Go Back   BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X) > General BMW > M3Forum Welcome Center
M3Forum Welcome Center Place for new members and to check in and say hello. If you're a new M3 owner or enthusiast, please check our FAQ's.
Old Wed, Oct-04-2017, 09:36:52 PM   #1
Dennett
Reputation: 0 Dennett is on a distinguished road
Default Transmission oil change E46 M3 SMG vert.
Has anyone given a detailed instruction on how to change transmission oil on 2003 M3 SMG Convertible.I have just purchased one and am brand new to the forum.
Jump to top Dennett is offline   Reply With Quote
Old Fri, Oct-06-2017, 04:47:13 PM   #2
Default Re: Transmission oil change E46 M3 SMG vert.
Jack car up and place 4 jack stands in appropriate places
Remove black plastic cover (like 5 or 6 8mm hex screws holding it and fuel filter cover)
Loosen fill bolt (17mm hex) on the driver side of transmission first then,
Place pan or bucket under drain bolt and remove drain bolt (17mm). About 2L of fluid will drain.
Replace drain bolt. No washers or gaskets are required for either bolt. Bolts are the same for drain and fill.
Pump 1.8-1.9l of gl4 75w80 gear lube into tranny until it starts to drip out of fill hole. Replace fill bolt.
SMG tranny is the same as 6mt tranny.
This is a very basic job. If you need a DIY, you probably shouldn't be doing it by yourself. Are you comfortable working under the car with it on stands? Do you know the correct points to lift the E46 m3? Where are you located? Members like me are willing to help, often.
-NA S54-
·RE Trans Mounts · AKG poly SUB/DIFF 95a · SDW RTAB · Weighted ///M knob + UUC DSSR + delrin carrier bush · OE CSL trunk · APEX 75mm Studs
·Sportline 8S 18"x8.5/9.5" · MPSS 245/275 · Brembo 996 36/40 345mm CSL Textar FF & 28/30 328mm CSL ATE "D738" FF · CM brackets & ss/teflon lines
Discussing Transmission oil change E46 M3 SMG vert. in the M3Forum Welcome Center Forum - Place for new members and to check in and say hello. If you're a new M3 owner or enthusiast, please check our FAQ's. at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
