Go Back   BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X) > M3Forum Garage > Forced Induction (F/I)
Forced Induction (F/I) Discuss the ever growing F/I options here!
Old Tue, Feb-14-2017, 01:37:37 AM   #71
Nicholas1996
Reputation: 0 Nicholas1996 is on a distinguished road
Greece
Default Re: The Official Supercharger Kit Maintenance/Replacement Parts Thread (VF, AA and ES
I believe this is the AA belt for C38 blowers with 85mm pulleys. (Prima and Prima Plus)
https://www.napaonline.com/en/p/NBG25060874
Topaz Blau
PTE 6266 on E85
AEM Infinity
Tuned by Ian @Bend Calibration
Jump to top Nicholas1996 is offline   Reply With Quote
Old Wed, Mar-01-2017, 03:11:55 AM   #72
toy4to
Lemonade Tycoon
Reputation: 0 toy4to is on a distinguished road
Active Autowerke Serpentine Belt for Gen 9 C38-92 kits: Gates K080872 or K080872HD (green stripe) $35-45 on amazon
Serpentine belt for Gen6 HKS 8550 kits: Gates K080893 or K080893HD.
Idler bearing/pulleys: Koyo PU355816RR9D ($20 from amazon).
Jump to top toy4to is offline   Reply With Quote
Old Wed, Mar-22-2017, 03:43:50 AM   #73
jbguillo
jabroni
jbguillo's Avatar
Reputation: 0 jbguillo is on a distinguished road
Does anyone happen to know the part numbers for the two idler pulleys on the VF kit? Apparently one is smaller than the other. Any clarification on this would be greatly appreciated.
-jb
Jump to top jbguillo is offline   Reply With Quote
Old Fri, Nov-03-2017, 06:57:52 PM   #74
iturnright
Reputation: 0 iturnright is on a distinguished road
I'm so glad I found this thread. recently bought a AA supercharged M3 and this will be a lot of help. Thanks OP.
I hope this is a worth-while contribution. I've been looking to replace the mangled air filter thats on the turbine. I did some research and it looks like I found a K&N and Green filter that fit. I listed both because I'm under the understanding that AA used to use K&N and now use Green and we're trying to keep this limited to brands that came with the kits. I'm not 100% on these but someone could chime in if you know for sure.
K&N: RU-3130 ~$36 on amazon
Green: 7124 ~$35 on amazon
Jump to top iturnright is offline   Reply With Quote
Old Sat, Dec-23-2017, 01:13:30 AM   #75
selflove
selflove's Avatar
Reputation: 0 selflove is on a distinguished road
Does anyone know of a message thread like this (or other web page) for the e36 M3 AA kits?
Jump to top selflove is offline   Reply With Quote
Old Mon, Jul-09-2018, 02:24:12 AM   #76
mills84
Reputation: 0 mills84 is on a distinguished road
https://www.amazon.com/RU-3130-Unive.../dp/B00029WZWU
https://www.amazon.com/Green-Filter-.../dp/B00DDTNPCA
The K&N: RU-3130 does NOT fit the HKS blower.
Jump to top mills84 is offline   Reply With Quote
Old Sun, Jul-22-2018, 08:49:03 PM   #77
Goose81
Reputation: 0 Goose81 is on a distinguished road
Originally Posted by WyattH View Post
Cool thread, can't believe I haven't seen it before.
I am approaching 24K on the Dinan Supercharger System and am replacing the pulley, belt, and tensioner. $280 from Dinan, which seems high, but supposedly expected with them. Not bad for maintenance overall though, if it's jut this every 25-30K, air filter services, and more frequent OCIs.
Going forward, I am wondering if anybody know what other kit this System would be most similar to for purposes of maintenance? I believe it's a Vortech blower (non-intercooled, 4.5psi, shared oil). Any idea when a rebuild may be necessary, or if there is any other component that can/should be serviced?
Did you ever get an answer for this?
Jump to top Goose81 is online now   Reply With Quote
Old Mon, Sep-10-2018, 09:39:42 PM   #78
Turb02
Turb02's Avatar
Reputation: 0 Turb02 is on a distinguished road
What is the recommended spark plugs for the AA Rotrex setup? I searched the thread and cant find where its mentioned. Gap would be awesome to know as well.
ModeGrau Respray
Active Autowerke Gen3 Stage 2.5 C38-91-AA Headers-Supersprint-Meisterschaft-Vorsteiner-Brembo-AC Schnitzer-BBS-CSL
6MT swapped-RTD shifter-Amber Gang-Dual port Aquamist-Advanced Fuel Dynamics E85-CMP Auto Engineering topside subframe reinforcement-Redish v2 plates
Jump to top Turb02 is offline   Reply With Quote
Old Thu, Jul-25-2019, 09:24:06 PM   #79
Silwer
Reputation: 0 Silwer is on a distinguished road
Estonia
I have older type VF570 kit. And my blow off valve is not working. Any ideas what BOV will be direct fit?
Unfortunately I do not have better photo about my valve than this: https://drive.google.com/file/d/1UoJ...w?usp=drivesdk
Other question is related to the V3 supercharger dipstick and pressure release valves - the ones I have have been heavily abused by turning them with wrong tools. I would need replacements - what is the best place to source Vortech V3 parts?
Jump to top Silwer is offline   Reply With Quote
Old Thu, Jul-25-2019, 10:41:53 PM   #80
ILLuSioNz X
Built, not bought
ILLuSioNz X's Avatar
Reputation: 0 ILLuSioNz X is on a distinguished road
You have the Greddy type r bov on your setup. Before you swap it, make sure youre getting adequate vacuum to the BOV and the check valves are installed in the correct direction. You can replace it with either the same one or upgrade to a tial q bov (theres threads on this).
The dipstick gave me the same issues, Id suggest contacting Vortec for a replacement
-Chauncey
2003 E46 M3 COUPE
Engine/Transmission: "Bolt-on's"
Wheels/Tires: 18 TE37SL & Falken RT615K
Suspension: TRM Coilovers 780F/895R|OEM Front & Turner Rear Reinforcement Plates|RE Rear Spring Perch Reinforcement|GC Race FCABs|GC Monoball RTABs|Godspeed LCAs|Turner Monoball Upper CAB|Turner Sway Bars|Turner Subframe Reinforcement (installed by Coinage)|Turner Solid Subframe, Differential, Motor and Transmission Mounts
Braking: Rotora 4-Piston Calipers|S/S Lines|Ate Dot4|Powerslot Rotors|Ferodo DS2500 Brake Pads
The Official Supercharger Kit Maintenance/Replacement Parts Thread (VF, AA and ESS)
Jump to top ILLuSioNz X is offline   Reply With Quote
Discussing The Official Supercharger Kit Maintenance/Replacement Parts Thread (VF, AA and ESS) in the Forced Induction (F/I) Forum - Discuss the ever growing F/I options here! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
