Old Sun, Feb-24-2008, 10:49:52 PM   #11
tobes
tobes's Avatar
Reputation: 0 tobes is on a distinguished road
Originally Posted by daytonaviolet View Post
she's taking a break for now Michelle Monaghan is my new girl
Either way you have good taste
99 TiAG/Black/everything except for heated seats- (Sold)
03 TiAG/Grey/Premium/HK/Xenon (Sold)
- NAV retrofit
- OEM Sirius retrofit
- DICE IPod integration kit
- Bluetooth Retrofit
16 TZB/Amaro - in the works
Jump to top tobes is offline   Reply With Quote
Old Sun, Jan-25-2009, 10:56:47 AM   #12
bugiman
Reputation: 0 bugiman is on a distinguished road
biglar
Did you figure this out? I’m faced with the same problem..
Please anybody have pic on how to do this..
Jump to top bugiman is offline   Reply With Quote
Old Sun, Jan-25-2009, 05:56:14 PM   #13
daytonaviolet
OEM CSL Whoore
daytonaviolet's Avatar
if i find time today... i'll post a pic but do a search.. i posted a pic of this a while back.
Tischer aka GetBmwParts
Old Mon, Jan-26-2009, 10:13:36 AM   #14
bugiman
I searched all your posts (many) but I couldn’t find any pic of this removal. Can you repost the pic.
Thanks
Old Sat, Jan-31-2009, 01:56:10 PM   #15
bugiman
Pretty please with sugar on top Daytonaviolet post the pic or the link to the post where I can find the pic.
Old Mon, Apr-06-2009, 07:35:49 PM   #16
CharlieTX
Reputation: 0 CharlieTX is on a distinguished road
Arrow Summary
Is there a quick summary of the minimum steps required to remove the Nav Monitor? I am putting an Aux Audio jack on my '05 Vert. The instructions that came with the input simply say remove the monitor, refer to TIS for more information.
There seems to be LOTS of information for non navigation installations.
Thanks,
Charlie
Jump to top CharlieTX is offline   Reply With Quote
Old Mon, Apr-06-2009, 08:20:37 PM   #17
AltF4
In for pics...
AltF4's Avatar
Reputation: 0 AltF4 is on a distinguished road
Thanks,
Charlie
I had to pull mine out and came across this very thread back in the day. It's actually much easier than you think. Let's see if I remember this:
- Remove trim above glove box. (should pop off with fingers easily)
- Remove trim above nav. (should pop off with fingers easily). I believe this gives access to vent screws.
- Remove vent screws.
- Remove air vents above nav with help of flathead screw driver. This is tricky and feels like it's going to brake. Just pull it straight out. There are grooved clips attached to the vents holding it in place in the dash, they are pretty strong though and shouldn't brake. This gives you access to the bolts holding the nav.
- Remove nav screws.
- Finally, open nav unit by pressing the eject button (like to put a tape in). You only have a few seconds before it'll close automatically. Here is the magic that I had to dig for...go buy two metal finger-nail files, basically flat and thin...at the bottom of the nav under the faceplate there are two slots, one on each side. Insert the nail files in each slot and the nav should just slide right out.
Brian
2002 E46 M3 ~ SMGII
VMR V710 : TR MT1 : ZCP Brakes : StopTech : PFC : AR20 : UUC / Corsa
Ground Control Susp/Sway : RE FCAB : DICE : BW : AFE : PF : DEPO : Scoops
Coby Wheel : Black Trimming : Custom Alcantera / Brushed Alum Dove Grey
Jump to top AltF4 is offline   Reply With Quote
Old Mon, Apr-06-2009, 08:24:49 PM   #18
daytonaviolet
OEM CSL Whoore
great info also, to avoid the nav screen from closing again.. just unplug the battery when the nav screen door is in the up position. this way you can take your time.
- Remove air vents above nav with help of flathead screw driver. This is tricky and feels like it's going to brake. Just pull straight out. This gives you access to the bolts holding the nav.
- Finally, open nav unit by pressing the eject button (like to put a tape in). You only have a few seconds before it'll close automatically. Here is the magic that I had to dig for...go buy two metal nail files, basically flat and thin...at the bottom of the nav under the faceplate there are two slots, one on each side. Insert the nail files in each slot and the nav should just slide right out.
Brian
Old Mon, Apr-06-2009, 08:34:24 PM   #19
daytonaviolet
OEM CSL Whoore
also.. i purchased this navigation removal tool from tom@eas. it made the removal very simple
Navigation Removal Tools
Old Mon, Apr-06-2009, 08:38:58 PM   #20
AltF4
In for pics...
AltF4's Avatar
Thanks. Good idea on the nav door/battery thing too!
Not to take away from EAS as I use them as well but if you're looking to get it done tonight...here is the kind of file you should look for:
2002 E46 M3 ~ SMGII
e46, navigation, removal
HELP - E46 M3 Navigation Removal biglar Audio/In Car Entertainment (I.C.E.) 4 Fri, Mar-14-2008 05:16:21 AM
e46 Navigation Software FTR M3 E46 M3 (2001-2006) 1 Fri, Dec-28-2007 02:04:42 AM
E46 Navigation vs. iDrive ZeroG E46 M3 (2001-2006) 3 Sun, Jul-29-2007 09:19:12 PM
Stock Navigation removal apexapex Audio/In Car Entertainment (I.C.E.) 5 Sat, Jan-21-2006 05:43:23 PM
e46 navigation removal Thunberg E46 M3 (2001-2006) 3 Fri, Jul-02-2004 09:39:55 PM
Discussing HELP - E46 M3 Navigation Removal in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
