Old Thu, Mar-08-2018, 12:42:51 PM   #1
Samersalheyeh
Reputation: 0 Samersalheyeh is on a distinguished road
Default Slow throttle response
Hello, i hope anyone can help in this, i have been experiencing a slow throttle response in my M3 and suddenly the EML light , ABS , and traction control lights come on , i have changed 2 TPS sensors the car got better , but still does the same problem from time to time specially after a long ride.
Example : i press on the gas paddle and 2 seconds later i get the power .
Is there any other sensor i have to change ? Because im getting no faults on the obd check.
Thank you.
Chassis : E46 M3
Model : 2005
Mileage : 152K KM
Jump to top Samersalheyeh is offline   Reply With Quote
Old Thu, Mar-08-2018, 02:14:59 PM   #2
Default Re: Slow throttle response
Use a BMW specific code reader or INPA.
There are codes if you're throwing lights-- your reader is just unable to read them.
Old Thu, Mar-08-2018, 03:22:13 PM   #3
burningchrome
Reputation: 0 burningchrome is on a distinguished road
Gas pedal (unless that's one you did). Next suspect is the throttle actuator.
Jump to top burningchrome is offline   Reply With Quote
e46, e46m3, s54
Discussing Slow throttle response in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
