Old Mon, Jun-18-2018, 06:45:08 PM   #41
Default Re: RS-30 lithium battery
Originally Posted by usdmej View Post
is that battery mount custom or available to purchase?
Not available for purchase.
It was going to be a product, but it was decided there wasn't enough demand to justify it.
Old Mon, Jun-18-2018, 07:04:43 PM   #42
Volke
Reputation: 0 Volke is on a distinguished road
That the one Brey Krause was developing and then stopped because of too many different battery sizes?
Peter
Mechanical Engineer
Jump to top Volke is offline   Reply With Quote
Old Mon, Jun-18-2018, 07:06:08 PM   #43
That's the one.
Old Mon, Jun-18-2018, 07:33:41 PM   #44
usdmej
Reputation: 0 usdmej is on a distinguished road
i heard brey krause was developing one as well but never saw it on their site.
looks like the GU1R is discontinued anyways which would explain why this bracket didnt make it to market
Jump to top usdmej is offline   Reply With Quote
Old Mon, Jun-18-2018, 10:11:49 PM   #45
Good
@GOOD_M3
Good's Avatar
Reputation: 0 Good is on a distinguished road
Burkhart offers a 11lbs battery. A little pricey but it seems to be one of the few options for intense battery weight reduction.
2006 M3 SILBERGRAU COMPETITION
EXTERIORJCSL 1X1 DIFFUSER | VÖRSTEINER CSL BUMPER
PREVENTATIVE ▌ VANOS BEISAN LOCKDOWN: UPPER GUIDE CHAIN | SOLENOID COIL PACK | OIL PUMP DISK
EXHAUSTSUPERSPRINT EXHAUST ~ OVERSIZED STEPPED V1 HEADERS | RACE CATTED SEC 1 | RESONATED X-PIPE SEC 2 | SPORT (GEN 2) SEC 3
BRAKES ▌ STOCK CSL/ZCP ROTORS | PORSCHE 996 BREMBO CALIPERS | SS LINES
WHEELS ▌ STOCK ZCP BBS 19" | 75MM ECS/TMS F&R WHEEL STUD CONVERSION
SUSPENSIONTURNER MOTORSPORT 30MM FRONT SWAY BAR | KW V2 COILOVERS | GROUND CONTROL CAMBER PLATES | SDW RTABS
ENGINE ▌ TUNED BY PAUL-CLAUDE | KARBONIUS CSL AIRBOX (ALPHA N), OEM SNORKEL (FLAP DELETE), OIL CATCH CAN
TRANSMISSION ▌'255' CSL SMG DME TUNE | INERTIA SMG DME UPDATE | WARM-UP LIGHT RECALIBRATION
Instagram: https://www.instagram.com/good_m3/?hl=en
Youtube: https://www.youtube.com/channel/ucow...3n7qdfz5nszria
Jump to top Good is offline   Reply With Quote
Old Mon, Jun-18-2018, 11:41:49 PM   #46
2006E46M3fan
2006E46M3fan's Avatar
Reputation: 0 2006E46M3fan is on a distinguished road
Do they give you a free Christmas ornament as I see in the picture?
Jump to top 2006E46M3fan is offline   Reply With Quote
Old Tue, Jun-19-2018, 12:30:20 AM   #47
Volke
It was just replaced by the G30. There's also a slightly smaller and less capacity G20 now too. Both are around 5lbs.
Peter
Mechanical Engineer
Old Tue, Jun-19-2018, 10:35:54 PM   #48
usdmej
the G30 has changed dimensions, my point was if the bracket for the GU1R made it to market it wouldn't bolt on to anything currently available to buy
Old Thu, Sep-13-2018, 09:15:20 PM   #49
MFahrer
MFahrer's Avatar
Reputation: 0 MFahrer is on a distinguished road
Small thread revival
I'm looking at Lithium Battery and will likely purchase the RS-30 (might go AG ATX-30 or Braille G30) for some of the features like restart, etc. Just wanted to check into this thread to see if anyone got any feedback yet.
Walnut Motor Works x SCL Racing
2001 M3, on a diet, CSL wannabe, Ground Control race/track, Hotchkis, Powerflex, Project Mu, Solid Design, Autosolutions, APEX, Bimmerworld
Jump to top MFahrer is offline   Reply With Quote
Old Fri, Sep-14-2018, 02:23:34 PM   #50
INTMD8
INTMD8's Avatar
Reputation: 0 INTMD8 is on a distinguished road
I have the older version (rs-20) in my F355.
All good except it tripped the low voltage switch at the drag strip. Reset after about 10 minutes and started like it had full power. (so kind of seems like it too easily trips the low voltage cutoff switch)
Can sit for about a month with no charger and still start.
Jump to top INTMD8 is offline   Reply With Quote
Discussing RS-30 lithium battery in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
