Old Tue, May-15-2007, 04:25:11 PM   #1
rollielvp
Leo
Reputation: 0 rollielvp is on a distinguished road
Default Starter motor removal
Anyone has experience and/or DIY with removing starter motor from e46 M3 SMG? Mine is dead, but I can't reach the bolts to take it off...
Jump to top rollielvp is offline   Reply With Quote
Old Tue, May-15-2007, 05:50:09 PM   #2
shalend
SHALEND
Reputation: 0 shalend is on a distinguished road
South Africa
Default E46 M3 starter removal.
1. Raise vehicle -- front & rear.
2. Disconnect battery.
3. Remove air housing.
4. Remove air-box, airmass sensor, dipstick-tube & intake housing.
starter is now exposed.
5. Remove wiring from stater.
6. Now go under vehicle. Remove exhaust system - complete [ from manifold to
rear box. Don't foget to remove oxygen sensors wiring plugs]
7. Remove bolts for gear-box cross member. gearbox is now lowered at rear.
8. Remove bolts for stater on bell-housing.
9. Stater is now loose.
10. Remove stater from engine bay side.
NB. Make sure locating pin on gear-box bell-housing is alighned with stater & tighten bolts evenly , when assembling.
Jump to top shalend is offline   Reply With Quote
Old Tue, May-15-2007, 07:34:00 PM   #3
rollielvp
Leo
awesome - thanks for your help, man!
Old Tue, May-15-2007, 07:40:40 PM   #4
rollielvp
Leo
Shalend, another quick question: once the gearbox is lowered at the rear, do I need to support it with something? Or do I just let it "hang" like that?
Old Wed, May-16-2007, 06:02:09 PM   #5
shalend
SHALEND
South Africa
Let it hang , it's fine
Old Thu, May-17-2007, 01:56:46 PM   #6
rollielvp
Leo
man, removing exhaust system is a pain... all the bolts are rusted
Old Thu, May-17-2007, 04:21:59 PM   #7
kiloil
kiloil's Avatar
Reputation: 0 kiloil is on a distinguished road
I didn't think you needed to remove the exhaust?
2009 E92 M3 MT (Gone)
2011 4 Runner Limited 4WD (Gone)
1996 4 Runner 4WD (Too sendimental to get rid of)
2013 E92 M3 MT (Gone)
2015 25 SLX Sea Ray 8.2L Magnum Big Block.
Jump to top kiloil is offline   Reply With Quote
Old Thu, May-17-2007, 06:19:14 PM   #8
shalend
SHALEND
South Africa
You run the risk of breaking exhaust flanges , if you don't remove the exhaust.
Old Tue, May-22-2007, 03:37:43 AM   #9
rollielvp
Leo
the starter is finally out of the car - thanks again for you help, Shalend! I wouldn't have been able to figure it out otherwise. I took the starter apart, and one of the brush wire melted in half; the solenoid is also dead. I will post pics some time later.
Old Thu, Jun-14-2007, 06:03:25 AM   #10
mikymu
Reputation: 0 mikymu will become famous soon enough
holy mother of %&#! i would just install a hand crank. that is freaking involve for just a starter
Jump to top mikymu is offline   Reply With Quote
motor, removal, starter
Starter removal/installation DIY tilolite E46 M3 (2001-2006) 12 Wed, Dec-16-2009 07:07:18 PM
starter removal plz help!!! andresvillanu20 E36 M3 (1992-1999) 12 Wed, Sep-03-2008 07:13:25 PM
fs: M3 starter (new, never used) Benihana E36 M3 (1992-1999) 3 Sun, Sep-17-2006 10:33:23 PM
Thread Removal and Notifying The Thread Starter E90_GEN Member Notes and Requests to Admin/Mods 5 Sat, Feb-19-2005 06:19:47 PM
M3 Starter miduso E36 M3 (1992-1999) 6 Wed, Feb-19-2003 07:43:30 PM
Discussing Starter motor removal in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
