Old Wed, Apr-17-2013, 02:46:44 AM   #1
M clunk
M clunk's Avatar
Reputation: 0 M clunk is on a distinguished road
Default M clunk track car build
Hey guys,
I've owned this car for 5 years. I kept it stock for a little while so I wont bore you with stock looking pictures.
Here is how I got my car ready for this summer.
I knew my whole back end needed a lot of love so I rebuilt it entirely. Every single bolt,and bushing where replaced.I went with AKG 75d for everything that used to be rubber.
I also upgraded my motor, and transmission mounts which were both shot.
Steering coupler was also upgraded
Did my valves, and cam gears bolts.
Both exhaust tabs were intact. Not one valve needed adjustment , and all 12 cam gear bolts were tight. The car has about 130 000km with lots of track time. Very pleased
While I was in the I refreshed my cooling system with a new pump, Mortorsport thermostat, flushed the fuild, and filled it with water/water wetter.
I also got a vibration damper from ATI
And a AKG shifter
AiM Solo
AKG subframe plates.
Some paint corrections...
RS3s
Nice and clean
Mod List
Interior:
Recaro Profi Spa Carbon/Kevlar, VAC floor and side mounts,VAC anti sub bracket, Sparco 330mm steering wheel , AiM Solo lap timer, MPR wheel spacer, AKG steering guibo, 6 point roll FIA roll cage, heater core delete,AKG DTM shifter, AKG selector rod, AKG clutch pedal bushing, Schroth Profi II 6 point harness, Lithium weight battery, and MPR battery bracket.
Exterior
Carbon fibre sun roof delete, generic brake ducts, black out grills/gills, Home made diffuser, APR wing, Home made front splitter, AKG tow hooks.
Wheels
Apex ARC-8 9.5 square, Pirelli race slicks, Rogue Engineering 10mm wheel spacers front, 15mm back, Bimmerworld bullet nose race studs.
Suspension/drive train
JRZ RS coilovers, Ground control race camber plates , and RSM, Hyperco springs, SPC/Eibach rear camber arms, Hotchkis front sway bar, TcKline spherical RTABs, AKG FCABs, AKG transmission mounts, AKG subframe bushings, MPR Golf Ball Shift knob.
Brakes
AP Racing BBK front, Goodridge stainless lines, OEM blank rotors rear PFC-11 pads
Exhaust
JVT headers, Modified OEM unresonated section 1, Bimmerworld race exhasut .
Engine
VAC harmonic damper, Evosport under drive pulleys with titanium hardware, Active Autowerke tune, fanclutch delete, B-Line carbon fiber intake, AKG engine mounts, MPR SAP delete plate, MPR Oil filter housing.
Videos
Jump to top M clunk is offline   Reply With Quote
Old Wed, Apr-17-2013, 03:05:59 AM   #2
flipm3
E46 M3 | E90 M3
flipm3's Avatar
Reputation: 0 flipm3 is on a distinguished road
Default Re: Track car prep for 2013
Incredible work!!
How do you like the AKG Steering Coupler, more specifically, on the street?
What suspension are you running?
2004 E46 M3 6MT | Silver Grey . Cloth | My E46 M3 Build Thread
2009 E90 M3 DCT | Melbourne Red . Speed Cloth | My E90 M3 Build Thread
2002 E46 M3 6MT | Jet Black . Black Nappa | My E46 M3 Build Thread
2016 981 Cayman 6MT | White . Black | Coming Soon
POST YOUR DYNO GRAPH HERE: The Official Dyno Thread
Jump to top flipm3 is offline   Reply With Quote
Old Wed, Apr-17-2013, 03:11:29 AM   #3
M clunk
M clunk's Avatar
Originally Posted by flipm3 View Post
Incredible work!!
Thanks !
I like it a lot. I like my steering as direct as possible, and this is great. My race steering wheel also helps for that. On the street , you feel the bumps and vibrations a little more.
I'm running Tein SSP coilovers
Old Wed, Apr-17-2013, 02:17:26 PM   #4
m3freak86
JERSEY STRONG
m3freak86's Avatar
Reputation: 0 m3freak86 is on a distinguished road
Very nice work! The rear end overhaul looks great! Car looks a lotttt like mine when I had the silver arc8's! Keep up the nice work.
2013 SWP Subaru WRX Hatch (gone)
WRX Journal
2004 Carbon Black///M3 (gone)
Mods and Specs
My Exhaust Obsession
My Journal
Jump to top m3freak86 is offline   Reply With Quote
Old Wed, Apr-17-2013, 02:45:36 PM   #5
///M_Achilles
"Visor down for business"
///M_Achilles's Avatar
Reputation: 0 ///M_Achilles is on a distinguished road
Amazing work bud! I like the preventative maintenance and upgrades to the rear subframe. That takes dedication not cutting corners. She's definitely track ready
Sent from MI6
2005 Carbon Black Metallic ///M3
My Journal
Jump to top ///M_Achilles is offline   Reply With Quote
Old Wed, Apr-17-2013, 03:43:58 PM   #6
ML///M3
Sunday Drive NYC
ML///M3's Avatar
Reputation: 0 ML///M3 is on a distinguished road
Awesome project. It seems like everyone who has an M eventually decides to build the car for track. Side comment: That's one clean garage as well. Be sure to keep everyone posted on the progress both on and off the track.
2005 /// M3 Coupe ZCP - Road & Track | BMWCCA Instructor
Jump to top ML///M3 is offline   Reply With Quote
Old Thu, Apr-18-2013, 12:54:19 AM   #7
M clunk
M clunk's Avatar
Thanks! I remember seeing your car and thinking the same
Old Thu, Apr-18-2013, 12:58:34 AM   #8
M clunk
M clunk's Avatar
Sent from MI6
Thanks man
Old Thu, Apr-18-2013, 01:10:41 AM   #9
M clunk
M clunk's Avatar
Thanks.
The E46 is such a fun track car. It's no surprise to see more of them being built !
Old Wed, May-01-2013, 01:05:20 AM   #10
M clunk
M clunk's Avatar
Had some fun at the track yesterday. I'm very happy with the changes I made to the car over the winter. I beat my best lap time of 2012 by 0.300 on my first session
Here's a lap
I don't know why the quality is that bad. I need to work on my editing skills ...
Discussing M clunk track car build in the Member Journals Forum - Do you have a long term project you would like to share with the community? Use this forum to create a single thread which you can update over time to document the progress. at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
