Old Wed, Jun-09-2010, 11:59:46 PM   #41
THEHOUNDER
Ezekial 23:20
THEHOUNDER's Avatar
Reputation: 0 THEHOUNDER is on a distinguished road
Originally Posted by docwyte View Post
I couldn't imagine carrying 4 wheels/tires on the roof of the car. Just seems so ghetto to me as well as a huge PITA lifting a 50lb+ wheel/tire combo on and off the roof of the car.
I was very pleased with my tow hitch, worked great and I was able to keep all the tools etc in the tire trailer too.
It's actually three on the roof and one in the trunk. It might be ghetto, but I didn't need to cut up my car to do it. It's no big deal to lift the wheels /tires on the roof. It's only a couple of feet higher than lifting them onto your trailer.
Race Car Build Thread
2004 Silbergrau SMG/ Vulcan Racing Fab Cage / V-CSL Roof/Works Bell SMG/ Fabspeed Headers/ Epic tune/ BW 3.5"/Cobra Sebring /Brembo 355/345 / GSP Gen 1 Pedal /Moton CS / Ground Control Race Bars / AIM Solo DL /Other junk and stuff
2012 Mercedes GL450 - Tow pig
2010 Featherlite 17'6" open
2013 e93 ///M3 -stock
Jump to top THEHOUNDER is offline   Reply With Quote
Old Thu, Jun-10-2010, 01:39:45 AM   #42
elbert
Sikkens Autocryl MM
elbert's Avatar
Reputation: 0 elbert has disabled reputation
Wales
Originally Posted by TJe46M3 View Post
Also, Mike Miller from the Roundel Magazine told me that the electronics to run the trailer lights might turn into a huge problem since the US e46 M3 wasn't built for a trailer. Any thoughts? Thanks.
A lot of the German cars have problems when you tap into the light circuits.
You need to get a Modulite, which powers the trailer lights separately.
http://www.drawtite.com/modulite1.html
Jump to top elbert is offline   Reply With Quote
Old Thu, Jun-10-2010, 01:50:56 AM   #43
kaiv
SoCal S54 specialist :P
kaiv's Avatar
France
Originally Posted by THEHOUNDER View Post
You will also need to purchase some 1 inch square metal bars/tubes and some bolts and create wheel stops so that wheels won't roll backward or forwards.
Thanks
E46 ///M325i Touring journal
Kaiv's SoCal Feedback!
IG: limited.slip
Old Thu, Jun-10-2010, 02:18:30 AM   #44
docwyte
Track addict
docwyte's Avatar
Reputation: 0 docwyte is on a distinguished road
I didn't have to cut up my car for the hitch.
The 330 aluminum bumper beam directly replaces the stock kevlar one. Not sure what you're confused about there...
I also didn't need anything special for the trailer lights. I used a standard wiring harness and it worked fine.
'98 BMW M3 Track Rat
'06 Porsche Cayenne Turbo S 521hp Daily Driver
Jump to top docwyte is offline   Reply With Quote
Old Thu, Jun-10-2010, 03:12:39 PM   #45
delirium45
Bottom Feeder
Reputation: 0 delirium45 is on a distinguished road
i will post some pictures today of my install. but it is Doc's old hitch so nothing different really.
for the record, my car is an '04 and i have the LED tail lights, had no problem tapping into those signals lines for triggering the lights on the trailer, power is fine too, not dim or anything.
update:
here are the pictures i took when installing the hitch.
Here is the whole hitch, you can see that it is two pieces that bolts together. This is necessary as the hitch is very tight fitting and will not just slide in/out of the frame, it needs to be put in one part at a time then bolted together.
Now for the car.
Here is the starting bumper/exhaust setup:
bumper removed (note the two round openings in the frame):
the holes that these bolts go into are already there from the factory:
i have installed the left side of the hitch into the round frame opening:
both sides of the hitch are installed and the two halves are bolted together, please note that the larger tip diameter of the RE El Diablo touched slightly on the hitch frame, so i ended up installing my OEM exhaust temporarily as the tips are not as big and cause no interference:
bumper reinstalled (w/o exhaust):
ball and drop (i mean lift) tongue installed:
_ Garrett
2011 Rocky Mountain Region GTS4 champion & "Rookie of the Year"
2012 Rocky Mountain Region GTS3 champion
2013 National GTS3 - 4th place
Thanks Sponsors: SCR Performance
Jump to top delirium45 is offline   Reply With Quote
Old Thu, Jun-10-2010, 04:16:52 PM   #46
blue dragon
Proudly Canadian
Reputation: 0 blue dragon will become famous soon enough
Doc, who made the hitch for you?
Happiness is not just around the corner, it is the corner!
Jump to top blue dragon is offline   Reply With Quote
Old Thu, Jun-10-2010, 04:27:34 PM   #47
delirium45
Bottom Feeder
Here are a couple shots of the trailer attached to the hitch.
_ Garrett
Old Thu, Jun-10-2010, 05:02:06 PM   #48
Hopofthese
Hopofthese's Avatar
Reputation: 0 Hopofthese is on a distinguished road
Thats a nice little hitch . Although I prefer to put all that stuff inside the car and not have to worry about the hitch when I am cruising doing 100+ to the track.
S.O.H.
Jump to top Hopofthese is offline   Reply With Quote
Old Thu, Jun-10-2010, 05:39:46 PM   #49
TJe46M3
Reputation: 0 TJe46M3 is on a distinguished road
I am confused because you said the 330 bumper beam is the same as the M3 bumper beam (with the exception of being aluminum). But if you look at the realoem diagrams in the links in my earlier post, they appear to be shaped completely differently. So I am worried that the M3 bumper panel will not be able to attach to the 330i bumper beam. See my point?
2004 BMW M3 (6MT)
2002 BMW X5
Jump to top TJe46M3 is offline   Reply With Quote
Old Thu, Jun-10-2010, 05:50:49 PM   #50
docwyte
Track addict
docwyte's Avatar
You're thinking too much. Remove kevlar bumper beam. Bolt on aluminum 330 bumper beam. Finished.
The trailer is more than stable at 100mph. Trailer hitch works great.
Friend and I made it ourselves.
track, transporting, wheels
Thinking about transporting car kkamakasi Off Topic 3 Sat, Jul-05-2008 03:43:59 AM
Track wheels comapare CCW classics vs. Kodiak wheels rt's Jasoncor M3 Track: Racing and DE 1 Mon, Oct-01-2007 01:16:17 AM
Transporting the M JoeE46M3 E46 M3 (2001-2006) 5 Tue, May-29-2007 10:03:16 PM
need quick help.. transporting oem csl bootlid bmwJohhnyD E46 M3 (2001-2006) 7 Sun, May-13-2007 03:56:28 AM
CCW Track Classic Wheels: Street vs. Track |Drew| M3 Track: Racing and DE 6 Fri, Jul-29-2005 05:38:56 AM
Discussing Transporting Track Wheels in the M3 Track: Racing and DE Forum - Best mod for speed is learning to get the most out of what you currently have. Tracks and DE's is the place to start! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
