Old Mon, Mar-15-2010, 02:46:05 PM   #31
dsm918
dsm918's Avatar
Reputation: 0 dsm918 is on a distinguished road
Originally Posted by erc430 View Post
The hardest part was breaking the torx bolts loose with the wrench since I did not get much leverage from a short wrench and there was no room for a cheater bar.. Once the bolts are about half way out you can separate the starter from the bell housing with a small pry bar and it will pull the bolts against the bell housing again to give you room to finish loosening them.. The space is tight, but it can be done with a flat ratcheting torx wrench.. At first I tried to get a torx socket back there, but there was not enough room behind the bolts for that... Once I put the new starter in starting the bolts by hand was no problem. I used a e12 torx wrench from a set of blackhawk torx wrenches found on ebay.
Thanks. How many bolts hold the starter? 2? Also, where did you buy the starter from and for how much?
16 F80 AW/SO M3
09 E90 SG/Black M3
03.5 CB/Black M3
00 GSXR 600 (Track Star)
90 Nissan 300ZXTT
92 Eclipse GSX - 11.841 @ 117.11
Jump to top dsm918 is offline   Reply With Quote
Old Mon, Mar-15-2010, 03:14:09 PM   #32
erc430
erc430's Avatar
Reputation: 0 erc430 is on a distinguished road
There are 2 torx bolts that hold the starter. I got the starter from tischer for $237.12 with a $50 core charge refund. The part# is 12417835735...
Jump to top erc430 is offline   Reply With Quote
Old Tue, Mar-16-2010, 11:41:48 PM   #33
fiveride
Reputation: 0 fiveride is on a distinguished road
thank you for that unfortunately necessary information.
i just ordered.
Jump to top fiveride is offline   Reply With Quote
Old Wed, Mar-17-2010, 01:32:05 AM   #34
jald3rd
jald3rd's Avatar
Reputation: 0 jald3rd is on a distinguished road
Jump to top jald3rd is offline   Reply With Quote
Old Fri, Mar-26-2010, 02:21:53 PM   #35
dsm918
dsm918's Avatar
See 3/26/2010 update in first post.
16 F80 AW/SO M3
09 E90 SG/Black M3
03.5 CB/Black M3
90 Nissan 300ZXTT
Old Mon, Apr-12-2010, 03:27:45 AM   #36
Draddy
Draddy's Avatar
Reputation: 0 Draddy is on a distinguished road
This happened to me this morning. Went out to my car, had all power, but a turn of the key made no noise. I had to have someone push me so i could do a rolling first start. Pretty embarrassing. I guess I'll Be replacing my starter.
Any way we could have these pictures re-hosted for those of us in need of a diy? would be greatly appreciated!
My Car (sold) -- Old M3
Jump to top Draddy is offline   Reply With Quote
Old Tue, Apr-13-2010, 04:15:13 AM   #37
Michalek0915
04 M3 SMGII
Michalek0915's Avatar
Reputation: 0 Michalek0915 is on a distinguished road
Default Starter/Intake DIY SMG Question
Anybody know how to go about doing this DIY with an SMG since we have that reservoir on top of the intake that holds all the fluid with a hose connected at the bottom? I started tackling this job last night and Hit this road block towards the end of the DIY? Hope someone has some input.
Thanks
-Matt
Mods - Highline Intake System, VMR V715 19" Wheels, Agency Power Exhaust V2 W/Titanium Tips, Powerflex RTAB's & FCAB's, StopTech Stage 2 Brake Upgrade Kit W/Axxis Ultimate Pads & Slotted Rotors, CSL Half-CF Rear Diffuser, Front CF Lip, Koni Yellow Adjustable Shocks W/ Eibach Pro Springs, Depo Smoked Corners, Blackout Grille & Kidney Set, Umnitza Orion II Angel Eyes, Stealth Bulbs, Painted Reflectors, 30% Tint All Around, Blue LED Interior, Tennis Balls, JL Audio 500/1v2 Slash & Wicked C.A.S Enclosure W/ 12" W3v3.
Jump to top Michalek0915 is offline   Reply With Quote
Old Tue, Apr-13-2010, 04:48:25 AM   #38
PeteyyPab
So long M3, its been a trip!
Reputation: 0 PeteyyPab has disabled reputation
Italy
here friend:
http://www.m3forum.net/m3forum/showthread.php?t=262263
TOTALED: 3/20/2011 - I'll miss you M3, HELLO M5, Looking forward to the journey
In the cool still hours of night, you can still hear my subframe pulling away and my VANOS bolts backing out.
VERT Subframe mount failure confirmed 5/4/2010
Current Fleet:02 M5 Carbon Black - 11 335d M-Sport Alpine White - 89 750iL Salmon Silver - 69 F-100 Ranger Peacock Blue
The ones that got away:02 M3 Vert Jet Black - 04 A4 3.0 Quattro Brilliant Black - 77 Mercedes-Benz 300D Milan Brown Metallic - 02 Range Rover Java Black - 84 Mazda 626 Diesel
Jump to top PeteyyPab is offline   Reply With Quote
Old Tue, Apr-13-2010, 07:21:09 PM   #39
pachieh
Reputation: 0 pachieh is on a distinguished road
It's one more hose to unhook. That's it. Unplug it from the intake manifold, that's it. It is self sealing, so don't worry about losing fluid. Once it is out, you don't have to worry about working around the SMG system. It's not required to work around for the starter.
I just did my starter the other day and I have SMG. It's quick and easy. Have fun getting the hose clamps for the throttle bodies back on though. That was annoying.
Jump to top pachieh is offline   Reply With Quote
Old Tue, Apr-13-2010, 09:11:26 PM   #40
Michalek0915
04 M3 SMGII
Originally Posted by PeteyyPab View Post
You're a Life Saver!!!
For anyone doing this with SMG just be sure to have a bottle of the hydrolic fluid on hand and be careful when pulling that hose off the bottom of the intake. I used a flex hosed funnell to capture the majority of the fluid and re-filled 50/50 with the existing fluid and the new fluid.
Also, For cleaning the throttle bodies, i used STP Throttle Body & Air intake cleaner and let it soak for a few minutes after spraying on all areas of the throttle bodies and the contaminents will come off like dust with a quick swipe of a rag. For the intake horns, I used simple green as some did above and just an FYI for anyone considering using a detail spray or anything, DON'T. This is because wax compounds are good for a slick shiny surface that would seem to ease airflow but in this case wax creates a sort of static electricity and will attract more dust to the intake horns which you don't want. Hope this makes sense and thanks again for the great DIY.
-Matt
car, cleaning, cleaning>>>, diy, diystarter, intake, intermittent, issue, issuecomplete, removal, replacement, starter, starting, terminal
Discussing Intermittent Starting Issue-Complete DIY-Starter Replacement (Intake Removal) in the Faults, Fixes and DIY Forum - Please share your experience and knowledge with other members by contributing your own DIY, or by helping another member find the elusive fix! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
