E46 M3 (2001-2006) Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm Total Produced: 45,000+ - Years Produced: 2001 to 2006. |
![]() Location: OHIO
I have read that Derlin is self lubricating, also read people saying they asked AKG people and they said you can ? I have rogue Derlin Bushings.
If yes which one ? |
Sponsored Links |
Delrin is a very slippery material; not sure I'd call it self-lubricating the way a powered metal bearing (think heater fans in cars, stove hood vent motor in houses, etc) is.
Can't hurt to lube it lightly and this might help installation if nothing else. ADS
98 M3/4, Supersprint catback, UUC red tranny mounts, Rogue SS w/UUC dual selector rod, wired V1. Sold to my son, still in the family! 06 SMG/ZCP - April 09, Dinan over Konis, RAC RG63, homelink with off-delay (working), multifunction steering wheel buttons, RacingBrake Front kit. |
Registered Drug User
![]() Location: Calgary
Don't suppose it's necessary but if it really squeaks, plastic bushing grease will solve it
FS: LAST prototype adjustable mason engineering rear strut bar FOR SALE!!! |
#4 |
Actually I have pedals out and bushing go in with little pressure.
#5 |
#6 |
A very light coating of teflon still can't hurt; maybe not needed but can't hurt.
ADS
#7 |
#8 |
Is fine, I did a quick wiki check, Delrin doesn't like chlorine even from chlorinated water or acids, but greases should be fine. Wheel bearing grease is generally heavier/thicker than teflon/PTFE grease; doubt you'd feel the difference either way.
ADS
#9 | |
![]() Quote:
Cool Thanks Man, appreciate your help. ![]() |
#10 |
"Visor down for business"
![]() Location: Little Rock, AR
You'll need to use to a lubricant regardless. Maybe even sand paper so that the pedal doesnt stick. It's a really stiff bushing. I have RE delrin bushings
Sent from my squat rack
Bookmarks |
Thread Tools | |
Display Modes | |
