Go Back   BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X) > BMW M3 Discussions > M3 Frequently Asked Questions > E46 FAQ
Old Thu, Nov-26-2009, 07:25:00 PM   #1
simonbaker1
Reputation: 0 simonbaker1 is on a distinguished road
Default Smg 2 gearbox problem !!!!!!!
had a faulty clutch slave cylinder which showed up as a fault....car still drove but hard to pull away as it would stall !! Had a new cylinder fitted at a dealer but the adaption process kept stopping at the 4th gear during setup...hence the gearbox wont learn or adapt now and wont select any gears...pressures are fine and everything was ok just wont learn now....any ideas as car did drive before hand...software or mechanical? Help
Jump to top simonbaker1 is offline   Reply With Quote
Old Thu, Mar-17-2011, 07:56:44 PM   #2
Chris40178
Reputation: 0 Chris40178 is on a distinguished road
United Kingdom
Default Re: Smg 2 gearbox problem !!!!!!!
Hi Simon,
I currently have the same issue with the adaptation process, it errors at 4h gear. Did you manage to fix this problem?
thanks
Chris
Jump to top Chris40178 is offline   Reply With Quote
Old Wed, Jun-28-2017, 10:23:50 PM   #3
pat-b
Reputation: 0 pat-b is on a distinguished road
clutch position switch it sounds like
Jump to top pat-b is offline   Reply With Quote
Old Wed, Jul-26-2017, 08:15:29 PM   #4
pat-b
did you get the issue sorted out ?
Old Thu, Jul-27-2017, 01:44:48 AM   #5
daytonaviolet
OEM CSL Whoore
daytonaviolet's Avatar
hopefully since it was 6 yrs ago.
Tischer aka GetBmwParts
Old Thu, Aug-17-2017, 01:06:41 AM   #6
M3ANMACHINE
@coleslawjay
M3ANMACHINE's Avatar
Really guy...
2011 E90///M3 | Space Grey | Fox Red | DCT | ZCP | Slicktop
APEX | BIMMERWORLD | COBY WHEEL | CORSA | H&R | MACHT SCHNELL | PEDALHAUS
2014 F15 X5 | Space Grey | M-Sport
gearbox, problem, smg
Discussing Smg 2 gearbox problem !!!!!!! in the E46 FAQ Forum - at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
