Parts for Sale/Wanted Post your Parts Wanted, and non commercial bmw related items for sale. We ask that companies selling goods become a Sponsor to advertise your goods. |
#31 |
This is absolutely amazing.
I've had cat cams for the past two years and made absolutely amazing power with them. Car runs flawlessly and makes 368.5whp/289wtq, and she was a daily for 30k miles on them and as expected they look like they're fresh out of the box. In Lebanon many hill climb cars use cat cams with great success not a single beat missed. Good luck guys!
PM for performance tune requests Mods: -Custom CF airbox -SSV2 catless headers(with a modified collector extention), Custom 2.5" dual sec1, Custom sec2 2.5" dual with e9xM X pipe, SuperSprint Race inspired custom section 3.. -Cat Cams 280 272. -Custom dyno tune -Tms pulleys and electric fan conversion 385.7 whp 288 wtq Custom exhaust thread and dyno http://m3forum.net/m3forum/showthread.php?t=569086 Cams thread and dyno http://m3forum.net/m3forum/showthread.php?t=554439 Custom cf airbox thread http://m3forum.net/m3forum/showthread.php?t=595180 Why not to use after market bearings with surfacetreatments and /or increased clearance http://www.m3forum.net/m3forum/showp...4&postcount=10 |
Sponsored Links |
#32 |
![]() Location: jacksonville
interested in 280/272 no followers
#33 | |
GroupBuyingPower@outlook. com
I'll need you to include you zip-code and everything else on the list. Thanks for the support.
2004 E46 ///M3 - Oxford Green Metallic II + Cinnamon SMG IG: DrM3anM3 ![]() Mods: Genuine OE CSL Bumper, Both Karbonius and Streamline CSL Airboxes, OE CSL Snorkel w/ working Flap, OE Map Sensor + OE Air Rail, Paul Claude Custom Tune, CSL Engine management with CSL converted DME, Supersprint V1 Stepped Headers w/ Oversized HJS Race Catted section 1, SS 2.5" Twin-Piped Oversized Custom section 2, Custom Oversized Supersprint muffler, Catcam's Billet 280/272 cams, WPC treated rod-bearings, VinceBar (weld) + Redish Plates, Full Beisan VANOS lockdown, BBS LMs w/ PSS, Brembo GT6 (front) + GT4 (rear) BBK, CSL style CF diffuser, Vorsteiner CF CSL Bootlid, CSL SMG Engine DME tune, CSL '255' SMG DME tune, SMG Pump Relocated. For Sale: BNIB OE CSL Wheels Active Group-Buys (PM if Interested):OE CSL Bootlids, Supersprint Headers/Exhaust thread, New Supersprint Oversized Twin-Piped Section 2, HTE Tuning Group-Buy Last edited by Dr M3an M3; Mon, Mar-25-2019 at 02:49:31 AM. |
#34 |
1. Radekxpl 272/280 zip 06418
2. Good, 288/280 -- Need zip 3. Whips333, 280/272 + followers for now zip 06053 4. jbfrancis3, 280/272, no followers, zip 22066 5. samgrant951, 280/272, no followers, zip 46240 6. Topaz_46, 288/280 + followers, V0E 2G5 7. Nugs, 288/280 + followers + shaft, Australia 6003 8. Apex_3472, 280/272, no followers 9. Rbmwiv, 280/272 cams only. Zip 28043 (likely pick-up) 10. AtsAntone, 288/280 no followers, 94550 11. RBG, 280/272 no followers, NC, 27514 |
#35 |
2. Good, 288/280 -- Need zip 3. Whips333, 280/272 + followers for now zip 06053 4. jbfrancis3, 280/272, no followers, zip 22066 5. samgrant951, 280/272, no followers, zip 46240 6. Topaz_46, 288/280 + followers, V0E 2G5 7. Nugs, 288/280 + followers + shaft, Australia 6003 8. Apex_3472, 280/272, no followers 9. Rbmwiv, 280/272 cams only. Zip 28043 (likely pick-up) 10. AtsAntone, 288/280 no followers, 94550 11. RBG, 280/272 no followers, NC, 27514 12. Dutchhome, 280/272, no followers, maybe oil bridge and follower rails, zip 19711 |
#36 |
Schmuck
![]() Location: Syracuse
Could someone enlighten me as to why anyone would chose a milder 280/272 over the 288/280? Why go through all the hassle and expense and not get the most power out of it? Is there a drive-ability concern with the hotter cams? Do you sacrifice bottom end for top end, or something like that?
