Old Fri, Feb-16-2018, 12:09:56 AM   #21
erickrayos
Default Re: S54 exhaust upper chain guide solution
I need to replace my cam bolts and just placed the order for this and the seals as well. might as well do them while I am at this vanos lol
Old Fri, Feb-16-2018, 12:50:47 AM   #22
bimmerfan08
bimmerfan08's Avatar
Glad to see your project come to fruition Raj and the forum have access to another solution over OE. Seems forever ago that we were having those initial technical discussions. Thanks for the shout-out.
Old Fri, Feb-16-2018, 02:27:44 AM   #23
M3_#67
Reputation: 0 M3_#67 is on a distinguished road
Good to see you got them in production Raj! I was lucky enough to get one of early test units from a couple years ago.
'02 Imola Red on Black
Jump to top M3_#67 is offline   Reply With Quote
Old Fri, Feb-16-2018, 12:45:45 PM   #24
FK
Dammit. Had my vanos done two years ago lol
Old Fri, Feb-16-2018, 12:59:50 PM   #25
bmwahba39
bmwahba39's Avatar
Reputation: 0 bmwahba39 is on a distinguished road
Awesome. Ordering everything now to do the rebuild. What do you guys recommend for an exhaust hub, if needed?
Jump to top bmwahba39 is offline   Reply With Quote
Old Fri, Feb-16-2018, 05:02:56 PM   #26
aznniche
aznniche's Avatar
Are their any symptoms if this is broken? I haven't seen any discussion about this.
Old Fri, Feb-16-2018, 05:03:58 PM   #27
They're all broken by 75,000 miles, from cars I've opened up.
Most are broken by 50,000 miles.
Old Fri, Feb-16-2018, 05:04:47 PM   #28
Not sure what you're asking...?
The beisan exhaust hub is a great way to go.
Old Fri, Feb-16-2018, 05:18:24 PM   #29
bmwahba39
bmwahba39's Avatar
I didn't see that Beisan made a replacement/reinforced exhaust hub? It looks like TurboToys and Dr.Vanos makes one?
I'm just generally confused, thanks for your help!
Old Fri, Feb-16-2018, 05:26:02 PM   #30
natty99
Heeeeyyy
natty99's Avatar
Reputation: 0 natty99 is on a distinguished road
Dr. Vanos (cryo-treated) or stock (non-treated) hub with Beisan re-drilled disk
2005 BMW M3 ZCP 6spd, black on black
ENGINE: DINAN TBs | VAC Motorsport pulleys
EXHAUST: SS Stepped V1 Headers | SS race cats | SS resonated X-pipe
SUSPENSION/CHASSIS: Moton Street Sport S/A coilovers | Hyperco 450 front TCK 500 rear | GC Street camber plates (-2.4*F) | GC RSMs | RE weight jacks | TMS RTAB limiters | TMS RCAs (-1.4*R) | Mason Engineering Race FSTB | OEM front strut tower reinforcement plates | TMS rear subframe reinforcement
BRAKES: Brembo GT 6/4 monoblocks, 355 front 345 rear
WHEELS/TIRES: Volk TE37s in gloss white, 18x9.5 +22 (F) 18x10.5 +22 (R) | Michelin PSS 245/40 and 275/35
DRIVETRAIN: 3.91 BMW Motorsport
SHIFTING: AS 30% SSK | Illuminated ZHP | RE tranny mounts | GSP clutch pedal with UUC bushings | UUC "big boy" clutch stop | CDV delete | TMS SS clutch line
LIGHTING: Lightwerkz TFX retrofit | Digital 55w 4300K HIDs
INTERIOR: Euro first aid storage boxes
Jump to top natty99 is offline   Reply With Quote
Discussing S54 exhaust upper chain guide solution in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
