Old Sat, Apr-20-2013, 04:36:08 PM   #11
ROASTM
Reputation: 0 ROASTM is on a distinguished road
Default Re: Clutch Free Shifting
"Granny shifting, not double-clutching like you should."
- Vin
Jump to top ROASTM is offline   Reply With Quote
Old Sat, Apr-20-2013, 04:53:06 PM   #12
Mmradix
Reputation: 0 Mmradix is on a distinguished road
I drove a semi for 3 years and was trained to use the clutch for every upshift and down shift. If you did this every day in traffic your left leg would be twice the size of your right leg in one week because the clutch is stiff. After a week I learned very quickly to rev match both up shifting and down shifting. Any experience semi driver will rarely use a clutch.
I would not try it in my M but have accidentally done it in my land rover defender, I believe as flow posted it is much easier in a low revving engine.
Jump to top Mmradix is offline   Reply With Quote
Old Sat, Apr-20-2013, 10:47:49 PM   #13
mpanella
I live for ///M
mpanella's Avatar
Reputation: 0 mpanella is on a distinguished road
I agree that in our cars there is no reason but I have a question for all you tranny (no pun intended) experts
Do you really need the clutch to disengage from a gear and go into neutral at speed? In otherwords going from let's say 3rd into neutral to stop at a light.
2005 Carbon Black Metallic / Cinnamon - RAC RG4's | Rogue | V-CSL Diffuser + Bootlid + Bumper |
| AR20 Rasp Elimination | TC Kline S/A| StopTech 4 POT F/R| Scorza CSL
Journal
Jump to top mpanella is offline   Reply With Quote
Old Sun, Apr-21-2013, 02:27:22 AM   #14
OpTics
OpTics's Avatar
Reputation: 0 OpTics is on a distinguished road
You can but make sure youre RMPs are low enough to put it straight into neutral, but not too low where it will stall while youre in gear.
For instance when driving in 3rd gear and you see your rpms at ~3500ish approaching a stop, Use breaks to lower rpm to about ~2000, clutch in, neutral, neutral/ brake into the stop.
but everyone has their own preference to driving MT. You can engine brake but i assumed you dont want that included in your scenario.
Lolss MAD
Jump to top OpTics is offline   Reply With Quote
Old Sun, Apr-21-2013, 07:38:34 AM   #15
M3an0ne
M3an0ne's Avatar
Reputation: 0 M3an0ne is on a distinguished road
i noticed theres a certain timing to doing this. im starting to wonder if that might be bad for the car but it doesn't seem like it would be... what i do is give the gas pedal a slight blip while in gear with light pressure on the shift knob towards neutral.. real light though, like not enough to feel any real pressure against it. and what seems to be happening is the engine isn't slowing down the car, so for a brief moment the engine is slowing down at the same speed the wheels are after the blip. when that happens the shift knob falls into neutral like butter. anyone try anything similar? thoughts on possible damage to the car? i do it just to save some life of the throw out bearing
Jump to top M3an0ne is offline   Reply With Quote
Old Sun, Apr-21-2013, 09:28:08 AM   #16
Flow
Flow's Avatar
France
You don't, but I would suggest there is no load on your gearbox (accelerating or decelerating using the engine). If you give it just slightly throttle, and do not force the gear out, you'll see it is very easy, and it will not hurt anything.
But I don't get the point of doing so?
2004 M3 TiAg / LSB SMG
Old Sun, Apr-21-2013, 10:57:17 AM   #17
adrianma
Reputation: 0 adrianma is on a distinguished road
Hong Kong
it can be done easily.. i do it on my mini all the time
that said i wouldn't try it on the M at such high revs
there is no sounds/clunks if you do it properly.
to start trying i would recommend to try pulling the 2nd gear out (into neutral) when you are rolling to a stop, do not let the drivetrain 'hang' on the gear... give it a little bit of gas at the same time your hand is pushing from 2nd up into N.. don't force it,,, it'll pop out with no effort. once you know what that feels like.. you can try experimenting...
this is a good watch.. in case you are interested.
its one thing to know how to do it.. but it is really pointless..
Jump to top adrianma is offline   Reply With Quote
Old Sun, Apr-21-2013, 05:06:12 PM   #18
vtn86
Reputation: 0 vtn86 is on a distinguished road
I used to do it a lot on my old hondas. Tried it once when I first bought the M. Couldn't do it for some reason. The gears seem to be "too tight".
Jump to top vtn86 is online now   Reply With Quote
Old Sun, Apr-21-2013, 05:10:04 PM   #19
///M_Achilles
"Visor down for business"
///M_Achilles's Avatar
Reputation: 0 ///M_Achilles is on a distinguished road
Watch this right now
2005 Carbon Black Metallic ///M3 SOLD
My Journal
2012 Porsche Cayman R
Jump to top ///M_Achilles is offline   Reply With Quote
Old Sun, Apr-21-2013, 11:24:43 PM   #20
E46Dinan
E46Dinan's Avatar
Reputation: 0 E46Dinan is on a distinguished road
Do it all the time. It's called SMG
2003 1/2 M3 coupe AW and LSB interior, 4.10's, Comp wheels, brakes, SMG unit. TMS reinf. AA exhaust, Powerflex, Koni, Eibach,etc..
2001 325CI Dinan 3 TS and IR M3 interior, 5spd sold
2001 M3 convert TS and Black interior,6 spd sold
1995 M3,5 spd sold
1986 635Csi, 5 spd sold
Jump to top E46Dinan is offline   Reply With Quote
clutch, no clutch
Discussing Clutch Free Shifting in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
