Old Thu, Jun-19-2008, 03:53:48 PM   #1
///MPIRE
Reputation: 0 ///MPIRE is on a distinguished road
Default Clutch Replacement DIY
Anyone know of any clutch replacement DIYs ? Tried searching couldnt find anything regarding the topic.
Jump to top ///MPIRE is offline   Reply With Quote
Old Thu, Jun-19-2008, 09:00:01 PM   #2
SammyXp
SammyXp's Avatar
Reputation: 0 SammyXp will become famous soon enough
Subscribing. If no one can seriously find this then I'm taking pictures when I do my clutch, and then posting it on a website full of ads!
Jump to top SammyXp is offline   Reply With Quote
Old Thu, Jun-19-2008, 09:27:27 PM   #3
kiloil
kiloil's Avatar
Reputation: 0 kiloil is on a distinguished road
Do you have SMG?
2009 E92 M3 MT (Gone)
2011 4 Runner Limited 4WD (Gone)
1996 4 Runner 4WD (Too sendimental to get rid of)
2013 E92 M3 MT (Gone)
2015 25 SLX Sea Ray 8.2L Magnum Big Block.
Jump to top kiloil is offline   Reply With Quote
Old Thu, Jun-19-2008, 09:28:21 PM   #4
///MPIRE
Manual Transmission
Old Thu, Jun-19-2008, 09:35:18 PM   #5
905rMP32V1x
905rMP32V1x's Avatar
Reputation: 0 905rMP32V1x is on a distinguished road
Quick search yielded this for e36. Still looking for e46.
http://www.pelicanparts.com/BMW/tech...ch_Replace.htm
Jump to top 905rMP32V1x is offline   Reply With Quote
Old Thu, Jun-19-2008, 09:43:08 PM   #6
905rMP32V1x
Another source. Sounds like a PIA.
http://forum.e46fanatics.com/showthread.php?t=514381
Old Thu, Jun-19-2008, 09:44:33 PM   #7
nrubenstein
E46 is identical. In fact, the transmissions are even interchangeable. The differences are in the clutches, output flanges/driveshaft length, and shifting mechanism.
Seriously, the Pelican DIY is all that you need for the M3.
IMHO, the most annoying thing will probably be the starter. Everything else is reasonably accessible (even with the threaded starter, it's still a giant pain in the ass). I will freely admit that I have not actually done a clutch job on an E46 M3 (just an E30 325is, E36 M3, and E46 323), but it's all the same. Except for the intake manifold/throttle bodies, which are a hell of a lot harder to get out of the way if you're struggling with the starter.
Old Thu, Jun-19-2008, 10:14:55 PM   #8
RTannerM3
Reputation: 0 RTannerM3 is on a distinguished road
I did a clutch on an e39 m5 in march and to my surprise the biggest issue me and my friend had was dropping that 100lb exhaust!
It was about the same difficulty as an e36 m3 I'd say, so I'm assuming the e46 M3 shouldn't have many, if any, new surprises. Thankfully the exhaust is sectioned so you don't have to worry with that headache.
Goodluck
-Richard
2003 Imola BMW M3, no roof, non-powered cloth/leather seats, TCK S/As, CSL Style 19's, 4.10s, SS Race, blackout grills and gills, UUC SSK w/DSSR, UUC tranny mounts
Jump to top RTannerM3 is offline   Reply With Quote
Old Fri, Jun-20-2008, 04:27:17 AM   #9
thetunersource
Reputation: 0 thetunersource is on a distinguished road
Go for it. Change everything though, which includes bearings and bolts.
The Tuner Source
Jump to top thetunersource is offline   Reply With Quote
Old Fri, Jun-20-2008, 07:50:49 PM   #10
Eric Giles
Reputation: 0 Eric Giles is on a distinguished road
Goodluck
-Richard
That E39 M5 exhaust was a *****, wasn't it! Man, I hope that clutch assembly lasts a long time because I don't want us to have to drop that exhaust again.
As Nick has basically alluded to, if you've read one clutch DIY on a BMW, you have read them all. I have replaced clutches on E30's, E36's, and E39's and basically, they are all the exact same process. There might be an extra brace or heat shield to remove, but it's the same process overall.
If you have access to a lift, I highly recommend using it. If not, then having the car on jackstands will do-that is how I have done all but one clutch job. It's a ***** especially if you are above average size, but it is doable.
Eric Giles
'04 M3
'04 330i ZHP
'91 318is
Jump to top Eric Giles is offline   Reply With Quote
clutch, diy, replacement
Dinan Filter Replacement DIY? longms E46 M3 (2001-2006) 17 Sun, Feb-01-2009 04:16:46 AM
DIY SMG clutch replacement? Viper966 E46 M3 (2001-2006) 25 Sat, Oct-18-2008 07:02:20 PM
Diy Coolant Replacement bmrlvr E46 M3 (2001-2006) 2 Sat, Sep-15-2007 07:12:23 PM
AC belt replacement - DIY? blink21me E36 M3 (1992-1999) 2 Wed, Oct-11-2006 01:24:11 PM
Need tips on DIY belt replacement mighty-dog E36 M3 (1992-1999) 14 Thu, Jun-02-2005 05:46:17 PM
Discussing Clutch Replacement DIY in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
