Old Wed, Jan-04-2017, 11:01:24 PM   #131
CypherD86
Reputation: 0 CypherD86 is on a distinguished road
Default Re: DIY Fuel Filter Change
Is it really okay to jack up just the Driver's side of the car like that?
Jump to top CypherD86 is offline   Reply With Quote
Old Tue, Jan-17-2017, 06:45:03 PM   #132
ol_Blue
Reputation: 0 ol_Blue is on a distinguished road
Thanks for the DIY. Going to do mine this winter.
Jump to top ol_Blue is offline   Reply With Quote
Old Wed, Feb-22-2017, 01:57:35 PM   #133
Zach Dunham
Reputation: 0 Zach Dunham is on a distinguished road
Yes. Use jack stands. 2. Basically your car will be leaning. I would not use just one jacked spot. Jack. Stand, jack again in another spot, secure then other jack stand second position.
Jump to top Zach Dunham is offline   Reply With Quote
Old Sat, Oct-14-2017, 10:13:41 PM   #134
babydocjd
babydocjd's Avatar
Reputation: 0 babydocjd is on a distinguished road
Just did this today along with the cdv delete,both as easy as pie. Just have a container to catch the residual gas because there will be alot in the filter, or just keep the filter horizontally.
///M Life
Jump to top babydocjd is offline   Reply With Quote
Old Thu, Oct-19-2017, 05:37:38 PM   #135
arkow
Reputation: 0 arkow is on a distinguished road
i'm at 135k, should i replace my fuel filter? i don't know if it was ever replaced. bought the car with 125k miles...
Jump to top arkow is offline   Reply With Quote
Old Thu, Oct-19-2017, 06:50:06 PM   #136
babydocjd
babydocjd's Avatar
I personally would. I bought my m3 with 187k and with no records of maintenance from prior owners. So that means knock out all of the basics such as inspection 1 and 2 items just to give yourself a baseline of whats been done to the car moving forward. Like i said the fuel filter is a extremely easy DIY.
///M Life
Old Thu, Oct-19-2017, 06:56:12 PM   #137
arkow
True, the part is cheap, i will tackle it this weekend. I got all the fluids replaced already and some other major cooling components. Next is rod bearings and spark plugs..
Old Sun, Jul-08-2018, 02:42:27 AM   #138
EYEHAVEYOU
Simon
EYEHAVEYOU's Avatar
Did this today, super helpful guide. As others have said I think I had an easier time starting with the fitting towards the rear of the car.
As far as the front side (where fuel pressure regulator is), remember that you are turning the 19mm nut opposite what you'd usually expect. That is, if your wrench handle is pointed directly down to the floor (open end facing up), turn towards the passenger side. After spraying some PB on it, I used a needle nose vice grip and squeezed it and the wrench together, came loose easily. Since I'd already disconnected the rear fitting, it was simple to just turn the entire fuel filter to remove it at this point.
change, diy, filter, fuel
Discussing DIY Fuel Filter Change in the Faults, Fixes and DIY Forum - Please share your experience and knowledge with other members by contributing your own DIY, or by helping another member find the elusive fix! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
