Old Wed, Apr-17-2019, 07:06:14 PM   #31
Maddin
Reputation: 0 Maddin is on a distinguished road
Germany
Default Re: AVIN AVANT 2 issues thread (new for 2019)
Here is the answer from avinusa.
The Avant2 system was developed over 7 years ago and has been discontinued for many years now. There are no new software updates for it. Disconnect the GPS antenna from the radio. The GPS IC chip inside the radio might be causing the issue. Then perform a factory restore on the unit. This should get the radio working again minus GPS. Our newest system has the latest GPS IC chip and is not affected by this bug. We are offering the all-new units to previous Avant owners for only $349.99.
In this case i think about this offer........ but i am not sure
Jump to top Maddin is offline   Reply With Quote
Old Fri, Apr-19-2019, 03:59:52 PM   #32
1/2past3ci
Reputation: 0 1/2past3ci is on a distinguished road
I have disconnected the GPS antenna and while this has fixed the rebooting issue, Iím having trouble using any of the apps and radio. I did the factory reset by pressing the power button 8 times then holding it. It went through the reset. Then installs 17 preloaded apps. Then I get nothing. Anyone know what to do from that point?
Wes
Jump to top 1/2past3ci is offline   Reply With Quote
Old Fri, Apr-19-2019, 06:30:37 PM   #33
norcal420
mass nerder
norcal420's Avatar
Reputation: 0 norcal420 is on a distinguished road
That's weird. I followed the same procedure and it works fine now (minus GPS of course). I did order the Avant4 so I'm prepared to throw the '2' in the dumpster soon.
Jump to top norcal420 is offline   Reply With Quote
Old Sat, Apr-20-2019, 03:19:31 AM   #34
1/2past3ci
So my Avant 2 is junk. Disconnecting the GPS antenna stopped the rebooting but the apps wonít load. Honestly, I just want a radio, Bluetooth stream capable head unit and the less work to install the better. Anyone getting rid of a working Avant 2 or 3 let me know. I know I can buy the Avant 4 brand new for $350 but it would require running new cable since my car is factory navigation. Really would like plug and play to my Avant 2 set up.
Wes
Old Sat, Apr-20-2019, 08:44:31 PM   #35
Cincinnati Wolf
Cincinnati Wolf's Avatar
Reputation: 0 Cincinnati Wolf is on a distinguished road
If I were to replace my Avant 2 with a Avant 4, are all the wiring hookups the same? Does the new unit have as good or better sound processing. The Avant 2 with speaker upgrades was amazing. The ability to adjust all the finer sound processing controls made a huge difference over the stock NAV head unit.
2006 M3 Coupe 6M, Japan Rot Individual, CSL 19" wheels 275 x 245 Michelin PSS, TC Kline SA Koni w/H&R Sport Springs, aFe Stage 2 Intake, AS 20% SSK, Rogue Transmission Mounts, Avin Avant 2
2001 M3 Coupe 6M, Carbon Black, EC-7 9.5-18 ET35 with 265-35 square, 4.10 Diff, MCS 2WNR- Hyperco, Kirk Cage, Racetech 4009WHR, OMP 6pt Harness, aFe Stage 2, Stoptech BBK, TMS reinforcement
Jump to top Cincinnati Wolf is offline   Reply With Quote
Old Sat, Apr-20-2019, 08:45:56 PM   #36
1/2past3ci
If your car had OEM navigation you need to run new cable to the trunk.
Wes
Old Sun, Apr-21-2019, 10:39:05 AM   #37
GrendelsbaneM3
GrendelsbaneM3's Avatar
Reputation: 0 GrendelsbaneM3 is on a distinguished road
I suppose there is no place that can fix these things, right?
2004 Silver M3 / SMG / TC Kline DA Coilovers / Eibach front and rear sway bars / Proflex bushings / Predator Orion V2 Multi-Color LED Angel Eyes / ALPS Jammers / Clear Bumper Reflectors / Zionsville Competition Cooling Kit with Offset Fan / AKG Motor mounts / Rogue Engineering Transmission Mount / AKG differential bushings / Euro mirrors / B&B Exhaust / CSL SMG tune /DME CSL tune / ESS 575 Supercharger / Stillen AP Racing BBK / J-Fiber Carbon Fiber Driveshaft
Jump to top GrendelsbaneM3 is offline   Reply With Quote
Old Sun, Apr-21-2019, 05:29:14 PM   #38
1/2past3ci
From the sounds of it, the repair is more costly than the price of a new Avant4.
Wes
Old Tue, Apr-23-2019, 04:32:48 PM   #39
andrewrivera141
Reputation: 0 andrewrivera141 is on a distinguished road
It really should be a disconnection of the antenna in the back and that's it.. I'm able to use all my applications but I haven't signed into the store to use THOSE applications if that's what your trying to do
Sent from my Pixel using Tapatalk
Jump to top andrewrivera141 is offline   Reply With Quote
Old Tue, Apr-23-2019, 05:55:04 PM   #40
I M Legend
Does your GPS work?
Sent from my R1 HD using Tapatalk
Discussing AVIN AVANT 2 issues thread (new for 2019) in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
