Old Mon, Jul-21-2014, 10:13:04 PM   #141
Pnick
Pnick's Avatar
Default Re: M3 SMG pump reconditioning
That's called a "One touch collet" that is used to retain/grip either a pneumatic/hydraulic tube.
Measure the diameter of the tube that goes into it & let me know.
I'll see if the ones we have at work are about the same and we'll see what we can do. The ones we have are for 4mm to 12mm tubes.
I can disassemble one of the these to get the "one touch collet" and maybe it'll work.
Old Sun, Aug-24-2014, 02:40:14 PM   #142
M3e46yellow
M3e46yellow's Avatar
Reputation: 0 M3e46yellow is on a distinguished road
Spain
Interesting topic!
I found a replacement motor for the smg pump.
http://www.ebay.de/itm/171421396340
Has someone already installed this one?
Jump to top M3e46yellow is offline   Reply With Quote
Old Sun, Aug-24-2014, 04:57:54 PM   #143
SouthTexasE46
Reputation: 0 SouthTexasE46 is on a distinguished road
Originally Posted by jdamore44 View Post
Here is a link and a picture. Its a sensitive lil guy.. most people break them because you have to push the red rim down and pull up on tube. I would be forever grateful if I could find a good one
http://www.m3forum.net/m3forum/showthread.php?t=250333
Man, for some reason this thing never told me this thread was updated. Do you still need that ring? I can look in my stuff later and see if I got it. I apologize for taking so long.
Jump to top SouthTexasE46 is offline   Reply With Quote
Old Fri, Nov-07-2014, 06:36:56 PM   #144
promitheas81
Reputation: 0 promitheas81 is on a distinguished road
Greece
Smile Re: M3 SMG pump reconditioning
Hello everybody, my name is Nick, i am from Greece and i am a M3 owner
Recently i had to replace my clutch in my M3 2006 smg with 130000Km, and i installed a new sachs.
In the way of DIY replace of clutch i thought that i could clean my electric smg pump. And i did it.. I was very nervous, but finally was it a really easy job.
I think that i could share with you my knowledge as you did it to me.
When i open the pump, it was full of black brushes dust. I cleaned it with spray and then i look it inside. My pump was going to be dead soon.
Brushes was good but two bearings and the Commutator was really very bad. So i decided to reconstruction it.
Bearings was easy to replase them, Part Number is 6001, i bought two new skf 6001.
The commutator i took it from a used DSC pump from 2001 M3 E46. First m3 have the dsc pump as external part of the dsc system. So very carefull i uninstall both of them from their motors and put it back to smg.
It was difficult but finally everything worked fine. Commutators have differents but both of them has 12 copper bars.
Next day i visited a torno machine, where i make a plastic ring to fix my new commutator in smg pump axle, then i package it in the axle and solder copper bars with wires. And thats all.
Total cost was 22 euro.
Now my pump hearing nice and smouth.
With Inpa i have check the pressure and i noticed that working between 49 and 67-68 bar. The pump works for 3-4 seconds and it covers 5 gearbox changes Natural - first.
I think that pressure is low but brushes need to apply on commutator, that need to use it for a period and check it again.
Thats all i have to say, thank you everybody.
Jump to top promitheas81 is offline   Reply With Quote
Old Fri, Nov-07-2014, 07:03:12 PM   #145
Goose81
Reputation: 0 Goose81 is on a distinguished road
@SteveEvans. Great work and thank you for sharing.
Jump to top Goose81 is online now   Reply With Quote
Old Fri, Nov-07-2014, 07:28:17 PM   #146
promitheas81
Greece
More photos...
File Type: jpg PartImage_4fe559f3-e962-46b9-bdbc-bd1f7ffa45fe.jpg (36.8 KB, 121 views)
Old Fri, Nov-07-2014, 07:35:59 PM   #147
m3dragon
CSL M3 / Raptor / 12C
m3dragon's Avatar
Reputation: 0 m3dragon is on a distinguished road
For those who have done this work. Did you take enough pictures to make a DIY as well as make a complete parts list?
NorCal drive organizer guy
Drive database and photo locations
NorCal CSL build thread - US to CSL Conversion
Jump to top m3dragon is offline   Reply With Quote
Old Fri, Nov-07-2014, 08:04:38 PM   #148
SteveEvans
Reputation: 0 SteveEvans is on a distinguished road
United Kingdom
What was the temperature when you measured the pressure? If cold, that pressure is good. With the car properly warmed up you should see nearer 75 bar.
Steve
Jump to top SteveEvans is offline   Reply With Quote
Old Fri, Nov-07-2014, 08:14:34 PM   #149
promitheas81
Greece
Hello Steve!
Yes that pressure was it with cold engine.
I am going to check it tomorrow.
Really thank you for the advise!!
Old Fri, Nov-07-2014, 08:28:57 PM   #150
VinceSE2
FKA VinceSE
Sweden
Thank you very much promitheas81 for taking the time to snap pictures and share your experience!
So I assume the brushes where OK, and that its the comutator that wears. Is that correct?
Discussing M3 SMG pump reconditioning in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