#37 |
noobie
![]() Location: Santo Domingo
2. Good, 288/280 -- Need zip 3. Whips333, 280/272 + followers for now zip 06053 4. jbfrancis3, 280/272, no followers, zip 22066 5. samgrant951, 280/272, no followers, zip 46240 6. Topaz_46, 288/280 + followers, V0E 2G5 7. Nugs, 288/280 + followers + shaft, Australia 6003 8. Apex_3472, 280/272, no followers 9. Rbmwiv, 280/272 cams only. Zip 28043 (likely pick-up) 10. AtsAntone, 288/280 no followers, 94550 11. RBG, 280/272 no followers, NC, 27514 12. Dutchhome, 280/272, no followers, maybe oil bridge and follower rails, zip 19711 13. Jevi Javi, 280/272 only, 33166 |
#38 |
![]() Location: Los Angeles
If one chooses to not get new followers/shafts etc., and just purchase cams (along with seals and whatever else) I assume these cams can drop in without any other modifications?
![]() ///BBRTuning | 2001 LSB M3 6MT | AEM Infinity | JE 11.5/Carillo S54 | Streamline CSL box | Dbilas 288/280 cams | Moton 3WR rear coilover, 700/500 | Stoptech Trophy BBK 6F/4R | Slicer-spec BBS RIA Japan 18x10.5 et22 (x4) | 4.10 | Turner monoball FCAB/RTABs | Turner lower-rear + Wisefab upper arms | Z3 rack | Lang Racing CF roof | full interior 3310lb wet -- @bbrtuning -- |
#39 | |
![]() Quote:
People aren’t getting that much more power out of the 288/280 cams 5-10 at most and it comes with a lot more tuning hurdles. As well as with 280/272 new followers are recommended but with 288/280 they’re much more needed. Obviously that all depends on mileage and condition. Sent from my iPhone using Tapatalk
#40 |
There is definitely more stress and wear from higher lifts and durations of 288/280, I think their onramps are cut steeper. You need to replace followers and maybe springs/retainers to avoid valve float if you want to run high rpm (costs add up). Car sounds meaner, so if you are in cali trying to fly "under the radar", that is tougher. You definitely need an airbox to run 288/280 to take advantage of them, while 280/272, you could get away with not having one. Tuning wise, not every shop has success getting the max out of 288/280, but if tuned right, they do better at low/mid/high range than 280/272, not just high.
'85 528e 164k miles (sold) '05 M3 6MT coupe All DIY: VANOS, WPC rod bearings, full SS (SS stepped V1 headers, catted S1, stock S2, SS sport), AFD E85 Proflex kit, Ohlins R&T/Hyperco 375f Swift 672r/GC street tops and camber plates, ST40 355 pfc08, 330 ZHP steering rack, diffsonline 4.1 diff with rem polish, E60 short shifter lever, AKG black diff bushings/subframe bushings, Rogue rtab, Sachs clutch/flywheel, rear main, Beyer driveshaft, valve adjustment, cooling refresh. Happy to help with VANOS or any other DIY job around NorCal. Have various specialty tools (VANOS, RTAB, engine bar, valve adjustment, tranny jack, ball joint separator, pilot bearing puller, tap&die kit, etc). |
Bookmarks |
Thread Tools | |
Display Modes | |
