Old Thu, Mar-30-2017, 08:08:37 AM   #1
UDPride
UDPride's Avatar
Reputation: 0 UDPride is on a distinguished road
Default Trunk edge plastic trim protection
Did the search, Google, etc.
Does anyone know how to get these plastic protector-type trim pieces off of the edge of the left and right trunk jams? They are on there pretty doggone good (won't peel away like a sticker). As you can see mine are severely cracked/faded and I want to replace them as I tidy up the trunk. Probably a non-issue for most, but nonetheless....
I thought about using a heat gun to try to toast them up a bit and then get a plastic pry tool under them to scrape them off. Someone must have tackled this and gotten them off somehow.
And I will need a part # for replacement. I assume everybody has these and they are a BMW part?
Thanks.
1997 M3 SEDAN | 56K mi | Hellrot | Quest for Perfection
2005 M3 COUPE | 18K mi | BMW Individual PY | Time Capsule
1988 911 TURBO | 62K mi | Guards | Icon for the Ages
2006 CAYMAN S | 45K mi | Guards | Tweaked but Daily Driven
Front Engined! Mid-Engined! Rear-Engined!
There Is No Substitute for the Ultimate Driving Machine.
Jump to top UDPride is offline   Reply With Quote
Old Thu, Mar-30-2017, 11:36:24 AM   #2
LockDots
LockDots's Avatar
Reputation: 0 LockDots has disabled reputation
Default Re: Trunk edge plastic trim protection
Have you tried realoem.com yet? Personally, I've never seen that.
Jump to top LockDots is online now   Reply With Quote
Old Thu, Mar-30-2017, 10:10:42 PM   #3
UDPride
UDPride's Avatar
Looked on RealOEM but nothing jumped out. Mostly just sheet metal and fasteners. The plastic strips do not have any part #s etched on them. I assume its a factory piece however. They seem precisely cut for the job they are doing and are on both sides of the trunk jam edge.
Its a sedan, dont know if that makes a difference. I gotta think others have these too?
Old Thu, Mar-30-2017, 10:55:12 PM   #4
LockDots
LockDots's Avatar
It's possible it was part of the wing's install kit.
Old Thu, Mar-30-2017, 11:30:52 PM   #5
fiveightandten
He'll save children, but not the British children...
fiveightandten's Avatar
Reputation: 0 fiveightandten will become famous soon enough
I pulled them off with my fingers and cleaned it up with goo gone. They didn't put up much of a fight and my car was a garaged 90K mile car when I did it. They weren't weathered at all.
-Nick
1986 325es || 2003 330ci || 1998 M3/4/5
Jump to top fiveightandten is offline   Reply With Quote
Old Fri, Mar-31-2017, 12:43:16 AM   #6
scoobiedoo2029
Reputation: 0 scoobiedoo2029 is on a distinguished road
mine are in the same condition as OP. i never found a replacment part, but the 3m clear paint protective stuff seems like the ticket, theres a spray on too that 3m makes and maybe it dosnt suck. i was thinking of using it and just taping off the original and removing it and spraying the exposed area. enless someone can get a peice off intact i cant see another method of easily duplicating the shape and placement exactly.
Jump to top scoobiedoo2029 is offline   Reply With Quote
Old Fri, Mar-31-2017, 11:09:30 AM   #7
LockDots
LockDots's Avatar
May not be a bad idea to place it on the bottom of the "wing tips" that comes into contact with that area. This way the protection is still there but unseen.
Discussing Fast n Loud in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
