Old Sun, Sep-06-2015, 05:42:05 PM   #11
bimmerdriver
Reputation: 0 bimmerdriver is on a distinguished road
Default Re: Autosolutions Complete Kit Installation
I got the pin installed with minimal force. I wasn't getting good photos with my camera because it was having trouble focusing so I tried another approach. I blackened the end of the pin with a felt pen and inserted it into the hole. That showed me the misalignment. It took only a couple of tries to get it aligned so there was no visible misalignment. At that point, the pin still wouldn't insert with finger pressure, so I lightly tapped it with a 3/8" ratchet. It went almost all the way in. I wiggled the transmission up and down while tapping and it went the rest of the way in. That's the ticket.
2002 (12/2001) M3 6MT Coupe Carbon Black on Black - ZCP/CSL Wheels, 245/35/19 Mich PS2 & 285/30/19 Conti ExtremeContact DW, H&R 15 mm Front Spacers, CSL F/R Brakes, EBC Redstuff, TMS SS F/R Brake Lines, PSS9, TMS F/R Sway Bars, TMS Rear Control Arms, TMS Underdrive Pulleys, TMS/Carbonio Intake, Eisenmann Exhaust, AutoSolutions 30% SSK, BMW Illuminated Shift Knob, BMW Performance Pedals, BMW Performance 4.10 R&P, CDV Delete, Flossmann GTR Carbon Fiber Hood/Trunk, Carbon Fiber Rear Diffuser, Euro Front Signal Lights, Euro Rear Tail Lights, Angel Eyes, Homelink
1997 328is 5MT Coupe Madeira Violet on Black - Staggered M Forged Double Spoke Wheels, Bilstein Sport, H&R Sport, M Tech Rear Spoiler (Sold)
Jump to top bimmerdriver is offline   Reply With Quote
Old Sun, Sep-06-2015, 07:47:09 PM   #12
///M_Achilles
"Visor down for business"
///M_Achilles's Avatar
Reputation: 0 ///M_Achilles is on a distinguished road
Originally Posted by m3 hal View Post
I chamfered the edge of the pin. Took only a few minutes to install.
This. I took a filer and made the edges of the pin dull. This is the hardest part of the job, no doubt. Somewhat comical to read about your pain (no offense). A right of passage because we know what you're going through, but you'll soon be on the other side of the pond and can read the next poor soul's review of the install. that being said, I supported the transmission with a low profile jack lifting the transmission and pressing the carrier against the tunnel. Took a long dowel and dead blow hammer to tap the carrier into position. I used a cheap dental kit i bought at Walmart (the small mirror) to check my position. It sucks. No way around it. GL
Sent from my squat rack
2005 Carbon Black Metallic ///M3 SOLD
My Journal
2012 Porsche Cayman R
Jump to top ///M_Achilles is offline   Reply With Quote
Old Mon, Sep-07-2015, 02:47:31 AM   #13
kkamakasi
울산박
kkamakasi's Avatar
Reputation: 0 kkamakasi is on a distinguished road
South Korea
oh gawd... the pin alignment.
It's been 2 years since I did this and just thinking about it still gets my blood pressure up.
Jump to top kkamakasi is offline   Reply With Quote
Old Mon, Sep-07-2015, 03:19:54 AM   #14
bimmerdriver
Well, it's done and I took the car for a test drive. What a difference! I'm really impressed. The shifter is somewhat stiff and more notchy, but the precision is amazing. I also like the shorter throw and shorter lever.
As I said previously, I was able to get the pin inserted with minimal force by aligning the carrier. I did not have to chamfer the pin. I prefer the method I used for aligning the carrier to get the pin inserted rather than using force.
The reassembly process went without a hitch. I took my time and power washed the underbody trays and exhaust shield and did some degreasing. Also did an oil change and vacuumed the car. Also looked at the RACP, which shows no signs of cracking.
The only thing I wish I had done was get a new set of rear fasteners for section 2. They weren't in terrible condition, but they were more corroded than I would prefer. The front fasteners were in good condition. I replaced both the front and rear gaskets. The rear gaskets were in good enough condition to have been reused, but the front gaskets definitely needed to be replaced.
