Old Thu, Sep-03-2015, 01:48:18 AM   #1
bullet0770
bullet0770's Avatar
Reputation: 0 bullet0770 is on a distinguished road
Default Do you grease on Derlin Pedal Bushing ?
I have read that Derlin is self lubricating, also read people saying they asked AKG people and they said you can ? I have rogue Derlin Bushings.
If yes which one ?
Jump to top bullet0770 is offline   Reply With Quote
Old Thu, Sep-03-2015, 02:19:51 AM   #2
RedM3/4
Reputation: 0 RedM3/4 is a jewel in the rough
Default Re: Do you grease on Derlin Pedal Bushing ?
Delrin is a very slippery material; not sure I'd call it self-lubricating the way a powered metal bearing (think heater fans in cars, stove hood vent motor in houses, etc) is.
Can't hurt to lube it lightly and this might help installation if nothing else.
ADS
98 M3/4, Supersprint catback, UUC red tranny mounts, Rogue SS w/UUC dual selector rod, wired V1.
Sold to my son, still in the family!
06 SMG/ZCP - April 09, Dinan over Konis, RAC RG63, homelink with off-delay (working), multifunction steering wheel buttons, RacingBrake Front kit.
Jump to top RedM3/4 is offline   Reply With Quote
Old Thu, Sep-03-2015, 02:21:08 AM   #3
Mr. Black
Registered Drug User
Reputation: 0 Mr. Black is on a distinguished road
Don't suppose it's necessary but if it really squeaks, plastic bushing grease will solve it
Jump to top Mr. Black is offline   Reply With Quote
Old Thu, Sep-03-2015, 02:23:06 AM   #4
bullet0770
bullet0770's Avatar
ADS
Actually I have pedals out and bushing go in with little pressure.
Old Thu, Sep-03-2015, 02:27:43 AM   #5
bullet0770
bullet0770's Avatar
Thanks, then it has to wait for tomorrow as I don't have grease at home.
Old Thu, Sep-03-2015, 02:28:04 AM   #6
RedM3/4
A very light coating of teflon still can't hurt; maybe not needed but can't hurt.
ADS
Old Thu, Sep-03-2015, 02:42:18 AM   #7
bullet0770
bullet0770's Avatar
ADS
AKG recommends to use wheel bearing grease for their derlin bushing, maybe will use that.
Old Thu, Sep-03-2015, 03:53:59 AM   #8
RedM3/4
Is fine, I did a quick wiki check, Delrin doesn't like chlorine even from chlorinated water or acids, but greases should be fine. Wheel bearing grease is generally heavier/thicker than teflon/PTFE grease; doubt you'd feel the difference either way.
ADS
Old Thu, Sep-03-2015, 12:10:54 PM   #9
bullet0770
bullet0770's Avatar
ADS
Cool Thanks Man, appreciate your help. 🏼
Old Thu, Sep-03-2015, 04:41:15 PM   #10
///M_Achilles
"Visor down for business"
///M_Achilles's Avatar
Reputation: 0 ///M_Achilles is on a distinguished road
You'll need to use to a lubricant regardless. Maybe even sand paper so that the pedal doesnt stick. It's a really stiff bushing. I have RE delrin bushings
Sent from my squat rack
2005 Carbon Black Metallic ///M3
My Journal
Jump to top ///M_Achilles is offline   Reply With Quote
Discussing Do you grease on Derlin Pedal Bushing ? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
