Go Back   BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X) > BMW M3 Discussions > M3 Frequently Asked Questions > E46 FAQ
Closed Thread
Old Sun, Sep-28-2003, 03:12:37 AM   #1
droptop
droptop's Avatar
Reputation: 0 droptop is on a distinguished road
Default BMW Service Bullitins (Convertibles Only)
Mods- Please pin this for easy access.
Bulletins for 2001 BMW M3 (E46) Convertible L6-3246cc 3.2L DOHC (S54)
Safety Recalls
TSB Number Issue Date TSB Title
340601 SEP 01 Recall - Parking Brake Cable Fastening
General Recalls
110601 OCT 01 Campaign - Engine Oil Viscosity Change
520101 JUL 01 Campaign - Backrest Switch Replacement
840600 AUG 00 Campaign - Navigation System Failure
Service Bulletins
540102 MAY 02 Body - Headliner/Soft Top Staining
620102 MAY 02 Instruments - Cluster Beeps When Selecting REVERSE Gear
240202 APR 02 A/T - Hard Shifts/Leak at Torque Converter Seal
210101 FEB 02 M/T - Popping/Clicking From Clutch Pedal
640891 JAN 02 A/C - Musty Odors
650599 JAN 02 Audio System - Radio Security Code Acquisition
360601 DEC 01 Tires - Pressure Setting Procedure
110801 NOV 01 Engine - Revised Connecting Rod Bearing Clearance
651001 NOV 01 Instruments - Split Screen Board Monitor Setting
110898 OCT 01 Engine - Oil Recommendations/Change Intervals
110400 OCT 01 Engine - Oil Recommendations/Checking Procedure
240198 SEP 01 A/T - Fluid Level Checking Procedure
180201 AUG 01 Exhaust - Muffler Type Availability
840701 AUG 01 Cellular Phone - Intermittent Malfunctions
650601 JUL 01 Cassette Radio - REG OFF, Displayed
180101 JUL 01 Rear Muffler - Revised Replacement Parts
320201 JUL 01 Steering Gear - Replacement Due to Accident Damage
110101 JUN 01 Engine - MIL ON/Codes Set/Tapping/Rattling Noise
841197 JUN 01 Navigation System - Numerous Failures/Malfunctions
330101 JUN 01 Rear Axle - Radial Play in Right Side Axle Flange
840401 MAY 01 Battery - Disconnecting Procedure With MK3 Nav System
650600 MAY 01 Radio - AM Band Whining When Brake Pedal Depressed
340201 MAR 01 Brake Caliper - Lubrication
630201 MAR 01 Light Bulb - Replacement Guidelines
720101 MAR 01 Seat Belts - Click/Rattle From Upper Mount
840201 FEB 01 Audio System - Delayed Sound/No Audio Display
840101 FEB 01 Cellular Phone - No Volume Adjustment
090101 FEB 01 Vehicle and Key - Memory Programming
630101 FEB 01 Xenon Lamp Bulb - Color Change After Operation
640101 JAN 01 A/C System - Musty Odors
611600 JAN 01 Battery - Maintenance
160400 DEC 00 Check Engine Lamp ON/DTC's Stored
841200 DEC 00 Digital Cellular Phone - Training/Troubleshooting Manual
111190 DEC 00 Engine - Oil Capacities With Filter Change
110900 DEC 00 Engine Controls - False Low Oil Level Lamp Illumination
410200 DEC 00 Interior - Wind Buffeting
110901 DEC 00 Thermal Oil Level Sensor - Operation and Diagnosis
650499 AUG 00 Audio System - Test CD/Tape
360200 JUL 00 Tires and Wheels - Applications
Jump to top droptop is offline
Old Sun, Sep-28-2003, 03:15:53 AM   #2
droptop
droptop's Avatar
Default BMW Service Bullitins (Coupes Only)
Bulletins for 2001 BMW M3 (E46) Coupe L6-3246cc 3.2L DOHC (S54)
Safety Recalls
General Recalls
Service Bulletins
840102 JAN 02 Navigation System - Features/Software Update
510401 DEC 01 Body - Door Edge Protection Seal Rubs on Door Panel
540701 DEC 01 Sunroof - Revised Initialization Procedures
720300 JUL 01 SRS - Warning Light ON/Multiple Fault Codes Set
510301 JUN 01 Interior Mirror - Installed Without Red DWA (Alarm) LED
180299 NOV 00 Exhaust System - Back Pressure Checking Tool
330200 NOV 00 Rear Differential - Whine Noise
240900 OCT 00 A/T - Repair/Replacement Guidelines
720897 OCT 00 Airbags - Deactivation
241000 OCT 00 Engine Control Module - MS 43 Removal Precautions
