Old Sun, Oct-27-2013, 03:42:49 PM   #51
Simon//M3
Simon//M3's Avatar
Reputation: 0 Simon//M3 is on a distinguished road
Default Re: M3 SMG pump reconditioning
Steve - do you think it would be wise to remove the cover and clean out the carbon? This would be on a car that the motor still works but may have a lot of miles. Your looks pretty bad in there and I wonder what cleaning it out would do to the life of the motor. Also can this cover be removed while still attached to the car?
Thanks for all the hard work! I also have your resistor mod in place and it works perfectly!
Best,
Simon
2002 TiAg M3: SMG, Fully Loaded. 19" CSL Reps, 6000k Angel Eyes, 4500k Xenon Fogs, Stealth Bulbs, Clear Front Bumper Reflectors, OEM Strut Bar, DICE Ipod Intergration.
Jump to top Simon//M3 is offline   Reply With Quote
Old Mon, Oct-28-2013, 03:42:34 AM   #52
RedM3/4
There is at least one source for a rebuilt motor in the US -
This comes courtesy of user budbundy:
http://eurtonelectric.com/catalog/mo...p_motor_repair
The part number looks different than yours.
ADS
Old Mon, Oct-28-2013, 03:49:13 AM   #53
RedM3/4
Steve, is the seal you speak of the black partially melted piece with the silk-screened number on it AES ..... 2018? Or am I missing something?
Simon, cleaning it can only help, but all of that carbon and copper color in the 5th pic tells me it is brush and commutator scrape (between the segments to clean the crap out) time.
Budbundy also showed me a link to a motorcycle ABS motor (same general design, probably identical to ... some ABS model) where the guy tried to do the brushes; fairly tricky getting it apart, drilling though the case, breaking off plastic tabs of brush-holders, etc. So this one is probably doable, but not the best for one's first dc motor rebuild...
ADS
Old Tue, Oct-29-2013, 12:49:49 AM   #54
SteveEvans
Reputation: 0 SteveEvans is on a distinguished road
United Kingdom
ADS
Hi,
You'll see that I mentioned them in POST 39 in this thread along with that photo which shows that they damaged the end of the motor when removing the casing too.
Steve
Jump to top SteveEvans is offline   Reply With Quote
Old Tue, Oct-29-2013, 12:53:16 AM   #55
SteveEvans
United Kingdom
ADS
No, it's the silicone rubber seal around the black melted bit.
I'm sure that using an airline to blow out all that dust would be beneficial, but it's quite a major job to get the pump removed, only to remove the cover, blow out the dust, and then replace it.
Steve
Old Wed, Nov-06-2013, 06:06:55 PM   #56
SteveEvans
United Kingdom
Will do. First I need to take some photos detailing the measurements to be taken to check the solenoid resistance. Whilst the motor and temperature sensor are all that this thread really covers, some quick checks of the other components would be no bad idea to prevent fitting a pump with other issues.
Also I plan to create a thread detailing how to use DIS/GT1 to report accumulator residual pressure. This will be a good test to run if you think your pump may be on the way out as it would be good to know if the accumulator is in good condition before refurbishing a pump using it.
Steve
Old Mon, Dec-02-2013, 02:44:18 AM   #57
BMtroubleyou
EL-SATO
BMtroubleyou's Avatar
Reputation: 0 BMtroubleyou has disabled reputation
Puerto Rico
I posted this in my build thread for my S/C M3 in the F/I section, but here I wanted to share a minor tip to help those with SMG issues or to do some preventive maintenance on their pumps. Thanks OP!!
Here doing some preventive maintenance on the SMG PUMP, I read this part on the forums http://www.m3forum.net/m3forum/showthread.php?t=413137 and has some really great info. After reading this I decided today to do some maintenance and YES! The pump was really dirty on the inside and a lot of dust from the brushes. This is what gets in between the bearings and all other internal parts damaging the SMG PUMP.
I then vacuumed the dust and ckeaned it with electrical spray cleaner
I also cleaned all the internal electrical brushes and conectors as they were filthy and covered in that black dust, all interior parts and came out super clean!
Also, here is a tip... As I was cleaning the pump I noticed the the interior bearing was dry, so I then took a grease gun with a dpecial tip that you can find in any auto parts store. This tip is syringe that is specialized to penetrate in dificult location. Well on this picture below, I was holding the tip really tight against the gap you see here, I also kept squeezing and pressing more greese with my finger. I then kept spinning the bearing and noticed it feeling more resistant with the wheel bearing grease. It was doing it's job. I only have 60k miles, and if this bearing was like this dry, I am for sure that this is the culprit of most failed SMG pumps. This is just a little preventive maintenance. Tested the pump and all worked perfect!
Currently
04 ///M3 E46 previous was 633 RWHP on 98 mix gas & 50/50 W/M. Now turbo....
10 X5///M E70
07 E60 ///M5
RIP
80 VW Rabbit
85 Toyota Corolla 1.8
85 Mazda RX-7 GSL-SE
87 Mazda TurboII RX-7
96 318Ti
97 BMW 328is E36 "fully modded" AA Supercharged
99 Jetta
02 Jetta
03 BMW 325 IS
03 VW GTI 20th Anniversary
04 Toyota 4 Runner SR-5
04 Audi Quattro 1.8 Turbo
04 AUDI S4 B6 Winter Vehicle DD
06 BMW 530i
01 BMW 330Ci
02 M3 E46 Vert
05 X5 E53 4.8is
2001 R1
2004 CBR 1000RR
2004 GSX-R 1000
Jump to top BMtroubleyou is offline   Reply With Quote
Old Mon, Dec-02-2013, 02:48:54 AM   #58
Rontgen
Rontgen's Avatar
Reputation: 0 Rontgen is on a distinguished road
Thanks for posting! In your opinion, is there any chance of removing the pump motor without taking the rest of the hydraulic unit out?
-Darrell
2001 M5
Jet Black / Black
Jump to top Rontgen is offline   Reply With Quote
Old Mon, Dec-02-2013, 03:57:36 AM   #59
BMtroubleyou
EL-SATO
Puerto Rico
Yes it can be done, it'll be kinda tight but it's doable.
Currently
10 X5///M E70
07 E60 ///M5
RIP
80 VW Rabbit
96 318Ti
99 Jetta
02 Jetta
03 BMW 325 IS
06 BMW 530i
01 BMW 330Ci
02 M3 E46 Vert
05 X5 E53 4.8is
2001 R1
2004 CBR 1000RR
2004 GSX-R 1000
Old Wed, Dec-18-2013, 11:38:50 AM   #60
Detox
Reputation: 0 Detox is on a distinguished road
United Arab Emirates
Default NEW MOTORS Available - Re: M3 SMG pump reconditioning
Hey Guys, absolutely fantastic thread....
Here is what were waiting for.......
http://www.ebay.co.uk/itm/1611778661...84.m1586.l2649
New e46 M3 Motors....
M3 SMG II Convertible...
Certainly the Ultimate Driving Machine.......
Jump to top Detox is offline   Reply With Quote
Discussing M3 SMG pump reconditioning in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
