Go Back   BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X) > BMW M3 Discussions > M3 Frequently Asked Questions > E46 FAQ
Closed Thread
Old Sat, Apr-12-2003, 03:55:19 AM   #31
muf
muf's Avatar
Reputation: 0 muf is on a distinguished road
I got the letter as well. And I totally understand the fact that you HAVE to BREAK IN THE CAR AGAIN. I cant however say that im happy about it.
Scott
2002 M3 Cabrolet.White/Red.SMG
website://www.leo.nutz.de/
Jump to top muf is offline
Old Sat, Apr-12-2003, 03:55:55 AM   #32
David L
Reputation: 0 David L is on a distinguished road
Default S54 Engine Failure Campaign
Does anyone know the location of the oil pump on the S54 engine? I did a 1200 mile oil change and doubt that my bearings are at risk. I'd rather not crack open the engine if the oil pump replacement can be done from the "outside".
Jump to top David L is offline
Old Wed, Apr-16-2003, 01:53:59 AM   #33
davidw333
Reputation: 0 davidw333 is on a distinguished road
Has anybody have this work done and is driving the car now? Does it feel any different? I know you probably can't really tell because you can't rev it past 5500rpm yet. But is their any minor sh*t like squeaky noises or vibrations anywhere?
Thanks.
A Freudian slip is when you say one thing but mean your mother
Jump to top davidw333 is offline
Old Wed, Apr-16-2003, 06:43:06 PM   #34
DaveM3CA
DaveM3CA's Avatar
Reputation: 0 DaveM3CA is on a distinguished road
I took mine in on Monday for the work. I will be picking it up today and will write back with the results later this week.
I asked a lot of questions and talked to the lead mechanic. The engine is not removed, but the front suspension is lowered to allow them to get to the bearings and oil pump. He and the service advisor guaranteed there would be no damage to the rest of the vehicle. They (Rusnak in Westlake, CA) have done 3 before mine so I feel fairly confident they know what they're doing. I was more worried about taking the whole engine out and that causing damage to other parts of the car.
Jump to top DaveM3CA is offline
Old Thu, Apr-17-2003, 08:10:19 AM   #35
Ninjaboy
Ninjaboy's Avatar
Reputation: 0 Ninjaboy is on a distinguished road
They should do a complete engine swap with a *NEW* updated engine IMHO. You don't want a bunch of hobos in the service department cracking open your new engine and playing frankenstien. I can see if you're at 90k or something but at 9k? or 900 miles? New engine nothing less.
Jump to top Ninjaboy is offline
Old Thu, Apr-17-2003, 12:30:07 PM   #36
David L
Default M3 Engine Recall
I'll be interested to know how it goes. The two dealers I live closest to have not yet done one of these. I did find out that the oil pump is internal (perhaps in or near the oil pan). I also found out that the crankshaft main bearings are loosened to lower the crankshaft to get the the connecting rod bearings, but not replaced. They are only inspected. I wrote a letter to Hans Dunzl Engineering Director at BMW asking why they don't recommend replacing both the connecting rod and main bearings while they are at it. After all, all the bearings were subjected to the same conditions. I'll post his reply when I receive it.
Old Fri, Apr-18-2003, 03:27:56 PM   #37
DaveM3CA
DaveM3CA's Avatar
I got my car back yesterday but haven't driven it much yet. Everything was in top order as they said it would. They cleaned it up (detailed it I believe), filled the gas tank, and changed the oil during the procedure. In talking with the service advisor after the work was done, I got a copy of the work instructions (9 pages). In them, it says that the engine does not come out (good), the bearings and oil pump are replaced with extra care not to scratch the bearing surfaces, they will fill the gas tank (so bring it in empty if you have a choice), and the oil is changed (again, bring it in midway through your service interval for a free oil change if you can). It also said that the replacement kit is VIN specific. Once you call for an appointment, they order YOUR parts. It sounded like they are custom for your engine rather than a way to track the work by VIN number.
They didn't reset the service indicator. They put about 8 miles on the car which probably explains why they put gas in it as part of the service. I believe the idle rpms are a little higher than they used to be. It's about 800 rpms after warmup, now.
I didn't get anything extra for my inconvenience, but they did a great job and covered the cost of a rental car for the three days it was there. Man is it hard driving a Chevy Malibu after owning an M3. The good thing is, I'll have it broken in before summer starts
Cheers
Old Fri, Apr-18-2003, 07:33:03 PM   #38
davidw333
Cheers
Hey Dave, is the idling rougher than before? I have had no cold start problems, so I might opt to not change the software.
Old Fri, Apr-18-2003, 07:49:51 PM   #39
DaveM3CA
DaveM3CA's Avatar
It's hard to say if the idle is rougher. I never had the cold start problem either, but it was rough at times before the change. I don't think it ever idled as smoothly as it feels when revving, and it doesn't seem to be any different now.
Since the tech notes say the s/w upgrade is required, I'm not sure if they'll let you choose not to get that part of it. Good luck though.
Knowing the actual changes they made would help make a better decision. I'd hate to learn that they detuned the engine just to fix a problem I didn't have in the first place. If they just raised the idle speed, that's fine with me. I wonder if Dinan would know. They certainly have control over all the same parameters and probably have contacts within BMW.
Old Sat, Apr-19-2003, 08:00:55 PM   #40
AtlM3Guy
Reputation: 0 AtlM3Guy is on a distinguished road
Default Bad feeling
I got a letter last week from BMWNA informing me that they had found the problem (as mentioned earlier) and that my engine was not effected. On Monday, I then took my car in for 12000 miles service, got a call in the afternoon that they were going to have to replace the entire long block due to a recall related problem part.
sigh...
Jump to top AtlM3Guy is offline
Closed Thread
E46 M3 Engine Block Failure ccM3zcp General BMW Discussion 13 Sun, Jun-06-2010 05:42:56 PM
Rod bearing recall engine failure question matth76 E46 M3 (2001-2006) 8 Mon, Mar-03-2008 08:03:36 PM
Latest E46 M3 S54 Engine Service: Details. Kevin034 E46 M3 (2001-2006) 43 Sun, Sep-05-2004 06:13:45 PM
S54 engine failure drewk E46 M3 (2001-2006) 4 Sat, Apr-12-2003 11:28:18 PM
E46 engine failure posts..... E46GTR E46 M3 (2001-2006) 3 Fri, Jun-07-2002 06:35:00 PM
Discussing E46 M3 S54 Engine Failure Recall anouncement in U.S. in the E46 FAQ Forum - at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