I wasn't sure what to expect coming from the UUC shifter. The build quality of the UUC shifter and DSSR is good, but I think its downfall is relying upon the OEM carrier bushing. It's too soft. I also think the AutoSolutions selector rod design is better, because it eliminates play for the pins. The UUC DSSR is very well made, but I believe the design introduces more play because the pin is not fixed like the AutoSolutions selector rod. I don't think the improvements of the evo3 address either of those issues.
Old Mon, Sep-07-2015, 04:19:08 AM   #15
tjpatte
Reputation: 0 tjpatte is a jewel in the rough
It'll loosen up after a couple of hundred miles. Have about 50k on my 30% and still feels great.
2004 Mystic Blue M3
Jump to top tjpatte is offline   Reply With Quote
Old Tue, Sep-08-2015, 05:46:58 PM   #16
Tp///M3
Got ///M?
Tp///M3's Avatar
Reputation: 0 Tp///M3 will become famous soon enough
Laos
Ahh.... the pain of aligning the pin.
I actually like the mechanically feel when it's new. One of the best mods for the car. BMW should have done this from factory. IMHO.
04 CarbonBlack/ImolaRed
Jump to top Tp///M3 is offline   Reply With Quote
Old Tue, Sep-08-2015, 06:12:13 PM   #17
Yep! Report back in 500 miles! It gets much less notchy in short order.
Old Tue, Sep-08-2015, 07:27:23 PM   #18
OldFanatic
19 yr BMWCCA Member
OldFanatic's Avatar
Reputation: 0 OldFanatic is on a distinguished road
since the old pin is a pain to get off I just bought a new second pin. they're so inexpensive why not?
I test fitted the new one to the AutoSolution kit, chamfered the pin's tip ever so slightly. I read where people freeze the pin the night before to aid in fitment. it went in without much hassle. I also used a smaller bolt (size) than pin as my alignment starter. wiggle it around inside prior gets it aligned. doing these tricks it went in easier than my previous UUC kit.
but I feel your pain being a first timer.
2003 TiAg - OE CSL WHEELS - OE CSL BRAKES - AA SPORT TUNE - AA PULLEYS - AS 40% SSK- VCSL TRUNK - VCSL DIFFUSER
SUPERSPRINT EXHAUST
- BMW PERFORMANCE CF STRUT BRACE - BILSTEIN PSS9s - GRUPPE M CF INTAKE - CF RACE LIP - 4.10 M DIFF - CSL RACK - GROUP N MOTORMOUNTS
-SANS SUNROOF-
Jump to top OldFanatic is offline   Reply With Quote
Old Mon, Nov-09-2015, 05:04:56 AM   #19
bimmerdriver
It's a while since I installed the shifter. As expected, it loosened up somewhat (in terms of effort), but it is still very precise. No regrets at all. I highly recommend the AS shifter.
Old Mon, Nov-09-2015, 12:38:58 PM   #20
Stage3Rides
Stage3Rides's Avatar
Reputation: 0 Stage3Rides is on a distinguished road
I was actually just thinking about my 20% AS SSK kit that I've had installed in my car since the spring. I think it's my favorite mod that I've done to my car so far. I just love how it pops into gear; super precise and no excess force needed. Everyone needs to do this mod!!
Sent from my SM-G900V using Tapatalk
2003.5 IR E46 M3
| Apex ARC-8s | Dinan CAI | TTFS Tune | AS 20% SSK | CPI Stepped Headers | AR20'd OEM Section 1 | SGT SCZA Section 3 | TMS Power Pulleys | AFE Intake Elbow |
| SGT CF CSL Trunk Lid | SGT Rear Diffuser | K-Sport Coilovers | ZCP Shift Knob | TMS Subframe Kit | BW Motor Mounts | RE Tranny Mounts | Avin Avant 2 |
Jump to top Stage3Rides is offline   Reply With Quote
Discussing Autosolutions Complete Kit Installation in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
