3 CB/Cinn Convertible: OEM summer 19s w/ 17 snows; Bluetooth via TCU; euro center bin; v32/2007-2 nav; Beltronics RX75 Plus; Recaro Young Sport Seat
  • If you are wondering about whether or not to buy snow tires, please review the dozens of threads where people caused thousands of dollars of damage in a light snowfall at 10 mph.
  • If you are thinking about buying an M3 because they can now be found pre-owned fairly inexpensively, please review the threads explaining how expensive the maintenance is. Plan on spending $2,000 or more per year on routine maintenance.
Old Fri, Nov-21-2008, 06:27:42 PM   #26
deilenberger
Notice the spiral cut on them - counter-clockwise rotation will take them out.
Old Thu, Dec-04-2008, 07:21:35 PM   #27
rbenjami
Grumpy Old Man
rbenjami's Avatar
I finally got my old ones out by spinning and pulling with a pliers. The new ones look almost exactly like the old ones, but the spring mechanism seems to work a lot better on the new ones. I am 99.9% certain I already had the new part in there. Hopefully this will improve things. I hardly ever use my trunk and the problem only happened every so often in the past. If I am trouble free by the time spring rolls around, I'll call this a success.
Old Thu, Dec-04-2008, 07:37:29 PM   #28
deilenberger
There is a quite visible difference between the old ones and the new ones..
The old ones are simply screw in rubber bumpers.
The new ones are the same bumpers with a spring loaded piston that comes out of the center about 1/2" (1/4" in diameter or so..)
I can't imagine not spotting the difference.
What did your old ones look like and what do the new ones look like?
Old Thu, Dec-04-2008, 07:40:40 PM   #29
rbenjami
Grumpy Old Man
rbenjami's Avatar
They both had the spring piston, but the spring piston on the ones I removed was not nearly as strong as the new ones. I'm sure they were the same part number, but the new ones were - well - newer, so hopefully the stronger spring will help things. For the record, mine is a 5/04 build date and I bought the car used, so it is possible the prior owner already tried this fix.
Old Thu, Dec-04-2008, 09:06:56 PM   #30
M3Dom
M3Dom's Avatar
Reputation: 0 M3Dom is on a distinguished road
Got 2 of PN 51-24-8-137-994 (which was the part - PN-7 - I mentioned above on realoem.com) - cost was $9.30 each, $8.30 each with my CCA discount.
Unscrewed the old rubber bumpers, screwed these in - and it works great. Now when I pop the trunk, it pops up about 1/2" - and the latch fully releases.
I found a 21mm deep socket was ideal for removing the old one and installing the new ones - it had just enough grab on the rubber so they could be turned. I used a bit of GummiPhledge (silicone grease) on the threads on the new ones so they would go in easier.
Attached are photos..
The first photo is the new one on the left and one of the old ones on the right. The second photo is a new one installed in the trunk lid.
On a difficulty scale of 1-10, this is a 1..
you guys are great im having the same issue 02 vert im ordering those parts asap thanks
https://www.instagram.com/d_sicily/
Porshapwr:I thought every day was steak and BJ day?
Ghost : "She'll prolly suck your balls so hard they'll hatch"
Ben Z.;The Ultimate Driving Simulation Machine
LALaw :OP has been surprised by everything that's happened since the 13th Amendment
Cars : some verts some bikes and a 2012 veyron
Jump to top M3Dom is offline   Reply With Quote
latch, problems, trunk, vert
FIXED: Water in Trunk on a Vert! VMen E46 M3 (2001-2006) 6 Sat, Dec-13-2008 09:17:04 PM
Trunk latch recall? notopM3 E36 M3 (1992-1999) 1 Fri, Aug-29-2008 02:59:28 PM
Wtb: Oem Vert Trunk JOHNNYBEGOOD Parts for Sale/Wanted 11 Wed, Jun-04-2008 07:03:56 PM
Trunk help...vert if that matters IDM3 E46 M3 (2001-2006) 10 Fri, Mar-28-2008 01:56:47 AM
trunk latch and cruise control M3 Cougar E46 M3 (2001-2006) 1 Thu, Dec-30-2004 10:56:05 AM
Discussing 'Vert trunk latch problems? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
