Go Back   BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X) > Regional M3's > Pacific
Pacific For events in California, Idaho, Nevada, Hawaii, and Alaska.
Old Sat, Jul-28-2018, 08:11:40 PM   #1
yabmane
yabmane's Avatar
Reputation: 0 yabmane is on a distinguished road
Default HELP -Need Test Only Smog Check station without visual inspection
Any one know any Smog Check test Only Station without doing visual inspection in the bay area? I failed visual for euro header and cats.
1993 Integra Hatchback - Original Owner - Got stolen....
2005 E46 AW M3
Mod Lists:
ICONZ CSL diffuser, 19x8f, 19x9.5r OEM ZCP,
KW v3, Vibra-Tech engine and transmission mounts
Full Beisan Vanos
Euro Headers and CATS
Jump to top yabmane is offline   Reply With Quote
Old Mon, Jul-30-2018, 01:48:58 AM   #2
simon_c
Reputation: 0 simon_c is on a distinguished road
Default Re: HELP -Need Test Only Smog Check station without visual inspection
wow they actually knew the difference between euro headers/cats vs. stock? What shop is this so I can make sure to avoid them lol.
2004 M3 - Alpine White | Impluse Cloth | 6MT
2002 M3 - Alpine White | Cinnamon | 6MT (past)
Jump to top simon_c is offline   Reply With Quote
Old Mon, Jul-30-2018, 07:41:52 PM   #3
TheGenius46M
TheGenius46M's Avatar
Do you have your stock heatshields installed over the headers? If so you should pass unless they’re looking under the car and at that point you just leave lol
2003 E46 M3 TiAg/Cinnamon 6MT
Karbonius | MCS | Volk | Recaro | OMP | Hyperco | Ground Control | Besian | AKG | Schroth | Bimmerworld | Turner | PFC | CSF | SuperSprint | Radium Engineering |
Bay Area/ Nor Cal Coding and DME Tuning Specialist. PM for inquiries.
Old Sat, Aug-04-2018, 01:10:54 AM   #4
yabmane
yabmane's Avatar
I don't have heat shield cover the headers.
2005 E46 AW M3
Mod Lists:
Full Beisan Vanos
Old Sat, Aug-04-2018, 01:26:57 AM   #5
Kwakjoe
Kwakjoe's Avatar
Then the shop can easily see that you have aftermarket headers. Get heatshields and re-do. Passing visuals should be the easiest part imo.
Old Sat, Aug-04-2018, 01:29:28 AM   #6
yabmane
yabmane's Avatar
Do you know where I can get one?
2005 E46 AW M3
Mod Lists:
Full Beisan Vanos
Old Sat, Aug-04-2018, 01:32:02 AM   #7
Kwakjoe
Kwakjoe's Avatar
https://www.realoem.com/bmw/enUS/sho...diagId=11_3015
Part #3. I'm sure you can find it cheaper somewhere though.
Old Sat, Aug-04-2018, 04:20:08 AM   #8
mrgizmo04
mrgizmo04's Avatar
Realoem doesn't sell directly, they just show original list prices. Do a Google search for the part number, or go to your favorite source like fcp euro, Turner, thebmwminipartstore.com, bmwdiscountparts.com, etc to buy.
'85 528e 164k miles (sold)
'05 M3 6MT coupe
Discussing HELP -Need Test Only Smog Check station without visual inspection in the Pacific Forum - For events in California, Idaho, Nevada, Hawaii, and Alaska. at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
