Old Tue, Aug-15-2017, 05:06:10 PM   #11
BearDeXPS
BearDeXPS's Avatar
Default Re: 100 Degree Day - Car overheards 3/4 mark with AC on.
100*F is my coolant systems tipping point. And everything's new/upgraded.
Old Tue, Aug-15-2017, 05:34:30 PM   #12
malacai17
Reputation: 0 malacai17 is on a distinguished road
I'm having nearly the same issue as the OP:
* my temp will actually go all the way up into the red if I don't shut off the AC
* I have replaced the fan clutch within the last 30 days
* the radiator, water pump, thermostat, temp sensor, and hoses were replaced by the PO ~2 years/30k miles ago
* there are a few white splatters below the upper radiator hose connection to the radiator
- I suspect either a hairline crack in the radiator's plastic tank, or that the coolant is boiling and leaking out
* a coolant drain and fill (not a power flush) has also been done within the last 30 days
Note: Without running the AC, I haven't been able to get the needle to move above the middle during DD or AutoX (haven't been to the track yet though).
I'm thinking about going the route of the Mishimoto radiator + Mishimoto electric fan (w/ probe), and I'll replace the thermostat at the same time too. I've read all about the previous Mishimoto radiator's problems, and have also read about folks using the redesigned unit with good success. Any other suggestions (other than the obvious $$$Zionsville)?
Thanks!
Jump to top malacai17 is offline   Reply With Quote
Old Tue, Aug-15-2017, 05:35:44 PM   #13
HassanEido
HassanEido's Avatar
Lebanon
If everything checks out, blow compressed air thru ur rad fins, from to back and vise versa. A ton of dirt and sand will puff out, and it will not go past the middle again. That said, in your case, it's possibly a bad clutch fan to begin with
Mods:
-Custom CF airbox
-Cat Cams 280 272.
-Custom dyno tune
385.7 whp 288 wtq
Old Tue, Aug-15-2017, 05:45:36 PM   #14
WOLFN8TR
/// MONEY \\\
WOLFN8TR's Avatar
I'm thinking about going the route of the Mishimoto radiator + Mishimoto electric fan (w/ probe).
If you are having over heating issues now this will not fix the problem, unless your stock radiator is bad. The stock mechanical fan moves way more air than the Mishimoto fan does. Is your Aux fan working?
Old Tue, Aug-15-2017, 06:15:47 PM   #15
malacai17
I believe it is working, yes; I see it spin when the AC is on and it feels like it's moving air well. Is there a test like the one for the fan clutch? Since it's an electric fan I wasn't sure.
The coolant temperature increases when driving at higher speeds, and decreases when moving slowly or stopped. That points towards radiator, right?
Old Tue, Aug-15-2017, 07:40:37 PM   #16
akagc
Reputation: 0 akagc is on a distinguished road
Never experienced this. I'm in FL with 90-95 degrees in avg summer temps + high humidity. Never seen the temp gauge go past the half way point in 3 years of ownership. You might have an underlying cooling or A/C issue. Get it checked by a pro just to be sure.
- 04 Silver (tiag) ZHP 330i
- 06 Silver Grey ZCP M3
- 02 Black Civic. Beater
Jump to top akagc is offline   Reply With Quote
Old Tue, Aug-15-2017, 09:32:30 PM   #17
WOLFN8TR
/// MONEY \\\
WOLFN8TR's Avatar
The Aux fan is pretty loud when running full speed at idle when the temps call for it. It does sound like a radiator issue. Have you tried bleeding the system lately?
Old Tue, Aug-15-2017, 09:51:12 PM   #18
lmtfi
lmtfi's Avatar
Thats not right. I have run track days at exactly 99 and 100F with heat soaks far more than one can see on the street - with zero temp climb above middle range.
You should find the cause of your temp climb.
Old Wed, Aug-16-2017, 01:21:38 AM   #19
EricSMG
40 something
Overheating is not normal - the needle should literally never move or something is wrong, excluding extreme circumstances. 10 years, 5 of these cars, never had the need,e move above straight up. Needle should never, ever climb past middle.
Regarding the AUX fan - there is no test required, only listen. When it's on its LOUD, even at less than full tilt. Pull into your garage with the windows down with AC on and shut off motor - if you don't hear a very distinct fan noise your fan ain't workin. Hell just stand next to the car with motor and AC on......mega fan noise should be obvious.
Oil temp will climb, normal.
2004 E46 M3 6MT SG/Black
Old Wed, Aug-16-2017, 04:17:57 AM   #20
///M3 NA
Reputation: 0 ///M3 NA is on a distinguished road
I had this issue in the beginning of the summer and responded to another thread. The issue is likely your fan clutch !!!
Start up your car, get a magazine, open your hood, try to stop the fan with the magazine. It will either stop or shredd it. If the fan stops, your clutch is toast.
After replacing my fan clutch with a Sachs brand(don't get Behr), my coolant temp is dead in the middle with 110 degrees. Prior to the new clutch above 95 with AC on, the temp would creep up.
99% certain its your clutch.
Evolve
Evolve Eventuri
AutoSolutions SSK 30%
RE Transmission Mounts
CDV Delete
Intravee II
Jump to top ///M3 NA is offline   Reply With Quote
Discussing 100 Degree Day - Car overheards 3/4 mark with AC on. in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
