Go Back   BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X) > BMW M3 Discussions > M3 Frequently Asked Questions > E46 FAQ
Old Sat, Mar-28-2009, 09:57:39 PM   #1
bullyboy
Reputation: 0 bullyboy is on a distinguished road
United Kingdom
Default Bought it, now nervous
Hi guys, nice to be here,
I have just taken ownership of a 2003 e46 m3. It has 39000 miles and 19" rims. it is a soft top and I bought it with a detachable hard roof. Here are some of my worries which I hope you can help me with.
1. Slight hesitation for oil light to go out on start up (no rattles).
2. When braking hard from speed there is a drone from brakes.
3. Gears Notchy.
4. Hold engine at 3000rpm in neutral at standstill, car vibrates.
5. left hand door mirror has mind of its own and likes to look at floor?
Jump to top bullyboy is offline   Reply With Quote
Old Sun, Mar-29-2009, 12:30:08 AM   #2
BxPhillip
Reputation: 0 BxPhillip is on a distinguished road
Dominican Republic
Not much of a car expert but if #5 happens when you put it in reverse its meant to help assisting in parking. You can disable it by sliding the driver/passenger switch for the mirrors to the driver side.
Jump to top BxPhillip is offline   Reply With Quote
Old Sun, Mar-29-2009, 03:07:11 AM   #3
mynameiszian
Reputation: 0 mynameiszian is on a distinguished road
check your level, take it to your trusted mechanic have em look at it...i had a 08 g35 before i got my m3, i had a very doubts like you but my mechanic was like they are all a little finiky and its the sacrifice u make to have the benefit...also get your mirror motor replaced.
Jump to top mynameiszian is offline   Reply With Quote
Old Sun, Mar-29-2009, 06:13:57 AM   #4
lsrteg
carbon 03 e46 m3
lsrteg's Avatar
Reputation: 0 lsrteg is on a distinguished road
oil light can be low oil level
vibration is normal need to change guibo
mirror left side it happend to me all i did is do a system reset pul battery terminal and put it back. it fixed the problem
notchy gears change trans oil to redline or royal purple BMW is over rated.
brakes could be the pad material normal
Jump to top lsrteg is offline   Reply With Quote
Old Sun, Mar-29-2009, 03:38:28 PM   #5
shooler
Reputation: 0 shooler is on a distinguished road
It's highly recommended you have a PPI done before you buy, especially on a performance car. Since you have already bought, take it to a shop to have it inspected. That way you will know of any issues and can address them from that point.
Jump to top shooler is offline   Reply With Quote
Old Wed, Apr-01-2009, 01:14:22 AM   #6
mpegripper
mpegripper's Avatar
United Kingdom
check the oil level
that is normal with drilled rotors
3. Gears Notchy.
new tranny fluid (oem lt-2 is preferrable, but i've used royal purple with great results)
move the side mirror adjustment to the other side, in the US when its on the drivers side, the mirror goes down with in reverse, it may be the opposite in the UK as u drive on the other side of the road (that is if ur in the UK)
Old Sat, Apr-18-2009, 03:13:46 AM   #7
Renon Nity
Reputation: 0 Renon Nity is on a distinguished road
Well, if your experiencing such problem, I guess you need to bring your car to a car repair, where they can check what is going on with it. If need to be fixed...much better.
Renon Nity,
Take over car lease
Jump to top Renon Nity is offline   Reply With Quote
bought, nervous
It's halftime KUpolo, nervous yet? ///JayDee Off Topic 7 Mon, Mar-12-2007 09:20:54 PM
this is making me nervous.. fmk E46 M3 (2001-2006) 5 Thu, Oct-27-2005 09:18:51 PM
Getting nervous-buying tips e-brake M Coupe/Roadster (1997-2002, 2006-200?) 2 Fri, Feb-25-2005 02:00:27 AM
Nervous; waxing my M3 for the first time. squider M3 Car Care and Detailing 17 Thu, Jul-01-2004 12:58:01 AM
Nervous Imola red Cuutis E46 M3 (2001-2006) 25 Fri, Jun-04-2004 02:07:42 AM
Discussing Bought it, now nervous in the E46 FAQ Forum - at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