610800 AUG 00 Electrical - Closed Circuit Current Measurement
620400 AUG 00 IC Conversion - Km/h to Mph or Mph to Km/h
230200 AUG 00 M/T - Oil Fill/Drain Plugs Updated
720200 JUL 00 Airbag Control Module - Warning Light ON/Codes Set
510400 JUL 00 Door Sound/Vapor Barrier - Water Leaks
610500 JUL 00 Electrical Connnectors - Stabilant 22A Contact Enhancer
120400 JUL 00 MIL ON, Multiple DTC's Stored
720399 JUL 00 Rear Airbag - Activation/Deactivation
610700 JUL 00 Windshield Wiper Blades - Noisy/Not Cleaning Well
620200 JUN 00 Instrument Cluster - Erratic Operation Diagnosis
640100 MAY 00 A/C - IHKA Module LED in A/C Button FLASHES
240800 MAY 00 A/T - Fault Code 48, TCC Solenoid
160100 MAY 00 Fuel System - MIL ON, Tank Leakage Fault Codes
630100 JAN 00 Headlamps - New Vertical Adjustment Settings
330299 APR 99 Rear Suspension - Pops or Snaps on Dips and Bumps
110598 SEP 98 Crankcase Ventilation System - Diagnostic Information
620279 NOV 79 Turn Signal Indicator - Inoperative/Circuit Change
Old Sun, Sep-28-2003, 03:25:52 AM   #3
Raptor
Demonic M3
Raptor's Avatar
Reputation: 0 Raptor is on a distinguished road
"620279 NOV 79 Turn Signal Indicator - Inoperative/Circuit Change"
I didn't know our cars were around in 1979
Imola Red/Black M3 Coupe
Jump to top Raptor is offline
Old Sun, Sep-28-2003, 03:40:22 AM   #4
bimmerbadass
Reputation: 0 bimmerbadass is on a distinguished road
even tho ur 12 u sound like ur 45
Jump to top bimmerbadass is offline
Old Mon, Sep-29-2003, 10:08:59 PM   #5
Yup Yup!
Reputation: 0 Yup Yup! has disabled reputation
Default Re: BMW Service Bullitins (Coupes Only)
Originally posted by droptop
Service Bulletins
Cluster beeping in reverse? I'm going to feel like an idiot for asking but I have to know...I thought it beeps if you have PDC?
Torque converter for smg2??? I thought smg2 uses the same tranny as the regular manual thus no need for a torque converter?
Jump to top Yup Yup! is offline
Old Thu, Oct-02-2003, 04:11:10 AM   #6
stabmasterflex
stabmasterflex's Avatar
Reputation: 0 stabmasterflex is on a distinguished road
the tranny is the same. The clutch and shifter is comp. operated. I've experienced this beeping as well. I'll do some research and get back to you.
Jump to top stabmasterflex is offline
Old Thu, Oct-02-2003, 08:28:08 AM   #7
Yup Yup!
I was pretty sure the tranny's the same but why is there a TSB for a torque converter if this's a manual tranny?
Old Tue, Oct-07-2003, 12:50:59 AM   #8
FlyinM3
FlyinM3's Avatar
Reputation: 0 FlyinM3 is on a distinguished road
are there any service bulletins for 2003 models?
06 Lexus GS430
03 M3-SMGII
98 Audi A4
Jump to top FlyinM3 is offline
Old Tue, Oct-14-2003, 05:37:12 PM   #9
Yup Yup!
Just dropped off the car at the $tealership for the 1200 miles thingy & they told me of a light control module recall they have to perform. Mine's a June 03' build if it helps.
Old Mon, Oct-20-2003, 08:21:11 PM   #10
daihard
Freude am Fahren
daihard's Avatar
Reputation: 0 daihard is on a distinguished road
Could you give me a bit more detail about the light control module recall? Thanks!
Jump to top daihard is offline
Closed Thread
How can I locate BMW service bulletins (SIB's)? TeeKay E46 M3 (2001-2006) 13 Fri, Dec-10-2010 12:55:54 AM
Warrantee and service bulletins sjehrlich E46 M3 (2001-2006) 7 Wed, Mar-15-2006 01:19:01 AM
Service Bulletins grmnrkt E46 M3 (2001-2006) 3 Tue, Mar-14-2006 12:53:31 PM
What happened to the service bulletins???? smoldin Member Notes and Requests to Admin/Mods 35 Sat, Apr-02-2005 11:51:53 PM
service bulletins? recalls? chang_lee Off Topic 1 Thu, Nov-25-2004 09:46:19 PM
Discussing BMW Service Bulletins 01-03 (Coupes & Cab) in the E46 FAQ Forum - at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
