Old Wed, Oct-03-2018, 01:37:28 PM   #121
nextelbuddy1
nextelbuddy1's Avatar
Default Re: Converting an MSS54HP into an MSS54HP CSL (H-bridge)
There isnít one. The part they recommend is a different pinout altogether.
The MC33886, might work, though itís diagnostic functions are a little different. Maybe could build a little adapter PCB for other h bridges.
damn this sucks. I am just now feeling comfortable to try this since I got my new soldering station with a adjustable heat flow gun with assortment of attachment of tips. was going to start practicing desoldering chips and resoldering with older paste and heat flow.
Kassleperformance still offers this service so i wonder where they get their h bridges from. I may hit up Chris to see if he does this as well.
2003 ZHP 332i | S54 6 speed | M3 Conversion
Old Wed, Oct-03-2018, 02:38:10 PM   #122
They may have just bought sufficient quantities to not worry about it for now. Or they're using Chinese replicas. I've personally had bad luck with them (to the extent that one actually permanently damaged one of my DMEs), but perhaps some are okay.
Also you need some serious heat to get the solder underneath to flow - the little soldering station is not sufficient (at least without preheating the board and such)
Old Wed, Oct-03-2018, 06:05:46 PM   #123
nextelbuddy1
well poop
this was the soldering station i got on amazon.
  • Specifications:
  • Voltage: 110V/AC:
  • Storage Environment: -20~80įC:
  • CE approved:
  • Power Consumption: 270W (Max.)
  • Pump: Diaphragm Pump
  • Capacity: 24L/min (Max.)
  • Leakage Voltage of Iron Tip: <0.5mV Standard Iron Tip: AT-900M
  • Hot Air Temperature: 100 to 480C
  • Tip of Iron Temperature: 200 to 480C
so far it has fit the bill for soldering TIP usage as well as voltage usage.
i was going to crack open a used non M cluster I had and give my try at removing the M35080 chip in it as practice run and resoldering it back to the board with intact legs and solder paste.
Old Wed, Oct-03-2018, 08:33:04 PM   #124
well poop
F2C 853d SMD DC Power Supply Hot Air Iron Gun Rework Soldering Station (mode #8) - - Amazon.com
  • Specifications:
  • Voltage: 110V/AC:
  • CE approved:
It's fine for stuff like the M35080. Problem with the H-bridge is it has a metal plate underneath its body that's meant to be soldered to the ground plane of the PCB so that it can use the PCB as a heatsink. That means you need quite a bit of heat to loosen the solder
Old Thu, Oct-04-2018, 04:57:42 AM   #125
nextelbuddy1
ok well thank you
Old Fri, Oct-05-2018, 07:12:27 PM   #126
R3Z3N
E30 S54
R3Z3N's Avatar
Reputation: 0 R3Z3N has disabled reputation
We use this at work, and it's amazing. We sold our Hakko...
Jump to top R3Z3N is offline   Reply With Quote
Old Fri, Oct-05-2018, 07:48:41 PM   #127
Huh, that price isn’t terrible either
Old Tue, Oct-09-2018, 12:01:52 AM   #128
NZ_M3
Reputation: 0 NZ_M3 will become famous soon enough
Couldnít one theoratically substitute soldering with silver paste instead of solder under the chip for heatsink??
Jump to top NZ_M3 is offline   Reply With Quote
Old Tue, Oct-09-2018, 12:22:21 AM   #129
Probably. It won't conduct as well as solder, but might be good enough. Or possibly a low melting point solder like ChipQuick would be fine for the underside.
Old Mon, Nov-05-2018, 06:12:33 AM   #130
NZ_M3
Has anyone tried the Bosch 30348??
It is suppose to be a replacement for the Freescale
Discussing Converting an MSS54HP into an MSS54HP CSL (H-bridge) in the Coding and Tuning Forum - Discuss all avenues of coding and tuning here! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
