Old Mon, Jan-22-2018, 04:37:57 PM   #1
icecream
Registered Apples
icecream's Avatar
Default Removing rear trailing arm, any BMW specific tools?
Went to replace the trailing arm bushings today. Didn't realize the rod was hitting the dust shield and I installed the damn thing crooked. Warped the housing so the bearing just slips in so only about .25" or so is actually holding the bearing in. Should have known it was wrong with the amount of torque I needed.
Anyways, getting a used trailing arm today. Anyone know if I need special tools/pullers for this? The wheel bearing will remain attached to the arm but still needs to slip off the axle.
FML, turned a 30min job into a 48 hour job and triple the cost. Thanks!!!
Jump to top icecream is online now   Reply With Quote
Old Mon, Jan-22-2018, 10:00:27 PM   #2
Default Re: Removing rear trailing arm, any BMW specific tools?
If you reuse your hub the inner race from the wheel bearing will likely come off. So you’ll need to replace the wheel bearing.
I have a wheel bearing tool for rent if you need it.
Old Mon, Jan-22-2018, 10:46:11 PM   #3
icecream
Registered Apples
icecream's Avatar
The one I bought has the hub on it so I think I'll leave it alone. Looks like a 3 jaw puller will be sufficient without replacing the hub then.
Old Mon, Jan-22-2018, 11:26:13 PM   #4
Should be good to go.
Old Tue, Jan-23-2018, 12:00:02 AM   #5
icecream
Registered Apples
icecream's Avatar
Discussing BMW M3: The Evolution of an Icon. BMWCAR magazine special in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
