Old Fri, Sep-25-2009, 07:13:55 PM   #11
Highpower11
Highpower11's Avatar
Reputation: 0 Highpower11 is on a distinguished road
Subscribed and nice job with this DIY!
Where did you find the part numbers for the filter and washers? I looked on RealOEM and could not find the numbers.
___________________
06 /// M3 ZCP, 6MT, Interlagos Blau Metallic \ M-Alcantara\ Volk RE30\ VMR 701 (winter)\ CDV delete\ ESS ECU Tune\ RPI Scoops\ BMC Filter\ Turner aluminum Race Pedals\ Rogue FR 10mm spacers\ Rogue RSM\ Vogtland Springs\
\ V1 Hardwire\ DICE/iPhone\ Smoked corners\ painted reflectors\ ZHP illuminated Alcantara shift knob\ HID fog's\ LightWerkz TFX\ Nav, Power seats & Sunroof delete\ Coming Soon: Euro Headers & Cats
Jump to top Highpower11 is offline   Reply With Quote
Old Fri, Sep-25-2009, 09:13:10 PM   #12
aznbo187
XIII
aznbo187's Avatar
Remove the dashes between the numbers.
Old Fri, Sep-25-2009, 10:24:05 PM   #13
Highpower11
OK, I got it now.
___________________
Old Sat, Sep-26-2009, 12:13:50 AM   #14
davidilanweis
DW
davidilanweis's Avatar
Reputation: 0 davidilanweis is on a distinguished road
Default nice job
could've used this a few months ago before i broke that damn white plastic collar and had to buy a whole new rear fuel line.....
[FONT=Arial]DW
'11 E93
Jump to top davidilanweis is offline   Reply With Quote
Old Sat, Sep-26-2009, 01:07:56 AM   #15
nitro3421
nitro3421's Avatar
Reputation: 0 nitro3421 is on a distinguished road
Thanks for this, great pictures & comments... I could have used this a few months ago.
Jump to top nitro3421 is offline   Reply With Quote
Old Sat, Sep-26-2009, 01:42:33 AM   #16
RedM3/4
Hey, thanks much! Page saved into my SIYs
Old Sat, Sep-26-2009, 02:17:31 AM   #17
nairod
nairod's Avatar
Reputation: 0 nairod is on a distinguished road
Thanks for the DIY.
Jump to top nairod is offline   Reply With Quote
Old Sat, Sep-26-2009, 10:47:26 PM   #18
asn007
Reputation: 0 asn007 is on a distinguished road
Ok, so this DIY fuel filter change couldn't have come at a better time. I've had the fuel filter for a few weeks now...not sure exactly how to DIY. Then with this, I had the confidence to just do it. Also ordered the washers from my local BMW dealership, only 44 cents!!! I bought 2 just incase I lost one.
So onto the project: jacking up the car was its usual PITA, I only ended up jacking up the driver's side like in the pics.
Removing the panels was a PITA, all the little 8 mm bolts everywhere. The panels also fit like a jigsaw puzzle.
Here's the real PITA, unscrewing the filter from the fuel regulator. I used a 19mm wrench and adjustable wrench but it was tight!!! I sprayed some WD40 on the nut to loosen it up . I just used needle nose pliers on the white clips on the other end.
So if you are doing this with jacks, prepared for a really uncomfortable time on your back, with fuel fumes, and working in tight cramp spaces.
Having a lift would've made this 100X easier...
Jump to top asn007 is offline   Reply With Quote
Old Sat, Sep-26-2009, 11:04:40 PM   #19
aznbo187
XIII
aznbo187's Avatar
Having a lift would make it easier, no doubt!
The filter was ungodly tight onto the fuel pressure regulator. It took a good amount of force to loosen mine, and I now have a nice size bruise on my arm from smacking against the chassis once it snapped loose. But remember, when tightening it back up it doesn't need anywhere near that much force. I learned that after 2 copper washers.
Old Sun, Sep-27-2009, 01:06:49 AM   #20
asn007
Yeah, at one point, I thought the filter was welded on. A hit of WD40 helped.
At the end though, I'm glad I did it myself thanks to your guide
change, diy, filter, fuel
Discussing DIY Fuel Filter Change in the Faults, Fixes and DIY Forum - Please share your experience and knowledge with other members by contributing your own DIY, or by helping another member find the elusive fix! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
