Go Back   BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X) > BMW M3 Discussions > M3 Frequently Asked Questions > E46 FAQ
Old Mon, Jan-03-2005, 03:14:33 AM   #1
Lightfoot
Dad's Taxi
Lightfoot's Avatar
Reputation: 0 Lightfoot is on a distinguished road
Default How to adjust headlight level with thumbwheel?
Does anyone know which way to turn the headlight level adjustment wheel to raise the level of the headlights so that they project farther down the road? In other words, if you are looking down at the wheels, do you rotate them clockwise or counter-clockwise to raise their level? I tried this and it seemed to me they need to go counter-clockwise but I could be wrong. Thanks in advance.
03 Steel Gray Metallic, Rennline Drilled Aluminum Pedals, Borla Exhaust, Dinan Cold Air Intake/Mass-Flow Sensor, Dinan Stage 4 Software, Dinan Throttle Bodies, Dinan Stage 3 Suspension Mods, Auto Solutions SSK, Evosport Underdrive Pulleys, Evosport 4.10 Differential, Spec Lightweight Flywheel, Spec Stage 1 Clutch
Jump to top Lightfoot is offline   Reply With Quote
Old Mon, Jan-03-2005, 04:11:09 AM   #2
capirest
capirest's Avatar
Reputation: 0 capirest is on a distinguished road
I forgot which way it was. Try it both ways & see what happens, it's pretty simple...
Good luck!!
Anthony
My Little daughter (Maiya) is now 10 yrs old!!!! My Pride & Joy!!
Jump to top capirest is offline   Reply With Quote
Old Mon, Jan-03-2005, 04:30:39 AM   #3
04tytaniumsylvr
04tytaniumsylvr's Avatar
Reputation: 0 04tytaniumsylvr is on a distinguished road
bump. I need to re-adjust mine also.
How do you adjust the lights...
-Bill
2004 M3 Titanium Silver...
Crazy MF...
Dinan Stage 4, intake, airflow meter, throttle bodies. Custom bumper, molded hamann brake ducts. H&R Coilovers.
Jump to top 04tytaniumsylvr is offline   Reply With Quote
Old Mon, Jan-03-2005, 04:43:59 AM   #4
Sirius
How many licks..
Sirius's Avatar
Lol, for crying out loud.
Do this: Pull up to a wall. Make sure you can then back up at least 25 feet. Also make sure the ground is level
Mark a spot on the wall thats the same heigth as the hood roundel. Draw a line, or use tape, thats the width of the car, but at the same heigth as the spot you marked.
Back the car up 25 feet.
Align the left part of the cut off (Thats the lowest part) to that line on the wall. I believe raise is when you turn the wheel counter-clockwise.
When I aligned my headlamps, I put them about an inch below the line.
♪♫♪♪♫♪ Trevor ♪♫♪♪♫♪
97' M3. '10 R6.
Old Mon, Jan-03-2005, 05:17:08 AM   #5
cbformula
Reputation: 0 cbformula is on a distinguished road
i thought our HIDs have are auto-leveling... meaning they level themselves regardless?
2004 Estoril Blue M3
Delivery--9/25/04
Jump to top cbformula is offline   Reply With Quote
Old Mon, Jan-03-2005, 05:26:41 AM   #6
Roguish Racing
Roguish Racing's Avatar
Reputation: 0 Roguish Racing is on a distinguished road
I believe it's clockwise...have someone check for you. Just turn them and then have someone stand down the road. Very easy to check out especially if they're facing trees where u can tell how high they go.
Jump to top Roguish Racing is offline   Reply With Quote
Old Mon, Jan-03-2005, 05:27:46 AM   #7
04tytaniumsylvr
They don't, where's the switch to adj. or do I have to get access into my headlight assembly.
-Bill
Crazy MF...
Old Mon, Jan-03-2005, 05:35:43 AM   #8
Lightfoot
Dad's Taxi
Lightfoot's Avatar
I tried changing the level again and I am almost positive that turning the wheel counter-clockwise raises the level of the lights. At least it seems that way. I saw them do this at the dealership to change the level but didn't pay attention which way they turned the wheels.
Old Mon, Jan-03-2005, 06:47:38 AM   #9
Beowoulf
Grumpy
Beowoulf's Avatar
Reputation: 0 Beowoulf has disabled reputation
United Nations
Here is a pic of the wheel for those who don't know. I can't remember which way it goes either but turn one to see which way it goes but remember how much you turned it (ie 1-2 full turns)
Alex
Jump to top Beowoulf is offline   Reply With Quote
Old Mon, Jan-03-2005, 07:53:08 AM   #10
DaBean
Smurf Driver
DaBean's Avatar
Reputation: 0 DaBean is on a distinguished road
France
They are auto-leveling such that if you have 5 cases of beer in your trunk, plus 2 buddies of yours in the back (you never let them in the front seat - keep that for the hot chicas), then your xenons don't go glaring in oncomming drivers' eyes... aka they level themselves down to their "normal, empty weight" setting. THAT is the setting that you can change by turning the knob. Hope this clarifies things up.
-Fabien
NASA NorCal Region Instructor
*SMG Loverz Club*
Jump to top DaBean is offline   Reply With Quote
adjust, headlight, level, thumbwheel
headlight auto adjust? JoeyEsq E46 M3 (2001-2006) 2 Thu, Jun-12-2008 12:44:32 PM
Need to know how to adjust headlight level! JUNIOR_INIZIO E46 M3 (2001-2006) 11 Wed, Feb-27-2008 06:25:39 PM
Driver headlight not able to adjust up. MLicious E46 M3 (2001-2006) 4 Thu, Dec-06-2007 04:42:25 AM
problems w/headlight auto level after suspension Will ZCPM3 E46 M3 (2001-2006) 6 Tue, Oct-11-2005 06:22:08 PM
trying to adjust my headlight DMan E36 M3 (1992-1999) 4 Mon, Aug-02-2004 05:40:26 PM
Discussing How to adjust headlight level with thumbwheel? in the E46 FAQ Forum - at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
