Old Tue, Jun-03-2014, 06:10:13 AM   #11
LAWLence
N15 Design
Reputation: 0 LAWLence is on a distinguished road
Default Re: Raising idle RPM
K_LFR_NSOLL_AC
Under what running condition would this variable be applicable? I had the values only in the temperature to idle speed maps changed to my desired RPM (above 950), and the car has been idling at that since without having changed the above without any problems.
Jump to top LAWLence is offline   Reply With Quote
Old Tue, Jun-03-2014, 06:35:03 AM   #12
kaiv
SoCal S54 specialist :P
kaiv's Avatar
France
Thanks guys!
Lawrence pointed me to 0x43E4 where there's 03E8 0398 0366 0366 (1000, 920, 870, 870 rpm, respectively).
At 0x43CA I only find one value (0366) I guess that's normal SliM3's post.
Curious to know about the 950+rpm deal too. I need ~1030-1040rpm
Thanks again!
E46 ///M325i Touring journal
Old Tue, Jun-03-2014, 11:01:34 AM   #13
SliM3
SliM3's Avatar
It's the target idle value used during pre-drive checks, referenced when running some tests in DIS/INPA, as well as, some idle sync and adapt procedures. Best to keep everything consistent even though things are running fine with just the map values changed.
For idle values 950+ you also need to adjust the starting target rpm. This is the initial 1100-1300 rpm jump when you first start the car, before it settles into its target idle; All referenced via engine temps.
@185F eng temp the starting RPM is 950, so if this is your target idle value I'd change this to 1050 or something like that (+80rpm). Maybe bump up the 86F / 1100 to 1200.
Code:
Idle Speed Control_TARGET ENGINE SPEED START  KL_LFR_NSOLL_START
F eng temp /// RPM
-22 /// 1300
86 /// 1100
185 /// 950
Old Tue, Jun-03-2014, 03:09:48 PM   #14
LAWLence
N15 Design
Code:
F eng temp /// RPM
-22 /// 1300
86 /// 1100
185 /// 950
I needed a target value of around 1070RPM to minimize vibration. Is there any reason to set the idle any higher than that if it's already higher than the stock values? I imagine the higher idle speeds are there at the lower temps simply for a quicker warm-up.
Old Tue, Jun-03-2014, 03:48:44 PM   #15
SliM3
SliM3's Avatar
Default Raising idle RPM
There's no problem with your target idle speed selection, as you know what's best for your set-up; However the map I posted above is not your idle speed per-se. It's the initial controlled engine start speed that compensates for the large fuel pulses required at lower temps.
The 950rpm value is pretty much in the area of 'repeated hot starts', so that's the number you need to change if your target idle is 1070rpm. Can't have initial start lower than target idle or you'll probably get some sort of hunting every time you 'hot start' the car. It might even have an affect on your idle sync as well.
Hope that makes sense.
///M3 '06 Carbon Black
-Benjamin Franklin
- Fuel adaptations explained
- Checksum Verification
Old Tue, Jun-03-2014, 04:25:23 PM   #16
LAWLence
N15 Design
Very valuable info, thanks! Now that I think about it, there is some degree of hunting on hot starts. It only happens for a second or so, but that makes perfect sense as the cause.
Old Wed, Jun-04-2014, 01:19:50 AM   #17
kaiv
kaiv's Avatar
France
Fantastic info! Thanks!
Old Wed, Jun-04-2014, 01:34:50 AM   #18
kaiv
kaiv's Avatar
France
So let me get this right. We have:
Idle Speed Control_TARGET ENGINE SPEED w/AIR READINESS K_LFR_NSOLL_AC - 0x43CA
1 value for 'standard' idle (?)
Idle Speed Control_TARGET ENGINE SPEED - BASEK_LFR_NSOLL_GRUND - 0x43E4
4 values for 'standard' idle based on temperature
Idle Speed Control_TARGET ENGINE SPEED START KL_LFR_NSOLL_START -
3 values for start-up idle based on temperature
Am I getting this right?
What offset is that last one ?
Old Wed, Jun-04-2014, 01:42:21 AM   #19
Mozgov
Because Rasp Car
Mozgov's Avatar
Reputation: 0 Mozgov is on a distinguished road
Is this possible to program if I already have an evolve tune? I contacted them to raise my idle to 1k because I have the Bimmerworld engine mounts with N/V at idle. They sent me a new file however my idle is not sticking at 1k. Am I understanding correctly that there are multiple idles that need to be programmed.
Jump to top Mozgov is offline   Reply With Quote
Old Wed, Jun-04-2014, 02:02:14 AM   #20
kaiv
kaiv's Avatar
France
Yes Adam, it can be done regardless of tune. It's just a matter of tweaking some parameters and reflashing the car. I can help you do it if you want!
Discussing Raising idle RPM in the Coding and Tuning Forum - Discuss all avenues of coding and tuning here! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
