Old Fri, Jan-22-2016, 09:20:08 AM   #1
xkr
Reputation: 0 xkr is on a distinguished road
Default Would you run NT01s on the street if your M was your weekend car?
I'm looking at buying a set of rims which have almost new Nitto NT01s on them and I'm not sure if I should be concerned to drive them on the street. I know they're a DOT tire but they are not recommend. I put less than 3k miles a year on the M3 and it's more of a weekend car anyways so it wouldn't see moist grounds anyways. I must've drove my car 400 miles in 2015. They may see a track day if I ever decide to fit my car with a roll bar to bring it up to spec. I don't drive the M in the winter when there's salt on the ground either. So is it more of a heat cycle issue with these tires or is it a millage thing?
BW 3.5" header back res race exhaust, SGT catless headers, V4 angel eyes, dynavin d99+
Epic Motorsports race tune
Jump to top xkr is offline   Reply With Quote
Old Fri, Jan-22-2016, 01:55:26 PM   #2
nowanker
"He's no wanker!"
Default Re: Would you run NT01s on the street if your M was your weekend car?
No harm in it... probably not possible to get them/keep them up to optimum temp on the street tho. Might actually see better grip with with one of the hot new "200 TW" autocross tires.
RE71r, Rival S, etc
I knew a guy who ran Hoosier A6s on his Porsche on the street...
Old Fri, Jan-22-2016, 03:15:12 PM   #3
Kieffer87
Reputation: 0 Kieffer87 is on a distinguished road
Sounds like your selective on when you take it out, but if you happen to get caught in the rain it's going to suck.
2003 M3 Alpine/Cinnamon Loaded
APEX ARC-8 18x9.5 ET35 wrapped in 265/35 PSS
TCKline D/A Coilovers (550F/600R) W/Monoball RSM, H&R Adjustable Sway Bars
Fabspeed Headers, UUC Corsa Exhuast, CPI RASP-X
Rogue Power Pullies, AA Tune, SS Lines, ZHP Steering Rack
Jump to top Kieffer87 is offline   Reply With Quote
Old Fri, Jan-22-2016, 03:27:43 PM   #4
///M_Achilles
"Visor down for business"
///M_Achilles's Avatar
Reputation: 0 ///M_Achilles is on a distinguished road
You'll be fine on the street with those tires; even in the wet provided they're not worn down to a "slick". NT01's are known for getting a good amount of heat cycles out of them, so considering your limited use and a possible track day, it shouldn't be a concern. No need for a roll bar for the track either unless you're doing multiple weekends. Just get out there and as someone has already mentioned, the 200 rating autocross tires would be a nice alternative too.
Sent from my squat rack
2005 Carbon Black Metallic ///M3
My Journal
Jump to top ///M_Achilles is offline   Reply With Quote
Old Fri, Jan-22-2016, 06:46:01 PM   #5
lmtfi
lmtfi's Avatar
I wouldn't do it intentionally.
And if it rains - you are going to be hating your life. And it will rain.
Old Fri, Jan-22-2016, 09:29:02 PM   #6
xkr
So would I be hydroplaning everywhere if there was just a scatter shower? I don't take my car on that many road trips but yea sometimes I do and there is a rain cloud here and there.
Old Mon, Jan-25-2016, 09:59:37 AM   #7
Patrick4588
Patrick4588's Avatar
Reputation: 0 Patrick4588 is on a distinguished road
Yes, there is no traction on wet pavement with drag radials
Straight Line - 2010 335i M-Sport 704whp
Curves - 2003 M3 612whp
Daily - 600whp trailblazer ss
Track - 87 325i with LSx swap and all the nitrous
Build Thread - http://m3forum.net/m3forum/showthread.php?t=503137
Jump to top Patrick4588 is offline   Reply With Quote
Old Mon, Jan-25-2016, 02:31:31 PM   #8
nowanker
"He's no wanker!"
NTO1s are Nitto's DOT roadrace tire... many racers use them as an 'intermediate' wet track tire. Wet traction isn't bad depending on the depth of the water. Use caution and expect hydroplaning through puddles.
Rereading the original post... the wheels already came with those tires. Use 'em up!
Old Mon, Jan-25-2016, 03:49:20 PM   #9
nrubenstein
NT01s will be great in the dry, and mediocre in the wet. 100% fine as a weekend car tire. If the RA-1s are still available in an appropriate size, I think they'll be slightly better.
Hell, I once daily drove RA-1s in 275 square. My wife still does in the summer on her iX.
Old Mon, Jan-25-2016, 05:28:33 PM   #10
illestminimike
illestminimike's Avatar
Reputation: 0 illestminimike is on a distinguished road
I've done it. It's a little sketchy if you get caught in some rain tho.
Jump to top illestminimike is offline   Reply With Quote
Discussing Would you run NT01s on the street if your M was your weekend car? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
