Old Wed, Jul-12-2017, 12:01:33 AM   #31
Kdubski
Kdubski's Avatar
Default Re: Weighted Alignment
For what it's worth, here is the alignment spec sheet. Everything looks in spec so I'm praying the machine wasn't calibrated.
Sent from my SM-G920V using Tapatalk
Old Wed, Jul-12-2017, 01:31:12 AM   #32
EricSMG
40 something
In spec doesn't mean good. Your rear toe is significantly asymmetrical - maxed on one side and min on the other. That means thrust angle <> 0 which means pull.
Also to note that your caster is very low.
Old Wed, Jul-12-2017, 01:51:02 AM   #33
black bnr32
Reputation: 0 black bnr32 is on a distinguished road
yeah fix that rear toe imo
probably can way closer on front camber too
Jump to top black bnr32 is offline   Reply With Quote
Old Wed, Jul-12-2017, 01:59:23 AM   #34
EricSMG
40 something
Oh good call, didn't even notice the camber. Front is imbalanced and rear is WAY WAY off, virtually zero, not even slightly close to in spec.
Note - my black car can only reach about -1.0 degree rear camber - needs adjustable arms - yours is much worse. Minimum spec is -1.5.
Old Wed, Jul-12-2017, 05:08:18 AM   #35
bigjae1976
That is a terrible alignment job.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola Red
Old Wed, Jul-12-2017, 05:22:21 AM   #36
tmaxx445
Likes to Eat AMGs
tmaxx445's Avatar
Reputation: 0 tmaxx445 is on a distinguished road
Time for a new shop....those specs look terrible and Im not shocked that's how it drives.
2005 M3 Coupe / 6 Speed / Silver Gray Metallic / Black Nappa Leather / Premium / Cold Weather / Bi Xenons / Adjustable Bolsters / Lumbar / MKIV Navigation / Harmon Kardon Hifi / Sirius / Aux In / Bluetooth / Rain Sensor / Home Link / BMW Assist / Alarm / Hard Wired Radar Detector / LED Interior Lights / Carbon Interior Trim / Alcantara Pillars / ZHP Shift Knob / Short Shifter / Custom Tune / StreamLine Intake / IAT Relocation / Dynamic Air Scoops / Fan Delete / SS Headers / AR20 Resonator / Electric Exhaust Bypass Valve / Koni Yellow Adjustables / Eibach Pro Kit Springs / PowerFlex & AKG Poly Bushings / M Track Mode / RedLine Fluids / PFC Z-Rated Street Pads / Staggered OEM CSLs / 275 & 245 595 Evos / 12mm Front Spacer / 10mm Rear Spacer / Orion V2 Angel Eyes / Carbon CSL Splitters / Matched Reflectors / SunTek Carbon 38% Tint
Jump to top tmaxx445 is offline   Reply With Quote
Old Wed, Jul-12-2017, 03:33:23 PM   #37
nowanker
"He's no wanker!"
At last... some specs to look at.
Caster is even side-to-side, that's good. Uneven caster will cause a pull, but even up to 1/2 degree difference is usually invisible.
F Camber is NOT even... camber will def cause a pull.
Rear camber not in spec, rear toe uneven. Rear tires point the car, F tires correct the aim... Uneven rear toe will have the car driving slightly sideways down the road.
The numbers here highlight the difference between a quality alignment and a generic sh*t alignment.
Sure, the numbers can be in spec (although yours aren't), but the car still makes U turns when you let go of the steering wheel.
Good news though if you're planning to DIY the next alignment at home! Caster is a little tough to measure accurately at home. Yours is even, so it isn't causing the pull. And since it's not adjustable, you don't need to worry about it migrating off when you make other adjust's.
Old Wed, Jul-12-2017, 03:34:23 PM   #38
nowanker
"He's no wanker!"
Old Wed, Jul-12-2017, 04:03:28 PM   #39
bigjae1976
But caster is what it is. There's no way to adjust it unless I'm missing some adjustment? I can change it on my Vorshlag plates but I there's 3 fixed settings.
Camber can be 1/2 degree off and still track straight. Been there. Toe is what needs to be dead on.
Old Wed, Jul-12-2017, 09:20:45 PM   #40
nowanker
"He's no wanker!"
After doing a sh*tload (>1000?) of alignments....
Caster will cause a pull. Even if it isn't adjustable, nice to know whether it's even.
Camber will also cause a pull. Some cars/tires are more sensitive than others. 1/2 degree difference is BMW spec, and I consider that to be right at the edge of noticeable. Sometimes well over the edge...
Uneven rear toe will drive the car slightly sideways down the street. I can see it being theoretically possible, but I've never had one so far off that it made the car pull, without there being some additional and "more interesting" causes.
Uneven front toe gives you a crooked steering wheel, nothing else. Barring any other contributing factors, as the car is traveling, the front tires will equalize to relative straight ahead, turning the steering wheel accordingly.
Discussing Weighted Alignment in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
