Old Mon, Nov-23-2009, 08:36:17 PM   #21
e46badboy
Reputation: 0 e46badboy is on a distinguished road
Originally Posted by doozyj View Post
I think the shudder is a common issue probably due to the software.
Really, why is that?
Jump to top e46badboy is offline   Reply With Quote
Old Mon, Nov-23-2009, 09:05:02 PM   #22
Crayola
Crayola's Avatar
Reputation: 0 Crayola is on a distinguished road
Taiwan
I think the shudder is a common issue probably due to the software and not because of the clutch.
that's good to know because I've been noticing this a lot too especially on inclines
Jump to top Crayola is offline   Reply With Quote
Old Mon, Nov-23-2009, 09:14:01 PM   #23
Michalek0915
04 M3 SMGII
Michalek0915's Avatar
Reputation: 0 Michalek0915 is on a distinguished road
Yeah the shuddering can go from very mild to very severe at times. sometimes when I start off in 2nd gear the shudder can last 3-5 seconds before the clutch engages entirely, but rest assured BMW told me and confirmed that this is completely normal as my car was recently in for service and everything checked out. Kind of annoying but common is what I've come away with.
Mods - Highline Intake System, VMR V715 19" Wheels, Agency Power Exhaust V2 W/Titanium Tips, Powerflex RTAB's & FCAB's, StopTech Stage 2 Brake Upgrade Kit W/Axxis Ultimate Pads & Slotted Rotors, CSL Half-CF Rear Diffuser, Front CF Lip, Koni Yellow Adjustable Shocks W/ Eibach Pro Springs, Depo Smoked Corners, Blackout Grille & Kidney Set, Umnitza Orion II Angel Eyes, Stealth Bulbs, Painted Reflectors, 30% Tint All Around, Blue LED Interior, Tennis Balls, JL Audio 500/1v2 Slash & Wicked C.A.S Enclosure W/ 12" W3v3.
Jump to top Michalek0915 is offline   Reply With Quote
Old Tue, Nov-24-2009, 02:24:29 PM   #24
e46badboy
Tell me something, how can software cause shudder?
Software has nothing to do with shudder AT ALL.
These are issue that may cause shutter on SMG trans.
A. Low clutch disc.
B. A bad clutch Slave
C. A bad SMG hydro pump.
D. SMG pump need to rebleed or maybe low hydro fluid.
If it had software issues then the SMG control unit would have recognize
d the problem likely be throwing gear position codes.
Old Wed, May-07-2014, 06:48:52 PM   #25
cbaty08
Reputation: 0 cbaty08 is on a distinguished road
Default Re: SMG Clutch
A. Low clutch disc.
I stumbled on this old thread, researching expected SMG clutch life.. and didn't want to leave this ending with this comment.
While I don't disagree those areas can cause problems, I am proof that it CAN be SW.
I opened up INPA and reset my SMG's brain... FELT LIKE A NEW CAR.
My presumption is that the computer measures tolerances, in this case the gap it perceives between the clutch and the pressure plate, and as the clutch wears thinner, it doesn't re-adjust for that increased gap.
If my presumption is correct, which my findings so far would agree with, then you CAN certainly get rid of this shudder with a hard SMG reset via INPA.
Jump to top cbaty08 is offline   Reply With Quote
Old Wed, May-07-2014, 07:22:50 PM   #26
Lola's Dad
Reputation: 0 Lola's Dad is on a distinguished road
What is INPA?
Jump to top Lola's Dad is offline   Reply With Quote
Old Wed, May-07-2014, 07:37:49 PM   #27
Winegums
Winegums's Avatar
Reputation: 0 Winegums is on a distinguished road
I need to get this done... the shudder is really annoying and I know it's not clutch slip from glazed pucks since it hooks up nice and solid on an S6 shift from 7-8K rpm.
Anyone know how much a dealer charges for an SMG reset? or if there's someone who can do this in the Fraser valley/lower mainland area?
"What's an M3, like a 328i or something?"
Jump to top Winegums is offline   Reply With Quote
Old Wed, May-07-2014, 07:38:27 PM   #28
sleeks
sleeks's Avatar
Reputation: 0 sleeks will become famous soon enough
Originally Posted by Lola's Dad View Post
What is INPA?
Check out the coding subforum.
I need to find the proper procedures for SMG reset via INPA and try it out on mine.
2002 ///M3 - Steel Grey/Black 6MT
Installed: Beisan / APEX / Dinan / PFC / Stoptech / Redish / Bimmerworld / AKG
Jump to top sleeks is offline   Reply With Quote
Old Thu, May-08-2014, 01:18:57 AM   #29
Zabalzae
Zabalzae's Avatar
Reputation: 0 Zabalzae is on a distinguished road
Mine has 124k reset via inpa and still shudder. Replaced along with flywheel and compression springs.
Jump to top Zabalzae is offline   Reply With Quote
Old Thu, May-08-2014, 02:03:50 AM   #30
Headlock
Reputation: 0 Headlock is on a distinguished road
mines at 97000km and going strong.
i have a shitty steep driveway to reverse out of every day and it performs like a champ, on my last car that was a MT it would be nearly impossible to reverse out of without frying the clutch. SMG does it no dramas
Jump to top Headlock is offline   Reply With Quote
clutch, smg
Discussing SMG Clutch in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
